#1 |
Member#: 42331
South East
Vehicle:2008 BMW 328xi Black |
I'm wanting to start an Impreza project and my budget is a little tight. I was entertaining the thought of buying an Impreza L and swapping an EJ20 into it. Is this possible? And if so, how hard would it be to do? The L would be the chassis I'd be swapping the motor into since I don't have enough money to afford anything higher up in the Impreza line.
After the engine, I'd like to get the styling of a 2.5RS. I was talking to a friend of mine and he said to make the L look exactly like the RS, the only things needed would be the front bumper and the rear wing. How accurate is this? What other cosmetic differences are there between the L and the RS? How difficult are they to do? THe answers to these questions will greatly determine the decision of purchasing an Impreza L for my project car. I know this is my first post on here but hey, gotta start somewhere! Thanks a lot! -Andy
#2 |
Member#: 37641
SCIC
Vehicle:98 Impreza 2.5 RS |
You'll need 2.5RS side skirts if they fit an L and it doesnt already have them. Now correct me if Im wrong but the L has a 2.2L engine? If this is the case you prob need to do a tranny swap in conjunction with the motor swap.
#3 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Take a look at the FAQ. It should answer a lot of your questions.
-Jon |
#4 |
Member#: 42331
South East
Thanks guys.
#5 |
Member#: 26929
Vehicle:2000 Impreza with Gremilins |
I just had this done to my MY00 L, I now have a complete MY02 WRX under my L
To do it right you should do the UP pipe and downpipe and cat back at the same time... I changed my trans and rear diff also to match the WRX. (I bought the whole drivetrain from one car.) I also bought a Yoshio ECU from the guy, and I bought gauges to keep tabs on the new motor. All said I think I spent 10k on the swap so far, I have yet to do any body work other than the hood, which is a VIS CF hood with OEM scoop. |
#6 |
Member#: 33782
MAIC
Vehicle:96 bastard child search FIRST, then PM!!! |
I just did this swap into my 94 and it's well worth it. I have a few minor problems that are being fixed (i.e. A/C). The cost of the whole project came in at under $7000 including the cost of the car!! I highly recommend the swap.
Take it easy, Micah McMahan |
#7 | |
Member#: 42331
South East
#8 |
Member#: 9222
Vehicle:1995 Impreza Lw/EJ20 Silverstone Metallic- NSX |
Depending on the year of your Impreza L, you might have to spend a little more on the RS(look). If it is 97+ then all you have to do is wing, which on some is actually the same as the RS sedan. The coupe has the higher sitting wing. The hood, front bumper, and side skirts. However if you have an L earlier than 97 then you have more to change over. The lights are shaped slightly different and those need to be upgraded to a 97+ headlight. From there you either have the normal looking lights, or the crystal lights that went on the RS I believe in 99 and also onto the OBS in 99. Also the front grill will need to be changed out. This is almost a worth while upgrade as the lights are much brighter and have an overall better look. A couple things on your swap, make sure it is a AWD L. You don't have to swap over the tranny, but it might be a very good idea. If you go with the auto, they are increadibly good and are the same as the RS, but you will still want to upgrade a bit. Consult the likes of I-Speed, or Lachute as to what you will need to do the swap. The only big hurdle is the wiring which is a pain in the arse. Have fun... peace. ~Erick
| Thread Tools | |
| Display Modes | |
| 99 2.5rs -> V4 Ej20 Sti | JDMdrifter | Newbies & FAQs | 3 | 05-23-2010 06:25 PM |
| FS/WTT: '00 BRP 2.5RS USDM EJ20 swap - St.Louis | tverdek | MWSOC Private Classifieds | 3 | 08-06-2008 08:50 AM |
| FS/WTT: '00 BRP 2.5RS USDM EJ20 swap - St.Louis | tverdek | Private Vehicle 'For Sale' Classifieds | 14 | 08-06-2008 08:47 AM |
| 2.5rs to ej20 swap, what times did you trap? | erice1984 | Subaru Conversions | 32 | 06-17-2005 05:31 AM |
| wrx ---> 2.5rs muffler swap | xthexjoker | Normally Aspirated Powertrain | 1 | 06-05-2003 01:18 PM |
