Old 10-30-2003, 10:01 PM   #1
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Exclamation Downpipe FAQ: Read if you are thinking of buying one!
Downpipe FAQ
The primary purpose of an aftermarket downpipe is to remove or replace the stock catalytic converter with a better flowing unit. It also increases the exhaust diameter for better flow.
HP gain is 15-20HP. This figure is highly debated as different manufacturers use different dynos with different cars with different levels of mods. It also varies because some downpipes use one high flow cat, while others are catless and actually extend far enough back to eliminate the 3rd cat as well.
I have an 06/07 WRX, is the downpipe the same? No. The 06/07 WRX has a unique exhaust in that it's downpipe is both the downpipe and catpipe sections of the "older" exhaust. This means you must use a "long" downpipe to bolt up to the rest of your exhaust system. A full TBE will fit fine, but when replacing just the downpipe, you must use a long downpipe.
I have an 08+ WRX, is the downpipe the same? No. The 08+ WRX has a unique exhaust in that it's downpipe is the same, fitment wise, as the Legacy GT. So if you have one of these models, you must ensure you state your model/year to your vendor or specifically request the "Legacy GT downpipe" for your car in order to assure proper fitment.
Which manufacturer is best? This topic is highly debated. There have been no reported consistent "bad" downpipes on the market. Obviously, there may have been bad pipes sold, but not enough to report as "bad" overall.
Who manufactures downpipes? The NASIOC user fliz has kindly started a downpipe chart that lists all the downpipe manufacturers and lots of comparative data. fliz's downpipe chart.
What downpipe metal material is best? Downpipes are made from mild steel and stainless steel (304 & 321). There is no irrefutable evidence that one material is better than the other. Obviously, corrosion levels are higher with mild steel (coated or otherwise). Article on exhaust materials.
Which downpipe construction method is best? Downpipes have 4 main construction methods:
1. Blank plate: Identical to stock construction with the wastegate portion completely covered.
2. Bellmouth: Completely open design.
3. Split bellmouth: Similar to bellmouth only with a divider inserted to separate the wastegate.
4. Divorced or Twin Dump: Separate exhaust and wastegate piping that connect further downstream.
There is no irrefutable evidence that one design is better than the other. The thought process is that the greater the separation there is between the wastegate gases and exhaust gases, the smoother the overall exhaust flow.
Which downpipe construction method is least expensive? Generally, the blank plate design is the least expensive. The other designs, depending on manufacturer, are all around the same general price range.
Can I gut my downpipe like people do their uppipe? Yes. Scoobymods.com directions. Others have used a 2 foot section of bent rebar and a hammer and reported the de-catting process takes 30 minutes total if the scoobymods directions seem too labor intensive.
Can I use an STi downpipe? Yes. There is very little difference between the STi and WRX downpipes though. Using the STi downpipe is fine, but do not consider it a significant upgrade. Differences in HP between the two are likely to be very tiny (5HP or less is a guess) and not worthwhile.
What other differences are there with downpipes? The other differences are as follows:
1. High flow cat or catless.
2. Overall pipe diameter. Sizes range from 2.5, 3.0, and 3.5 inches. 3.0 and 3.5 are generally only necessary for higher (300-400+ HP) applications.
3. Length of downpipe, some are stock length and others are longer to remove the 3rd cat.
4. Propietary length. Some have manufacturers have unique lengths or are JDM length which requires manufacturer specific length or JDM specific length components after the downpipe.
5. Flanges. Some are manufactured with a donut gasket and some with a flat flange, the end user needs to research what bolts up to what before purchasing.
Which downpipe has the best gains? There is no irrefutable evidence that any downpipe has better gains than another. The consensus, if there is one, is they are all within 5HP or less, gain wise, of each other.
Are there any downsides to downpipes? There have not been significant amounts of problems with downpipes. There have been some reports of wastegate issues with split bellmouth and divorced or twin dump downpipes. These type of downpipes have a "splitter piece" that juts into the turbo to separate the exhaust from the wastegate. Sometimes this piece is too long and requires some slight cutting or grinding for a perfect fit. The telltale sign of this occurrence is less than full boost or irratic boost upon installation. As with any aftermarket part, even "perfect" ones, sometimes you run into a rogue issue. From research, this is not a widespread issue at all, only an advisory if this situation should occur.
Where do I buy a downpipe? Every Subaru/Import performance store sells downpipes. For purchasing, support your local economy or the NASIOC Vendors.
What is some good background information about exhaust pipe fitment?
