Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 11-01-2003, 04:36 AM   #1
dugrant153
Member#: 22505
1985 Old
Rusty
Post OBS Impreza okay for autoX?
Was looking at Impreza Brightons for a while when I noticed that even OBS Imprezas can look nice and as 2-tone wagons
I was wondering... what the differences were? And if the OBS isn't "too high" for autoX? Thanks.
dugrant153 is offline   Reply With Quote
Old 11-01-2003, 07:30 PM   #2
Matt
Allergic to turbos
Member#: 181
2009 Forester
'09 ImprezaGT '04Frontier
No...its fine for autocrossing. Sometimes it also comes to your advantage. For instance, my RS with the 2.5 motor is considered G stock or STS with the few items I currently have. However, our bugeye OBS is classified as H stock even though it has the same engine/drivetrain. Often this allows us to run the car in a class with little competition or other cars that have less power. Also, if you're looking at a pre-2002 model, many of the parts from the RS are interchangeable across the Impreza model line.
I'd recommend a second set of wheels with some Azenis or Kumhos and maybe a set of KYB-AGX struts and go nuts. You'd be suprised how well the car will do.
Matt is offline   Reply With Quote
Old 11-03-2003, 07:08 AM   #3
OhBe1
Member#: 45760
06 LOB5MT,LGTbits
OB
If Rangers & Tacomas can AX, an Outback (any flavor) can AX.
OhBe1 is offline   Reply With Quote
Old 11-11-2003, 01:25 AM   #4
dugrant153
Member#: 22505
1985 Old
Rusty
Is the ride height really THAT high??
Old 11-14-2003, 06:17 AM   #5
OhBe1
Member#: 45760
06 LOB5MT,LGTbits
OB
Our old Ranger was definitely taller than our LOB - and with a much inferior suspension (twin I-beam front), and I know of one that was AX'd ( few issues back in GRM); we never did ours. And our new Tacoma is taller, but from the customtacos forum, I know of a couple that are ax'd.
Our late & much lamented Mazda b2200, OTOH, was actually lower than the Outback - even before we lowered it.
Old 11-19-2003, 12:39 AM   #6
dugrant153
Member#: 22505
1985 Old
Rusty
What IS the difference between the OBS and the 2.5RS (in terms of ride height)...
and is it the springs that cause the increased ride height? or the shocks? or both?
Old 12-02-2003, 09:58 AM   #7
Rally Medic
Member#: 28249
1998 Outback Sport
Dirty with some mud flaps
both .
Rally Medic is offline   Reply With Quote
Old 12-04-2003, 02:54 AM   #8
dugrant153
Member#: 22505
1985 Old
Rusty
What are the specs for the springs and the shocks?
Like, are the springs WAY WAY softer than the 2.5RS springs?
Are they bigger?
Could I just change the shocks and make the ride a lot better?
Old 12-07-2003, 02:50 AM   #9
dugrant153
Member#: 22505
1985 Old
Rusty
Are the springs really soft?
Cuz was wondering what kind of affect the KYB-AGX struts would do to a car with that kind of ride height?
Old 12-07-2003, 11:59 AM   #10
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
The OBS has taller springs, I think, and is it easy to get the correct , higher rate, springs in the after market? Sure lowering by a little would be OK but too much and I think drivetrain wear can accelerate.
My concern is, for a future purchase of an OBS, if I want Konis or KYBs with new springs anout 15%-20% stiffer than stock, can I find some that DO NOT lower by more than -say- 3/4" or so? I plan to do a little lowering with smaller diam. tires. Sedan or coupe aftermarket springs may be WAY lower and I wouldn't want that.
Carl
1 Lucky Texan
1 Lucky Texan is offline   Reply With Quote
Old 12-10-2003, 12:58 PM   #11
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Carl-
As soon as you buy that new suspension setup, email me about buying your old shocks and struts. I've been looking for some outback suspension, and an excuse to visit TX again
Streetman is offline   Reply With Quote
Old 12-10-2003, 02:51 PM   #12
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I'll probably be all over the boards when that happens, looking for STI/WRX takeoffs, recommendations d\for parts , etc.
