Old 08-19-2003, 02:43 PM   #1
SubaruPreza
Member#: 21579
2000 Forester
Default No ej25 engine wiring harness, what to do???
I am doing a 2000 Ej25 swap into my 94 1.8L. I have everything for the swap except for this harness. What are the other alternatives in harness's or will i have to get a 2000 rs25 engine wiring harness? is there any other options i have to choose from. wiring harness cost an arm and a leg from the dealer and they are are hard to come by from private sellers so if anybody knows other options to what i can do for a harness in my swap let me know.
thanks
Aaron
SubaruPreza is offline   Reply With Quote
Old 08-19-2003, 03:22 PM   #2
Puckaveli
Member#: 1518
00 2.5RS
What ECU are you going to use?
Do you have the engine wiring harness? There are three harnesses possibly involved in swaps; bulkhead, engine, and instrument panel.
Which dash and instrument cluster are you going to use?
Puckaveli is offline   Reply With Quote
Old 08-19-2003, 05:10 PM   #3
SubaruPreza
Member#: 21579
2000 Forester
i dont have any of the wiring harness's. I have the ecu that came with the car ( 2000 RS ECU) and i have the 2000 rs gauge cluster that came with the car. any suggestions???
Old 08-20-2003, 12:50 AM   #4
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default harness
hey- have u read my ej18-->25 conversion?
just run the EJ25 with a 1.8L ecu. it'll run fine. with the 00 SOHC motor, youll need a couple things, ask hawk296 hes done it into his 95. realistically, its not really worth the effort to runt he stock 2.5L ecu to go through al hte wiring, u might as well do the 2.0 turbo swap for that kinda effort. u can get the ej20g for about the same price as u probbbly paid for your ej25, we look at the 25 as a temporary solution tot he ej18.
anyway, PM me for more exacting details or post.
supermoose is offline   Reply With Quote
Old 08-20-2003, 08:59 PM   #5
SubaruPreza
Member#: 21579
2000 Forester
can i use my 1.8L wiring harness if i use my stock ecu?? what other parts of the harness will i need. i am pretty sure i will need a different harness for the instrument panel and gauge cluster right??. what will the differences be if i use my 94 ecu verses the 00 ecu.
Old 08-21-2003, 06:30 PM   #6
supermoose
Member#: 9093
swap starr
Default harness
hey- basically, trick the car taht it has a really frekin big 1.8L.
you'll have to use the ej18 engine wiring harness - under the intake manifold, the sensors should be the same however, the ej18 throttle body, ej18 coil packs. hawk296 's car required special custom spark plugs, youllhave to ask him or look his posts up for that one, and on the later sohc ej25's youll have to make a block off plate for the throttle body to make the correct ports happen on the 1.8L throttle body to intake manifold junction. also, if your engine was an auto, you wont need to worry about the crank trigger sensor, but if ti was a manual, youll need to swap the sensor from your 1.8L on instead. (requires removing timing belt - a tedious job)
if u need a crank pulley, i have one from my old 1.8. or if your 1.8 is toast, tear the sucker apart for it.
oil pump / water pump / thermostat/ radiator cap/oil pan/ almost all sensors are all the same for ej18 and ej25.
youll also have the splice the connector ends for the injectors to run the 2.5 injectors (i didnt bc my 2.5 was a 98)
anyway, read my post on the swap, it might make things make more sense, ro it might not.
use your stock guage cluster, and everything. just swap out longblocks basically.
the only disadvantages?
6K redline, less aggressive fuel maps, little less power-
advantages?
a mad lot of time $$$ in wiring issues.
u might as well do a EJ20 swap for that kinda hassle.
h
Old 08-29-2003, 03:03 AM   #7
SubaruPreza
Member#: 21579
2000 Forester
any other suggestions???
Old 08-29-2003, 03:18 AM   #8
atmosphere
Member#: 37641
98 Impreza 2.5 RS
atmosphere is offline   Reply With Quote
sti ej25 engine wiring harness arrowscooby Engine/Power/Exhaust 21 10-19-2008 02:01 AM
WTB: EJ25 Engine Wiring Harness Slack Private 'Wanted' Classifieds 5 12-08-2007 10:03 AM
No AWD dynos around here, what to do??? mvorchard Proven Power Bragging 19 09-13-2007 04:05 PM
O2 sensor wires gone. what to do limeylight Normally Aspirated Powertrain 1 08-25-2007 03:29 AM
No rear O2 sensor EJ257 What to do?? Please Help crazyGC8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-15-2006 11:23 PM