Generally speaking, there are two types of catbacks:
Type 1: It has a sliding flange designed to bolt up to the stock downpipe.
Type 2: It has a flat flange designed to bolt up to 3" downpipes.
Generally speaking, there are two types of downpipes:
Type 1: It is designed to bolt up to the stock catback and other type 1 catbacks.
Type 2: It is designed to bolt up to only type 2 catbacks.
Type 1 catbacks do not bolt up well to type 2 downpipes, and type 2 catbacks do not bolt up well to type 1 downpipes.
Type 1 catbacks and downpipes taper to 2.5" where they meet.
Type 2 catbacks and downpipes are full 3".
Type 2 downpipes are usually less expensive than type 1 downpipes.
Type 1 and 2 catbacks are relatively similar in price.
All 2.5" catbacks are type 1.
Some 3" catbacks are type 1, and some are type 2.
What questions should I ask of the retailer or manufacturer before purchasing?
1. Will this unit mate up to the rest of my exhaust? Some downpipes will fit the stock exhaust, or must be fitted to a larger exhaust.
2. Will this unit throw a CEL? Some do, some don't, so find out beforehand.
3. Does it come with new gaskets? It is always a good idea to replace exhaust gaskets.
4. Does it come with a CEL fix if needed and is it the right one? In the case of the electrical fix, there are two unique fixes, one for the 02/03 and one for the 04. The 05+ does not currently have an electrical fix.
How hard is it to install a downpipe? Allow around one-two hours for install time. Professional installation, depending on your area, is around $75. This is one vehicle modification that is very simple and can be successfully accomplished by even the greenest shade tree mechanic.
What is that rubber hose on the lower rear firewall that is near my downpipe? That is the AC drain line. Move it out of the way of your new downpipe by moving the mounting tab, loosely zip tieing it out of the way, or by trimming it. Do not zip tie it closed as it needs to drain and do not trim is flush or near flush with the firewall as it will pop inside the car and drain into the passenger wheel well. Replacement of this drain line is said to be a real bear, so ensure you do not over trim it. People have not taken steps with this and it has melted on it's own due to the downpipe heat, but there's no reports of catastrophic fire as a result. This does not give you license to just let it "melt to fit" though, just a comment for people that have missed the fix and have noticed a melted tube.
How do I install a downpipe? Refer to the downpipe manufacturer's instructions. For downpipes without instructions, below are links to some of the better known downpipe installation instructions:
TurboXS's Instructions
Perrin's instructions
Scoobymods.com instructions
Cobb instructions
Keep in mind that the short black rubber hose on the passenger side side of your fire wall is the AC drain line. It's best to ensure that it is routed away from your new downpipe to ensure it properly drains and does not melt onto your downpipe. It can drip onto your downpipe and this causes no reported problems if you choose to cut it short and allow it to drain on the downpipe itself. Though not the best route, this is mentioned as a possibility.
What about ceramic or other heat wrap coating? Though there are pros and cons to heat retention treatments with exhaust components, the general consensus with headers is that heat retention benefits outweigh the liabilities.
Pros:
Increased heat retention, which is beneficial for exhaust flow.
Reduces underhood temps, which decreases IC heatsoak.
Cons:
Additional expense.
Additional lead time, in the case of coatings.
Increased heat retention, which in some cases, can accelerate metal fatigue, especially at weld joints.
No proven HP increase.
If you plan on using a coating, ensure you are aware of what impact this will have on your header warranty if applicable. Coating or wrapping your header can void exhaust component warranties. If using a ceramic-type coating, ensure it's working heat range is above the known EGT. EGTs can be as high as 1400-1600 degrees in the extremes. Some normal coatings are not rated to this temperature level.
What types of ceramic or other heat wrap coating are available? The two most popular manufacturers of heat wrap are Thermo Tec and DEi. The two most popular coating manufacturers are Jet Hot and Swain Tech Coatings. Wrapping is a DIY project with a shorter life span than the professional only coating with a longer life span.
Excellent coating thread
.pdf file on coatings
Car Craft magazine's testing of Jet Hot
What is the CEL fix? It stops the rear CEL code P0420 Catalyst System Efficiency Below Threshold from appearing, this code being caused by the lack of a catalytic converter in the exhaust. This is usually fixed with a Pony Express MIL Eliminator (no longer in business), Casper Electronics fix, or Perrin Performance fix. The 05+ does not currently have an electrical fix. Another fix is the mechanical fix, which works on all models. ***NOTE*** There are two CEL fixes for the WRX, the other one is the 2.2 KOhm 1/2 watt resistor. It is used to combat the CEL code P0546 = Exhaust Gas Temperature Sensor Circuit Malfunction (High Input) in the uppipe. This notice, though not important to this thread, acknowledges there are two "CEL fixes" and defines them individually to avoid possible confusion.
