Go Back   NASIOC > NASIOC Archives > NASIOC Archives > WRX Forum Archive
Old 02-21-2001, 02:50 PM   #1
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post "Up-Pipe" cat replacement info?
Sorry if this was covered before( did a search but didn't find anything specific).
I just recieved the new Hyper Rev " New Impreza STi Perfect Guide", and noticed a shot of a factory up pipe with the cat in it that had a O2 sensor right between the cat and the turbo( ), obviously making it difficult to simply throw in a "test pipe" for those who desired to do so.
I was curious if any of you that crawled under the Impreza here in the US noticed the same O2 sensor( can't see why we wouldn't get one).
Shik is offline
Old 02-21-2001, 06:27 PM   #2
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
The same O2 sensor will be there, Rallispec has plans for a replacement pipe.
Ken
DeliciouSpeed is offline
Old 02-21-2001, 07:57 PM   #3
XT6Wagon
Member#: 524
04 STi
Post
Uh, its not hard at all to move said O2 sensor to behind the turbo, while you are removing the cat. They do after all put in O2 sensors in custom exaust pipe every day at exaust shops across the nation.
XT6Wagon is offline
Old 02-22-2001, 12:06 AM   #4
Shik
Member#: 132
2015 WRX 6spd CWP
Post
Uh, you missed my point entirely. It doesn't matter where you put the O2 sensor. Being that the first 02 sensor is right after the first cat( which many have expressed a desire to replace with a test pipe such as RalliSpec's which to my knowledge does not include a cat),if the cat is removed, the readings from the O2 sensor are obviously going to be different, thus possibly causing a "check engine" light.
In the various disscussions involving fitting a "test pipe" in place of the OEM cat-fitted up pipe, I did not see any mention about the O2 sensor that is monitoring the performance of the first cat that everyone wants to delete.
I wasn't asking because I didn't know where the O2 sensor would be mounted after the OEM pipe was gone. Jeeze man, I did have a few exhaust systems made in the past.
Shik is offline
Old 02-22-2001, 08:14 AM   #5
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Post
I sure hope there is a work-around for those cats. I don't want my CE comin' on.
Brahmzy is offline
Old 02-22-2001, 09:25 AM   #6
j00z
Member#: 3801
'02 WRX
WR Blue
Post
check out the O2 sensors on the pics I took:
http://www.i-club.com/ubb-files/Foru...ML/000686.html
j00z is offline
Old 02-22-2001, 01:38 PM   #7
Tuning Factory Inc.
Vendor
Member#: 3600
Post
I will be producing crossover and downpipes with provisions for the O2 sensor. I have a solution to the problem. Now I just need my car to take the mold. I do this for the Honda folks who run test pipes. It's not a hard thing to solve when you think about it.
Tuning Factory Inc. is offline
Old 02-22-2001, 01:51 PM   #8
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
Mr G, won't call you god. But hey, have you manged to pull a cat on a stock ECU 96 up honda without the ECU going nuts? Or maybe I read you wrong.
Ken
Old 02-22-2001, 11:48 PM   #9
GDA
Member#: 4324
02 GDA
Platinum
Post
I did a Header swap on a 1996 Civic Dx, which has the cat built on to the header at the mid way of the block (4 primaries dump into cat at the top of engine). I swapped that out with a 92-95 style DC 4-2-1 header and put aftermarket 92-95 style cat on the bottom of car (normal area for most cars), and had new o2 fitting welded, no problems, no CE lights either, but my conversion is a bit different.
GDA is offline
Old 02-23-2001, 03:00 AM   #10
Shik
Member#: 132
2015 WRX 6spd CWP
Post
That is a bit different since the WRX has three cats and most people wanted to get rid of the first cat in the up pipe and the second one in the downpipe and then put a hi-flow cat in the mid pipe. Surely if you move the O2 sensor from the up-pipe all the way back to after the cat in the mid-pipe, the readings would be a bit off and would probably still cause a check engine light.
Of course, there is always the chance that deleting the cat in the up-pipe will do nothing for performance, in which case this topic wouldn't matter at all.
