Old 08-20-2003, 11:10 PM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Talking Moving Right along..
Well...the Motor got dropped in today.........
Prep work was done before hand...
A Deadbolt turbo is now installed:
Along with a up-pipe:
and a New ACT clutch:
Scooby South is offline   Reply With Quote
Old 08-20-2003, 11:11 PM   #2
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Well...all Prep work is done.....DOWN SHE GOES..
Old 08-20-2003, 11:12 PM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Some other notables...
Front Legacy turbo Crossmember:
MY New Intercooler...
All Done...
Old 08-20-2003, 11:13 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Cool Some Teasers........
what it will look like when its done...
And
Old 08-20-2003, 11:20 PM   #5
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Next ...... on the list...is to continue to wire...wire....wire....Then hopefully I can Enjoy it......Man I can't wait to get it going....
Should be pretty quick I would think...
Some notables:
-The Inspection cover on the WRX motor for the flywheel had to be removed....the RS flywheel doesn't clear it....so its gone...
-Power steering lines hooked right up...with no problems....
-Stock RS AC Compressor works...but you have to modify the Green Rails of death to get the line to clear....
Probably going to Napa to see If I can find a suitable matched radiator hose to fit the RS Radiator....The bottom RS hose works...but its still got a small kink in it...The Top is definately a no go....
More later...
Bill
Old 08-21-2003, 12:10 AM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Awesome! Wish I was that far. What splitter is that?
I don't know how you managed to do all your wires in 7 hours. I just spent 2 hours doing two connectors on my instrument cluster...
-Jon
stimpy is offline   Reply With Quote
Old 08-21-2003, 08:29 AM   #7
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Where did you buy your engine from? I'm quite impressed with the red plugs on all the openings. The only engine I've ever bought had bolts stuck in all the coolant/vacuum hoses & the TB & Turbo were fully exposed/open.
omahasubaru is offline   Reply With Quote
Old 08-21-2003, 08:52 AM   #8
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
-Jon
Jon...
The Splitter is a Bozz Speed Piece for the GC8....doesn't fit with my intercooler.....its made for the old style STi intercooler...makes me kinda mad...I was looking forward to having it...
wanna buy it????
Bill
The motor came from Import Auto Salvage is where I got my motor....90 day warranty...and yes they use all the plugs...They are simply awesome to work with....I traded my 2.5 motor and some $$$ for the WRX stuff....So I am very happy....I highly reccomend them...
Bill
Old 08-21-2003, 11:26 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
this pict might help bill
this is from an i-speed car
big version
Old 08-21-2003, 11:31 AM   #10
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Thanks Jaxx....that helps alot...
Bill
Old 08-28-2003, 05:46 PM   #11
stentorian
Member#: 12959
2008 Scion xB
I like this IC is better I think you could chop a little bigger hole in the hood and it can stick out there, hahaha!!
-Joe
stentorian is offline   Reply With Quote
Old 08-28-2003, 08:45 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Scooby South: With the Legacy Turbo cross member what Sway bar is compatible? Im currently performing an engine swap. I dont mind to order a legacy turbo sway bar from Whiteline australia but Id rather order an alternative that can be found locally
ciper is offline   Reply With Quote
Old 08-28-2003, 10:54 PM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Any turbo swaybar should work fine. I'll be using a WRX front swaybar.
-Jon
Old 08-28-2003, 11:31 PM   #14
ciper
Member#: 15543
90BJ Legacy LS ABS
Really? Thats great news. I have an NA 22mm whiteline installed in the engine swap car now.
I do trust you're right, but have you actually seen one installed before?
Old 08-28-2003, 11:51 PM   #15
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
i have the WRX wagon swaybar on my legacy turbo crossmember and it knocks a lot and the steering wheel is crooked a little. im looking into a JDM GC8 bar or just getting the legacy turbo bar.
Brent
scoobyimprza is offline   Reply With Quote
launch=Wheel hop, shifter moves right at WOT(lower gears) Mojambo Transmission (AT/MT) & Driveline 4 10-20-2009 04:06 PM
Nothing for sale here, move along Austin North West Impreza Club Forum -- NWIC 118 05-22-2004 09:02 AM
Moving Right along.. Scooby South South East Region Forum 22 08-22-2003 01:38 AM
moving along. petrol Texas Impreza Club Forum -- TXIC 3 07-03-2002 03:16 AM
