05-05-2015, 04:44 PM | #1 |
Member#: 285083
MAIC
Vehicle:2006 STi WRB |
Phatbotti Tuned 06 STi * TMIC WORLD RECORD 9.9@132* GS TMIC,EFR7163,IAG Motor,Cobb AP
Event: E-Tuning
Location: California/Virginia Ambient Temp: 80 Elevation: 0 Weather: Sunny Car: 2006 STi Tuner: Ron Watson- aka Phatron of PhatBotti Tuning Tuned With: Cobb Speed Density Dyno Info: Virtual Dyno Transmission: Stock 2006 STi 6 Speed Gear: 4th Peak HP at RPM: 550 Peak Torque at RPM: 535 Baseline hp/tq for a stock on same dyno: 235/235 Target Boost: 32 psi tapering to 28psi Target AFR: 11.7 Fuel: E85 2006 WRB STi -Paul Wilson driver mod -Cobb V3 Accessport on Speed density -Grimmspeed TMIC with black thermal dispersant coating -Grimmspeed Intercooler Splitter -Grimmspeed port & polished & coated intake manifold -IAG Closed deck shortblock -IAG CNC ported heads -IAG 1/2" headstuds -IAG TGV deletes -IAG V2 fuel rails with dampers -Tigwerks full V-band rotated piping kit with equal length header and 3" downpipe -Injector dynamics 1300cc Injectors -Walbro 450 E85 fuel pump hardwired -Turbosmart 45mm Hypergate EWG, 26psi spring combo -Turbosmart 1200 V2 FPR -Borla XR-1 catback exhaust -R2C Black hex series filter on Vibrant velocity stack to 3" intake pipe -AEM 3.5 bar MAP sensor with Cobb adapter -AEM IAT sensor -AEM UEGO wideband -Hallman Pro RX with heavy spring -Fluidampr crank pulley -NGK Iridium one step colder plugs -ACT HD R6 Clutch -OEM STi Flywheel -ACPT 1 Piece CF driveshaft -Ceramic wheel bearings -Gauges: STRI Boost, Oil pressure, and EGT ---------------------*NEWEST 2016 UPDATE*-------------------- 9's on a Grimmspeed TMIC and a little EFR7163?????? No Problem! 9.97@132mph... Got my single digit pass on my first run ever at MIR during their last test and tune session of the year 11/27/16 ----------------------------------------------------------------- 2016 UPDATE---------------------------------------------------- Couldn't get into the 9s this weekend, but got my record a bit lower with a 10.12 @136mph. I will give it another shot in a couple weeks, I managed to cut a 1.37 60ft my other pass but the car got way too sideways in 2nd gear and I had to bail. This pass I only cut a 1.46 and had a slight hesitation in my drive and shifting from getting scared by this out of control mustang lol ----------------------------------------------------------------- ***2015 UPDATE*** JUST WENT TO THE TRACK ON 8/21/15 AND TOOK THE OVERALL SUBARU TMIC RECORD. I got 4 Passes in and ran 10.25, 10.19, 10.18, and 10.17. All 4 passes with 1.4x 60fts and 1.40 was my best. I will be shooting for 1.3x 60fts and 9.9s next time I go. 10.18 run pits view 10.18 gopro view 10.17 run pits view Crossing 500wtq by 3700 RPM is just insane for a turbo that makes 550AWHP on a EJ257 Keep in mind this a short gear 06 sti trans, 4th gear on 07+ STi would appear to spool much quicker While I was building the motor last year in my garage (several parts in this picture are different now of course) And a few more pictures of the car and the building process Want to thank Ron especially for spending countless hours with me to get this beast dialed in 100% remotely. He has tuned all my different setups over the last few years and also tuned a lot of my friends cars that I have help setup locally with great results each and every time. I highly recommend him if you are looking to get an E-tune... Also If you live in CA or nearby just go visit his shop in person to get a protune on his dyno, he has the most professional and nicest dyno room setup I've ever seen.
05-05-2015, 04:46 PM | #2 |
Member#: 285083
MAIC
05-05-2015, 05:13 PM | #3 |
Member#: 239335
W. Canada
Vehicle:2011 WRX WRB |
She's moving that is for sure!
Now I am leaning towards this turbo over rotated again |
05-05-2015, 06:46 PM | #4 |
Member#: 382959
Torque curve/spool looks like a stage 2 except the numbers doubled. "Nasti" build and tune dude lol.
05-05-2015, 11:22 PM | #5 |
Member#: 294644
MAIC
Vehicle:2011 WRX Agile Auto DGM 440whp 420wtq |
Man I love this turbo, good work guys. I'm moving to alexandria here in 2 weeks. I'm sure I'll see you around.
05-05-2015, 11:53 PM | #6 |
Member#: 326377
SCIC
Vehicle:2006 WRX Wagon Aspen White |
Very nice setup, and good driving.
