Old 10-20-2003, 11:20 AM   #26
vile
Member#: 32371
'02 t-rex wagon
platinum
Originally posted by VetteVert
Don't have the part numbers with me. It is a package of 2 spark plug arresters (sp?). They are the "Help!" brand in the red blister packs. I seem them at all of the crappy parts stores (autozone, pep boys, advance, etc.). They are almost sealed on one end so I had to drill it out. It was also tapered down a little too small inside, so I slowly went up in size (up to 1/2" I think, will check) on the drill bit until I was satisfied. I bolted both together and into my down pipe. Then installed O2 sensor.
VV
can you pics of these spark plug arresters(package), and what you did?
i'm slow, need drawing, use crayon please, hehe
vile is offline   Reply With Quote
Old 10-20-2003, 11:25 AM   #27
VetteVert
Member#: 5961
2005 STi
Didn't take pics before I installed unfortunately. Will try and get some installed pics. Basically what the arrester is, is a male/female adaptor with one end partialy sealed. The idea is for the spark plug (with same thread pattern as O2 sensor) to screw into one end (female end obviously), and to screw the male end into the head where the spark plug would go. All I did was drill out the inside so it was larger. Screwed the male end of 1 into the female of the other, then screwed the new combo into the downpipe. This resulted in an extension with a female opening to accept the sensor. Hope that made sense...it is REALLY simple, but hard to explain
VV
VetteVert is offline   Reply With Quote
Old 10-20-2003, 12:10 PM   #28
vile
Member#: 32371
'02 t-rex wagon
platinum
one more question, which size of arrestor(anti-fouler) did you use, 5/8" or 13/16"?
Old 10-20-2003, 01:20 PM   #29
VetteVert
Member#: 5961
2005 STi
Don't remember, but I would think only 1 of them would be 18mm. I'll check for sure tonight.
VV
Old 10-21-2003, 12:22 AM   #30
WRXncrew
Member#: 39970
2008 LGT Spec.B
Quartz Silver Metalic
Default Yes, 18mm threads for rear O2
The following is the Help! part# 42002 from Motormite. This will need to be modified by drilling a 1/2" hole through one so that the O2 sensor won't bottom out. With both pieces screwed together, the length is around 2". These are the 18mm tapered part, but there is also a 18mm flat mount style part# 42009. These can be purchased from any autoparts house, like Kragen, Pepboys, etc. Any place that carries the 'Help!' Motormite brand.
WRXncrew is offline   Reply With Quote
Old 10-21-2003, 08:33 AM   #31
TopKatz
Member#: 36793
04 WRX
did you use an "elbow" with these, or just like this?
TopKatz is offline   Reply With Quote
Old 10-21-2003, 08:35 AM   #32
VetteVert
Member#: 5961
2005 STi
I used them straight out...but I used both of them. This setup looks exactly like the Godspeed design. No CELs yet.
VV
Old 10-21-2003, 08:36 AM   #33
TopKatz
Member#: 36793
04 WRX
Does the stock 3rd cat provide enuff clearance to do this?
Old 10-21-2003, 08:36 AM   #34
jamesohoh7
Member#: 39070
GTF off my lawn!
Default Re: Yes, 18mm threads for rear O2
Originally posted by WRXncrew
The following is the Help! part# 42002 from Motormite. This will need to be modified by drilling through one so that the O2 sensor won't bottom out. With both pieces screwed together, the length is around 2". These are the 18mm tapered part, but there is also a 18mm flat mount style part# 42009. These can be purchased from any autoparts house, like Kragen, Pepboys, etc. Any place that carries the 'Help!' Motormite brand.
Outstanding!, thanks to everyone who did the legwork for those of us (well, at least me!) who ain't so swift
-James
jamesohoh7 is offline   Reply With Quote
Old 10-21-2003, 08:47 AM   #35
VetteVert
Member#: 5961
2005 STi
I have no idea...I'll try to snap a shot of what it looks like on a Helix pipe to see if that will show how much clearance there is.
James: there's your part #s (I lost my blister pack)
VV
Old 10-21-2003, 08:52 AM   #36
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
interesting information. the autozone down the road from me sells help brand, i'll have to pick up a pack.
spankaveli is offline   Reply With Quote
Old 10-22-2003, 10:14 PM   #37
johnny 555
Member#: 8003
2002 WRX sedan
WR blue
I picked up a pack today. Do I need to use something like
loc-tite when installing?
