#1 |
Member#: 7253
Vehicle:2002 WRX WRB |
Does anyone else have idle problems when the AC is on? Usually on a hot day the car will almost stall, cause the idle will fluctuate when i'm waiting at the light.
#2 |
Member#: 10642
Vehicle:95 Impreza EJ22T 05 LGT, 96 Outback |
Check to see that the belt tension isnt too tight.
-Jim |
#3 |
Member#: 17302
MAIC
Vehicle:2002 Impreza WRX you know... the blue one |
I would say this is normal. It's the compressor kicking on and then off again. If it's pretty hot out and it's kicking on and off quickly then it may need to be recharged with freon.
#4 |
Member#: 25187
Vehicle:'08 Foz Prem TGM '10 Challenger R/T Blk |
A little helpful advice......you may want to fill in your profile info. It helps to know what model your talking about when folks try to respond to your questions.
As far as your question, I would say it's not normal. Your car should not be that close to stalling with the a/c on. However, as DJ points out, it's normal for the rpm's to fluctuate as the compressor cycles. Does it feel really rough? Has it ever actually stalled? Perhaps your mis-interpreting the slight drop in rpm's as a near stall? - Kean |
#5 |
Member#: 7253
Thanks for all the suggestions. I loosened the belts, but I still have the idle problem. Haven't checked the second suggestion about the Freon yet. Now I have a check engine light on, hope this relates to the idle problem. Then I'll know what the problem is for sure.
#6 |
Member#: 13910
NESIC
Vehicle:1997 Legacy outback blue |
ummm like 3 weeks ago I took my 95 Impreza 1.8 out for a drive.. I was waiting at the light with the Ac on and I felt the car idle rougher then the normal Idle I see that the car was idleing under 900 Rpms.. I don't know what it was but it never stalled that day.. But it's start Rpms are crazy... You start the car it will go over 1,00 then drop to 900 then go back over 1,000.
Also My AC in my impreza cuts on and off every 24 Seconds is that Normal? In the Forester it's every 7 Seconds. |
#7 | |
Member#: 212518
kenwei@gmail.com |
#8 |
Vehicle:OK Houston we have an Uncle |
clean the MAF
| Thread Tools | |
| Display Modes | |
| Slight smoke on idle with AC on | Nathan Explosion | Factory 2.5L Turbo Powertrain | 5 | 04-14-2010 07:38 PM |
| Problems with AC and Idle! | stierzy34 | Factory 2.0L Turbo Powertrain | 2 | 05-26-2009 01:12 PM |
| AC on. AC off. AC on. | WRX Jim | Factory 2.0L Turbo Powertrain | 48 | 09-04-2007 09:45 PM |
| Hiccup @ idle w/ AC on... | Kev5n24 | Baja Forum | 17 | 07-09-2007 11:13 AM |
| Surging/pulsing idle with AC on? | Slalom RS | Normally Aspirated Powertrain | 8 | 09-11-2006 01:57 PM |