05-06-2015, 08:27 AM | #7 |
Member#: 158888
MAIC
Vehicle:2011 STi EFR 7163! 07 GT30 WRX sold :/ |
Good stuff. I wonder how the stock location vs rotated setup varies on this turbo. I have the stock location 7163 vband kit for my 2011 sti but it is only at 20psi because of the actuator that was maxed out :/
05-06-2015, 09:19 AM | #8 |
Member#: 232458
SWIC
Vehicle:2005 & 2008 STi Cobb 20g & EFR 7670 |
I was trying to remember the car, but instead remembered the driver! You can drive man, makes it that much better your car is fast! Nice work! Good job on the tune Ron!
05-06-2015, 09:47 AM | #9 |
Member#: 108091
Vehicle:2002 WRX |
That power band is freaking amazing!!!
Nice work Ron!!! |
05-06-2015, 10:26 AM | #10 |
Member#: 68647
MAIC
Vehicle:07 STI 35R 05 BMW M3 ZCP |
Wow what a powerband! And a nice 10 sec pass at Richmond Dragway too. People laugh when I tell them I've ran my best times at that track when compared to VA Motorsports park I guess the ****ty track prep there just works well for AWD cars!
05-06-2015, 02:36 PM | #11 |
Member#: 294644
MAIC
Surprisingly enough, I haven't seen too much of a difference in power difference. We have a guy here in NOVA rocking a low mounted 7163 and he actually pushes nearly identical power on E85 with similar boost plots. He later opted for a twin scroll version to gain more spool and i think it reduced his overall top end by 15hp. He's an autocross junkie and needs as much power down low as possible
05-06-2015, 02:54 PM | #12 | |||||
Member#: 285083
MAIC
We have a massive subaru community here in the hampton roads area, not sure how close Alexandria is thoe |
05-06-2015, 04:15 PM | #13 |
Member#: 140036
intake flow is important!
05-06-2015, 04:43 PM | #14 |
Member#: 379581
BAIC
Vehicle:2014 WRX Gloss Vengeance Red |
Jealous of that powerband.
*checks bank account* |
05-06-2015, 08:18 PM | #15 |
Member#: 57064
Vehicle:2008 STi IAG built HTA86 E85 Kel272s Cos IM |
05-06-2015, 08:19 PM | #16 |
Member#: 57064
puts my powerband to shame
I need that E85 doe |
05-07-2015, 09:32 AM | #17 |
Member#: 420458
Vehicle:07 WRX STI Urban Grey |
This thing is moving! Crave power/torque curves.
05-07-2015, 11:46 AM | #18 |
Member#: 80649
South East
Vehicle:2000 2.5 Auto-X RSTi Sparkly |
Just curious, what do you see for IAT's at the end of a run? I've got a 6758 and a similar TMIC and without a water sprayer I'm seeing 170's after a 2-3-4 pull at 27 psi.
05-07-2015, 02:59 PM | #19 | |
Member#: 285083
MAIC
E85 is key. I haven't bought a single gallon of 93 in about a year now IATs rise 19-20 degrees on 4th gear Vdyno pulls 2000-7000rpm. IATs rise about 39-40 degrees going thru all the gears (1-5) like at a dragstrip. What TMIC you running? Also I dont think the water sprayer really makes much difference lol I just press it before drag passes because its there and fun to press Mabey ill try and press it next time I do a 4th gear VD and see if I notice any difference |
05-07-2015, 03:42 PM | #20 | |
Member#: 80649
South East
Thanks for the data point |
05-07-2015, 05:04 PM | #21 |
Member#: 372764
I have basically the same build plus some headwork but my 7163 did 422whp and 460ftlbs of torque at 24psi on E85. I am at 5000ft elevation and it was on a dyno dynamics instead of a dyno jet....Think the numbers are comparable or somethings up?
Did you notice any improvements in spool with a larger inlet pipe as apposed to just using a 2.5" diameter pipe...My inlet goes for about 1.5' of 2.5" pipe and I was thinking that could be somewhat of a restriction of airflow....I've seen more and more use a 3" or 3.5" diameter pipe and reducing it down at the compressor housing. |
05-08-2015, 01:21 AM | #22 | ||
Member#: 285083
MAIC
I think a 3" intake pipe works best on this turbo as its just a very minor smooth step down at the inlet and seems to work much better then the 3.5" pipe I used before |
05-08-2015, 12:40 PM | #23 |
Member#: 167794
Vehicle:08 500+whp sti |
nice work. what's your basic piston/rod setup? just wondering
05-08-2015, 01:31 PM | #24 |
Member#: 108091
Vehicle:2002 WRX |
Picture looks like Cossie pistons and Manley h tuffs???
05-08-2015, 02:21 PM | #25 |
Member#: 167794
pics are filtered at my work... sorry for pointless question, but thanks for the answer.
