Old 07-11-2014, 06:08 PM   #2151
BagRidersJohn
Member#: 372859
2006 WRX Wagon Ltd.
Sedan Wide Body UGM
Originally Posted by Topher03 View Post
What about the other hose off it? I dont have a intake anymore
The other hose from the crankcase vent goes to the turbo inlet and has the PCV diagnostic sensor in it. If you no longer have the sensor you can jump the pins on the harness together since it just needs to see continuity.
BagRidersJohn is offline   Reply With Quote
Old 07-11-2014, 06:14 PM   #2152
BagRidersJohn
Member#: 372859
2006 WRX Wagon Ltd.
Sedan Wide Body UGM
I did a write up on rotating the alternator positive post, it can be found in my build thread here: http://forums.nasioc.com/forums/show...2568979&page=5
I broke an alternator doing this the first time and then figured it out, so let my loss be community gain
Old 07-12-2014, 11:47 PM   #2153
I--RIDE--BIKES
Member#: 279176
2006 Sti
SGM
Just finished doing this to my sti. Just working on the tuning now and slightly changing things here and there.
I--RIDE--BIKES is offline   Reply With Quote
Old 08-20-2014, 04:54 PM   #2154
LeeC
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Just wanted to post to provide a little help for people wanting to flip the alt with all oem parts.
Shaved AC bracket so the alt will flip, a little bit of bending on the stock STi black ac bracket (steel one) along removing the 10mm stud and drilling a hole in it's place.
Running the smallest of the idler pulleys on a subaru timing assembly on the stock PS tensioner slot and using a stock PS/alt tensioner to tension the pulley, tightening and removing.
Granted this isn't how I would do it if I wanted a baller engine bay, but it works. Belt size is 46in.
LeeC is offline   Reply With Quote
Old 08-20-2014, 05:10 PM   #2155
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
mines is almost done
bue car is offline   Reply With Quote
Old 08-30-2014, 10:41 PM   #2156
Razgeiz
Member#: 358782
2013 STi
My reverse manifold project begins today
Razgeiz is offline   Reply With Quote
Old 08-30-2014, 10:44 PM   #2157
elbertmurphy
Member#: 268256
2005 STI
Nice dude, include pictures
Sent from my iPhone using NASIOC
elbertmurphy is offline   Reply With Quote
Old 09-01-2014, 12:54 AM   #2158
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
My car is still at the shop getting finished up slowly.
Old 09-01-2014, 05:09 PM   #2159
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Token-Negro is offline   Reply With Quote
Old 09-01-2014, 05:12 PM   #2160
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
Originally Posted by Token-Negro View Post
Sweet Jesus !!!
M4c0770 is offline   Reply With Quote
Old 09-01-2014, 05:19 PM   #2161
elbertmurphy
Member#: 268256
2005 STI
Originally Posted by M4c0770 View Post
Sweet Jesus !!!
Is that your car?
Old 09-01-2014, 05:21 PM   #2162
M4c0770
Member#: 225851
07 Spec Wannabe
Originally Posted by elbertmurphy View Post
Is that your car?
No brother. In my dreams only. I wish I can afford to tuck all wiring like that.
That pic was posted before me by Token Negro like it says on the upper corner.
Old 09-01-2014, 05:47 PM   #2163
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
wow... i should quit after seeing that. LOL
Old 09-01-2014, 06:03 PM   #2164
elbertmurphy
Member#: 268256
2005 STI
No way dude. Can't stop won't stop. Haha.
Old 09-01-2014, 07:18 PM   #2165
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Here is a more straight on shot, little out of focus.
Old 09-01-2014, 07:23 PM   #2166
elbertmurphy
Member#: 268256
2005 STI
Do you have any pics of the build? I want to replace my vacuum and breather lines with AN lines. Similar to what you've done.
Old 09-02-2014, 01:19 AM   #2167
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
Should have deleted the power steering
Old 09-02-2014, 08:19 AM   #2168
Razgeiz
Member#: 358782
2013 STi
Token is that a track car/weekend warrior or you daily that bad boy?
Sent from my DROID RAZR using NASIOC mobile app
Old 09-02-2014, 09:19 AM   #2169
M4c0770
Member#: 225851
07 Spec Wannabe
I am sure he does or plan to track his ride. You can follow him at his other post if you haven't. He also has some flares added for the flavor.
Old 09-02-2014, 11:36 AM   #2170
Razgeiz
Member#: 358782
2013 STi
I'd love to custom fab a top mounted intake for my rotated setup. Put a small hole in the bottom to allow water to drain
Old 09-06-2014, 04:16 PM   #2171
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Anyone know the belt size for the Outfront alternator relocation kit?
Sent from my XT907 using NASIOC mobile app
wrxsubiemod is offline   Reply With Quote
Old 09-09-2014, 10:19 AM   #2172
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
You could use masking tape to figure out the size you need faster than posting on the forum.
Old 09-09-2014, 10:26 AM   #2173
elbertmurphy
Member#: 268256
2005 STI
No build pics?
Old 09-09-2014, 10:29 AM   #2174
Subimods
Member#: 209139
2005 STi
Digital Camo Gray
I've also used string or wire in the past for previous setups when measuring.
Subimods is offline   Reply With Quote
Old 09-09-2014, 11:01 PM   #2175
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
^ this
stock intake manifold TB to manifold flange, stainless uppipe to turbo flange White 2.5rs Engine/Power/Exhaust 6 04-02-2007 01:24 PM
F/S: Borla header, Intake manifold, TB, TGV 01G_WRX_02 Private 'For Sale' Classifieds 14 03-03-2006 05:44 PM
'02-04 WRX intake manifold/tb/sensors annointed Private 'Wanted' Classifieds 6 03-05-2005 02:30 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
WRX intake manifold/TB question black knight Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-20-2003 10:58 AM