I'm hoping I can get a vehicle firts 2-3 months next year. Just can't do anything sooner.
I'll probably have some stuff to sell too - so, no problem!
Carl
1 Lucky Texan
Old 12-10-2003, 03:13 PM   #13
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Carl-
I PM'd you on that.
Old 12-16-2003, 01:55 AM   #14
Paisan
Tri-State Track Instructor
Member#: 197
'14 Touareg TDI '14
BRZ http://48hrs.info
Springs are the same as the L or 2.5RS not sure which, it's not the springs that are higher, it's the spot on the strut where the lower mounting bracket is located. That is what gives it it's raised stance IIRC.
I've successfully auto-x an OBS Automatic
-mike
Paisan is offline   Reply With Quote
Old 12-16-2003, 02:45 AM   #15
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
No shi.....kidding? Is there anywhere I can confirm that? What about the struts? I thought they were beefier. No?
Old 12-16-2003, 02:56 AM   #16
dugrant153
Member#: 22505
1985 Old
Rusty
A higher lower mounting bracket?! really?? I thought it was the springs or different struts.
Sooooo... if I were to get KYB AGX struts (or even just 2.5RS struts), which probably has a lower mounting bracket, I could go back to 2.5RS or Impreza L ride height (lower)?
Show me the monkey!! hehehehe
sweet
Old 12-16-2003, 10:21 AM   #17
Paisan
Member#: 197
'14 Touareg TDI '14
Yes, the struts basically have the lower mounting further down the strut, so if you got yourself a set of 2.5RS AGXs or 2.5RS stockers, it would drop you down to 2.5RS height. Personally? I'd get a set of eibach Prokit springs and AGX struts. That's what I run on my '96 Impreza L for Track and Auto-x. Good fun.
The OBS we ran was a '99 when both my buddy and I couldn't get a car for auto-x we took his mom's, threw on some R compounds and were good to go. I'll look for the pic I have online somewhere of it!
-mike
Old 12-16-2003, 01:41 PM   #18
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
So the spring is the same, what about the strut?
Old 12-16-2003, 04:58 PM   #19
Paisan
Member#: 197
'14 Touareg TDI '14
The spring may have a different spring rate, but the length is the same. Strut is different (lower mounting bracket is different) and valving may be different from RS to L to OBS. Physically they are the same dimensions however.
-mike
Old 12-17-2003, 01:38 AM   #20
dugrant153
Member#: 22505
1985 Old
Rusty
So if we were to add 2.5RS struts to the OBS, we'd get a softer ride because of the less stiffer springs, right?
Old 12-18-2003, 10:57 AM   #21
Paisan
Member#: 197
'14 Touareg TDI '14
I'm pretty sure the OBS and the RS have the same spring rates, if anything the RS would be stiffer than the OBS.
-mike
Old 01-15-2004, 07:47 AM   #22
Rally Medic
Member#: 28249
1998 Outback Sport
stick to Rally X.. i love mine
WTB: PSM hatch for 02-03 WRX/OBS/Impreza wagon 2.5_IMP NWIC Private Classifieds 0 06-04-2009 08:14 PM
Impreza RS/WRX/TS/OBS Turbo Parts For Sale HndaTch627 Private 'For Sale' Classifieds 24 10-30-2004 02:02 PM
For those with 93-01 OBS/Impreza Wagon's 2pt5RS South East Region Forum 7 07-26-2004 02:07 AM
WTB: 2 used hubcaps / wheel covers for 1999 OBS Impreza jburk Private 'Wanted' Classifieds 3 03-30-2004 04:30 PM
Need help from OBS / Impreza Owners in ATL Dave Hardy South East Region Forum 4 05-18-2001 08:57 AM
