Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 08-20-2003, 07:48 PM   #1
Member#: 37417
2003 Impreza RS 2.5
Blue Ridge Pearl
Default 2.5RS to new 2004 STI
is there anyway to do an sti conversion from a 2003 RS to an STI since they both have 2.5l engines. the only big difference i know of is the sohc of the rs and dohc or the sti. are there anyother major differences? what would i do replace the cylinder heads get a some guy who is seriously redoing his sti and take his piping and turbo and stuff and put that all in my car? any ideas or suggestions?
mofong is offline   Reply With Quote
Old 08-20-2003, 11:03 PM   #2
Member#: 1305
2000 Impreza
SOHC/DOHC? No, there's a lot more than that.
You're better off just selling your 2003 RS and getting an STI.
AKGC8 is offline   Reply With Quote
Old 08-21-2003, 06:14 AM   #3
Member#: 36080
I agree.... But good on ya though for wanting to be adventrous!!! :COOL:
GreenMarine is offline   Reply With Quote
Old 08-21-2003, 06:51 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Since no one answered well enough...
...looks around...
Let me answer some questions.
The STi has completly different interenals in the engine. It runs stronger internals with a compression ratio of 8.2:1, which is why it can run well with the turbocharger. It also has Subaru's AVCS with is another type of variable valve timing which changes the degree of the camshaft via engine RPM. The other biggy is the transmission driveline. The STi, as you may know sports a 6-speed with DCCD.
Depends HOW MUCH of a STi do you want to impersenate. I'm guessing the power output. You can do that with your engine but you'll have to open it up and put stronger parts in so it can HANDLE the boost, that's if you're going to boost it.
I'm sure you can replace your pistons, and rods with the STi ones. Then you'll have warrenty on the parts too! Then you can turbo it.
You just have to worry about the block. If you don't run high boost say 1.5bar or more then you'll be safe. STi's block is semi closed, yours is open.
Old 08-21-2003, 10:15 PM   #5
Member#: 1305
2000 Impreza
Subaru isn't going to warranty STI pistons and rods in a 2.5rs block. May be the same dimensions, but it wasn't OEM for that engine.
Like I said, he's better off just getting an STI. With the money you'd spend converting an 03 RS into an STI you could have just sold the RS and bought a new STI(assuming mofong would be paying someone to do the work). Even if you did the work yourself it'll still be expensive because the parts are in high demand now. Plus the resale on an 03 rs converted to an STI would be horrible compared to an actual STI.
So like I said, just get an STI.
Differences between the 2000 SOHC 2.5rs and the 2004 SOHC 2.5rs rst4me Normally Aspirated Powertrain 9 01-25-2007 08:19 AM
1999-2001 2.5RS to 04-06 STi swap 5lipstream Subaru Conversions 13 09-15-2006 02:45 PM
2004 impreza 2.5rs to a 2000 leg outback rickinne Subaru Conversions 6 06-08-2006 09:43 PM
R.I.P 2001 2.5RS - Hello new 2004 WRX eclip5e New England Impreza Club Forum -- NESIC 13 10-12-2003 08:27 PM
00' 2.5rs to 97 jdm sti conversion StrongBow Subaru Conversions 2 06-30-2003 04:15 PM