Many aftermarket engine management systems can also be used to prevent the CEL light from showing up.
Which is the best CEL fix, mechanical or electrical? Both work fine, though personnel living in states with OBDII testing prefer the mechanical fix. The reason for this is during state mandated OBDII testing, the electrical fix can show up as a malfunctioning sensor. For some states, this one malfunctioning sensor is fine, for others, you will have to fix it and return. In the end, the mechanical fix is cheaper and easier for most users.
Can I drive around with a P0420? Yes. This is not a code that will throw your car into limp mode, so you can drive normally with it until you get a CEL fix. It's never wise to do so though as a CEL is easily seen by police who may then do a "safety inspection" as well as cause issues during any local emissions testing.
Do I need engine management with a downpipe? For 02/03 WRX and 04-06 STI users, no. For 04+ WRX and 07+ STI users, it's pretty much a requirement as the open loop/closed loop fueling issue mandated by the EPA causes long term reliability problems with using a downpipe and no tuning. For STI users, the STI was the one exception manufacturers are allowed to have, but it's a wise move regardless as the STI and 06+ WRX users have a good chance of boost creep occuring with downpipe use. Tuning can ease this issue, but the cause/effect/cure of boost creep can be researched via this link.
Should I reset my ECU after this mod? It is never a bad idea to perform an ECU reset after a mod. The traditional route is to disconnect the negative battery terminal, press the brake pedal for a few seconds to bleed the system of charge, and reattach. Some use the more advanced Vishnu Reset.
What about emissions problems like emissions tests and legality? Using a catless downpipe is a violation of section 203 of the Clean Air Act. Each state has statutes that cover this subject as well. As far as passing state emissions tests, as long as you still have one cat in your system, you should be fine unless you run into a sharp-eyed and knowledgeable inspector who knows there should be two in the main exhaust. The exhaust should be properly warmed prior to any testing to ensure it is operating efficiently. Another smart move is to find someone in your local area with the same set up to compare notes. Seek out locals via the NASIOC Chapters or NASIOC Regional Areas. A nice article on cat testing can be found here.
Editors Note
This post was created because I wasn't able to find a good downpipe FAQ. I came up with the text based on LOTS of searching here. It was also created to be intentionally brand neutral so that it serves as a stepping stone for further research. Upon reading this you should have an idea of what type of downpipe best suits your needs. The manufacturer is up to you.
If you find an error in this FAQ, please PM me with factual details and I will update this post. Responses such as, "I have XXX's downpipe and it's great!" or "XXX's downpipe leaked after 1 month" are not appreciated here, that is what the Car Parts Review Forum is for.
Old 10-31-2003, 12:20 AM   #2
Rentalpillow7
Member#: 42141
Wow you know u'r estoff mayn
perhaps discuss the prices between the blank plate, bellmouth, split bell mouth and divorced. eg (blank plate is cheapest for the most part)
Rentalpillow7 is offline   Reply With Quote
Old 10-31-2003, 03:37 AM   #3
ShotgunTC88
Member#: 30970
Thanks Una,
For the time and research.............Appreciated
Shotgun
ShotgunTC88 is offline   Reply With Quote
Old 10-31-2003, 07:51 AM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thank you very much for the input. I did a little research and did find that though there aren't too many blank plate manufacturers, the cost of these type of downpipes was considerably less than the others. The other types of downpipes go all over the price spectrum without regard to design. The text has been edited to reflect this significant difference as it could be a key factor towards someone's decision.
Old 10-31-2003, 09:01 AM   #5
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Just gotta say thanks for the great writeup. I wouldn't mind though if someone did an addendum to it with all major makes and models of downpipes. Now if we could only get something that looks this good for exhausts.
Thanks Una,
offset
offset is offline   Reply With Quote
Old 10-31-2003, 10:29 AM   #6
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I promise you an exhaust FAQ will be on the way in due time. The harder the subject, the more research I must do to make an accurate FAQ. The exhaust portion will take probably 2-3 times as much research as this downpipe on did and I seriously worked on it for 4-6 hours. Exhausts are more complicated as they fall into cat back, turbo back, and axle back stages. I may have to do three independant FAQs along with a bland overall exhaust FAQ to highlight the key points. We shall see though.
