Old 08-20-2003, 12:21 AM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default please post spec of ej22 turbo clutch
hey- what are the dimensions on the turbo legacy clutch?
is it same as old gc8 turbo clutch -225mm disc / bolt pattern, or same as new gda - 230mm?
h
supermoose is offline   Reply With Quote
Old 08-20-2003, 11:36 AM   #2
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
I'm using a new WRX clutch on my EJ22T motor and '95 WRX tranny.....works just fine
Scoobyslack1 is offline   Reply With Quote
Old 08-20-2003, 04:10 PM   #3
supermoose
Member#: 9093
swap starr
Default flywheel
which flywheel are u using? what friction disc?
h
Old 08-20-2003, 04:20 PM   #4
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
was using Legacy turbo flywheel, but now I have the Exedy flywheel
disk is the Exedy disk
before this I had my original tranny from the 1.8L on there with a ACT pressure plate, stock RS disk & the 1.8L flywheel
Old 08-20-2003, 04:57 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
edit* wrong info
Old 08-20-2003, 05:23 PM   #6
supermoose
Member#: 9093
swap starr
Default disc
hey- so a disc from a legacy turbo is 225mm then? ive got aget some parts for my 94 JDM clutch
h
Old 08-20-2003, 05:32 PM   #7
Z1 Performance
Member#: 9327
All WRX's, and Legacy Turbo's from 93 up use a 225mm disk, and the clutch parts are interchangeable.
Only the GDB STi uses the larger 230mm unit, though you can use the smaller disk on an STi, just not vice versa (heck, its only 5mm anyway!)
Adam
Z1 Performance is offline   Reply With Quote
Old 08-20-2003, 07:15 PM   #8
supermoose
Member#: 9093
swap starr
Default hmm
so ur saying that the GDA usdm WRX has a 225mm disc also?
can anyone measuer it and verify that?
Old 08-24-2003, 12:44 PM   #9
Austin
Member#: 7089
2016 STi
Default Re: hmm
That's been measured a few times - wrx is 225 and STi is 230.
Adam - you said 93 and up Legacy turbo used a 225mm clutch... Like a dope, I forgot to measure the clutch when I had it out my 91 Legacy turbo - Do you know what size the 91/92 Legacy turbo clutch disks are?
Austin is offline   Reply With Quote
Old 08-25-2003, 11:22 AM   #10
Z1 Performance
Member#: 9327
Austin - should be exactly the same, as all GC turbo cars use the same clutches as GDA/GGA's.
Adam
Specs of the turbo spunAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-17-2008 01:11 PM
Please post pics of RS' with white rims please AndyM Brakes, Steering & Suspension 3 07-17-2001 03:15 PM
Please Post Pic of Split Spoke Speedline MY99-01 Danny5 Brakes, Steering & Suspension 1 06-05-2001 12:04 AM
Please post updates of your experience with the Prodrive GT and WR Sport mpaone Brakes, Steering & Suspension 13 04-19-2001 11:27 AM
('93-'01) please post pics of white rs w/gold rims... scubaracer Impreza Forum 6 04-17-2001 12:10 AM