-john
johnny 555 is offline   Reply With Quote
Old 10-23-2003, 01:32 AM   #38
blaznasn
Member#: 6750
you don't really need to, but it couldn't hurt.
blaznasn is offline   Reply With Quote
Old 11-02-2003, 01:02 PM   #39
TopKatz
Member#: 36793
04 WRX
I made an elbow type extendor, my CEL came on last night after 50miles.
Old 11-02-2003, 02:54 PM   #40
s_nold
Member#: 22649
2008 Spec.B
perhaps it made your sensor too far out of range in the other direction...?
VetteVert-
How big is the hole you drilled out to?
so far I have only drilled it out to 3/8" and I haven't had a chance to install it yet, and find out if it is wide enough.
s_nold is offline   Reply With Quote
Old 11-02-2003, 02:56 PM   #41
TopKatz
Member#: 36793
04 WRX
Old 11-03-2003, 02:32 AM   #42
WRXncrew
Member#: 39970
2008 LGT Spec.B
I've been running my CEL fix now for over 900 miles, no CEL even after driving on the freeway (always used to get CEL P0420 on the freeway).
The mod needs a half inch hole drilled completely through one, but keep the other spark plug non-fouler as is. NO elbow needed. You should clear all CELs after installing. I'm using the 42009 as a base (non tapered and has the washer), and the 42002 with the 1/2" hole drilled straight through.
If you get a CEL, it could be something other than the P0420 which is the rear CAT inefficiency code.
Old 11-03-2003, 07:49 AM   #43
VetteVert
Member#: 5961
2005 STi
1400 mi. here and no CEL yet...
I drilled mine out to 1/2"...that leaves just enough room for some exhaust to get to the sensor.
VV
VetteVert-
Old 11-05-2003, 02:45 PM   #44
WRXncrew
Member#: 39970
2008 LGT Spec.B
I'm curious to know if anyone here is using this fix on their '04 WRX or STI.
Old 11-05-2003, 02:57 PM   #45
spankaveli
Member#: 42826
1999 Toyota Corolla
Tan
VV
agreed. 3/8 isn't enough. 1/2 is the smallest that'll work.
Old 11-22-2003, 01:40 AM   #46
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
good stuff - will be looking into this tomorrow
CirrusWRX is offline   Reply With Quote
Old 11-24-2003, 11:23 PM   #47
R.C.Y.K.
Member#: 10389
so VetteVert or WRXncrew, is that i need both 42002 and 42009 to finish or i can just use the 42002?
R.C.Y.K. is offline   Reply With Quote
Old 11-24-2003, 11:23 PM   #48
R.C.Y.K.
Member#: 10389
Old 11-25-2003, 12:01 AM   #49
Eskram
Member#: 16697
2004 2.5 Hybrid 18g
Wagon + LGT 1-4 g00dness!
I'm not sure if it would work or not with teh WRX (I have an electronic CEL fix or I'd try it), but when I had my catless Integra, I wrapped the rear O2 sensor in aluminum foil and zip tied out of the way. Never got a CEL in over 9k miles...
Eskram is offline   Reply With Quote
Old 11-25-2003, 01:12 AM   #50
s_nold
Member#: 22649
2008 Spec.B
You only need one or the other...there is a small difference in them, I can't remember exactly what it was...they should be next to each other...and if I recall...it is somewhat obvious what the difference was from one to the other... Make sure you get two of either one...and you will have to drill out the center so that the O2 sensor will fit...The MINIMUM diameter of the hole should be NO LESS THAN 1/2" you will have to drill both peices out for everything to fit.
mechanical rear O2 CEL fix sesjptj Private 'For Sale' Classifieds 0 08-08-2005 12:03 PM
FS: Mechanical Rear O2 Sensor Fix spankaveli Private 'For Sale' Classifieds 75 03-02-2004 06:55 PM
Mechanical Rear 02 CEL Fix fliz Private 'For Sale' Classifieds 6 02-04-2004 01:18 PM
Non-permanent mechanical rear O2 CEL fix yjack Private 'For Sale' Classifieds 10 11-25-2003 11:09 AM
Rear O2 CEL Fix Thumper23 Private 'Wanted' Classifieds 4 11-07-2003 03:44 PM