I did think of a brand/type index of downpipes. The only problem with this is I want to be as brand neutral at all times so I don't seem like I am pushing one or the other. Plus everybody and their brother makes downpipes! I will probably have to push brand neutrality aside for the exhaust FAQ though as I intend on doing this for people who want the "loudest" and "quietest" exhaust as the sound is probably the number one factor for most people during their purchase decision process.
It would be nice for someone to index all the downpipes though. Any takers? If so, please make a new thread.
Old 10-31-2003, 01:46 PM   #7
escher
Member#: 31173
2003 WRX Sport Wagon
One hell of a writeup.
Thanks.
escher is offline   Reply With Quote
Old 10-31-2003, 07:53 PM   #8
kdmd2b
Member#: 6670
2002 WRX Sedan
WR Blue
Good info but don't you mean that there is no irrefutable evidence. There is plenty of evidence that could be refuted (heresay, circumstantional, ect).
kdmd2b is offline   Reply With Quote
Old 11-02-2003, 09:26 PM   #9
MRBLVD
Member#: 42039
MRBLVD is offline   Reply With Quote
Old 11-23-2003, 01:20 AM   #10
STi City
Member#: 43327
bellmouth and divorced are the way to go. Get one that will replace your last cat so you can kill two cats with one stone.
STi City is offline   Reply With Quote
Old 03-31-2004, 06:51 PM   #11
fliz
Member#: 30342
I took a shot...
http://forums.nasioc.com/forums/show...hreadid=532132
fliz is offline   Reply With Quote
Old 03-31-2004, 08:28 PM   #12
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
There is also the Mechanical O2 fix for the rear o2 sensor. It's really cheap too!
SupaSizeFries is offline   Reply With Quote
Old 04-01-2004, 12:59 AM   #13
uptownWRX
Member#: 34289
2004 STi
Very good FAQ
uptownWRX is offline   Reply With Quote
Old 04-01-2004, 10:08 AM   #14
biGRed
Member#: 30826
now do one for up-pipes
biGRed is offline   Reply With Quote
Old 04-01-2004, 10:11 AM   #15
fliz
Member#: 30342
You mean like this?
Old 04-01-2004, 01:16 PM   #16
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
thank you Mr. Unabomber for doing such a complete write up!
You are truly The Man
cky211 is offline   Reply With Quote
Old 04-02-2004, 10:05 AM   #17
ITWRX4ME
Member#: 24472
2001 Miata
Thanks, Unabomber!
Is this stickied yet? Or at least referenced in the FAQ thread.
Edit: Why, I see that it is. Note to self: Look first, ask questions later.
ITWRX4ME is offline   Reply With Quote
Old 04-02-2004, 10:45 AM   #18
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
^^ And you call yourself a specialist.
j/k man
mbiker97 is offline   Reply With Quote
Old 04-02-2004, 08:45 PM   #19
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Una - your FAQ's have been very helpful. We all appreciate your time and effort!
WRXRallyBlue is offline   Reply With Quote
Old 04-03-2004, 07:54 PM   #20
MBPEJ20
Member#: 24360
2002 WRX Sedan
awesome faq
MBPEJ20 is offline   Reply With Quote
Old 04-03-2004, 11:08 PM   #21
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
Originally posted by AznBoy1der
awesome faq
bezerk is offline   Reply With Quote
Old 04-04-2004, 10:43 PM   #22
Drav
Member#: 52713
2004 WRX (black)
2000 RS (red)
Does the stock STi downpipe have a cat or no?
Drav is offline   Reply With Quote
Old 04-04-2004, 10:59 PM   #23
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yes, one in the downpipe, one in the midpipe. Two total.
Thanks for the kind words folks!
Old 05-10-2004, 05:52 PM   #24
2004STiGuy
Member#: 53335
2004 Impreza WRX STi
WR Blue Pearl
same comment on downpipe as for uppipe...
how about a discussion of what it is and does in addition to the good info on reasons for replacement.
2004STiGuy is offline   Reply With Quote
Old 05-10-2004, 10:08 PM   #25
kool168
Member#: 61006
if i replace the aftermarket downpipe and run catless exhaust, will it cause boost creep?
but i am not gonna put the TBE, all i want is just replace the downpipe with no cats in STI...
kool168 is offline   Reply With Quote
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 382 08-24-2016 02:10 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 116 08-01-2016 10:03 PM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 303 06-14-2016 10:03 PM
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 88 02-02-2015 10:10 PM