Shik is offline
Old 02-23-2001, 06:13 AM   #11
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
EJ, the DX is different, does not have two O2s. And the 96 was the easiest to get away with for all Hondas anyway.
Ken
Old 02-23-2001, 06:41 AM   #12
Simon Lines
Member#: 1540
92 JDM GC8 WRX
2004 2.5 twin scroll 6MT
Post
Guys
Removing the cat (or reducing its effectiveness) WILL cause a check engine light (on the EU model)
Cheers
Simon
Simon Lines is offline
Old 02-23-2001, 09:35 AM   #13
j00z
Member#: 3801
'02 WRX
WR Blue
Post
AFAIK, all OBDII cars have 2 O2 sensors. One before the cat, one either in or after the cat. This was a change in the OBD system that had aftermarket tuners up in arms.
Replacing the one before the cat is nothing. It's when they are after or in the cats that's the tricky part.
j00z is offline
Old 02-23-2001, 10:35 AM   #14
zetecdan
Member#: 3729
Post
we will also be working on a replacement pipe as soon as the car comes in. From my experience with o2 sensors and workarounds, it shouldn't be that big of an issue. worst case scenario, we'll have a superchip made for the car (if possible) that will take the pipe into account, so the CE light doesn't come on.
dan
zetecdan is offline
Old 02-23-2001, 10:43 AM   #15
WRXRob
Member#: 3087
Post
How many O2 sensors does this exhaust have? It seems to me that if it only has two, you should be able to slap on in front of and one behind any cat in the system and everything would be alright. I find it hard to believe Subaru would have put in 4 or 5 O2 sensors to monitor all 3 cats.
WRXRob is offline
Old 02-23-2001, 05:35 PM   #16
BoostFreak
Member#: 4432
Post
On my 99 Regal GS, as with all OBD-II vehicals, there are also 2 O2 sensors. One in the downpipe, and one after the cat. It's there to check the efficiency of the cat. When I eliminated my cat, I installed a O2 spoof made by www.Casperselectronics.com . It worked flawlessly for my GS, but I don't know if it'll also work for the Subaru....
I'm about to sell my GS, and just put the cat back on. I was supposed to sell the spoof to a buddy, but I'll hold onto it and test it on the WRX.
BoostFreak is offline
Old 02-23-2001, 10:41 PM   #17
Steve Theodore
Member#: 3737
2007 WRX STi
Crystal Gray Metallic
Cool
Is this "spoof" you're referring to the same thing as an O2 simulator? I've heard of those being used on OBD-II cars to fool the ECU when cats are removed.
Steve
Steve Theodore is offline
Old 02-24-2001, 12:30 AM   #18
BoostFreak
Member#: 4432
Post
Yep, O2 sim is another name for it. Luckily I only had one cat on my GS. I can't believe the Sub has 3! Lots of room for improvement.
Old 02-24-2001, 03:08 PM   #19
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
G-man you are the Shizz you know. I to, love the apex power FC, I hope they don't take to long to make it available, I may just get the link, it will be available very soon.
Keep us posted on the availability of your toys,
TIA,
Ken
Old 02-24-2001, 03:27 PM   #20
Shik
Member#: 132
2015 WRX 6spd CWP
Post
G, as far as the JDM Imprezas go, the picture in the New Hyper Rev with the up-pipe cat and O2 sensor was of a JDM car, and I recall SCC stating that all WRXs world wide will have three cats. So as far as sensors monitoring the cats, it seems everyone will have a bit of working out to do.
I also recall Brett Middelton from MRT stating that the new Imprezas are a bugger for fitting aftermarket exhausts due to O2 sensors and their placement on the new cars.
At least we will have the whole world working on a solution( if there is indeed a problem, as I mentioned before)
Shik is offline
Old 02-24-2001, 09:20 PM   #21
GDA
Member#: 4324
02 GDA
Platinum
Post
Deliciouspeed the 96 civic dx did have 2 O2 sensores (obd2), and it isnt/wasnt the easiest of hondas to do that with.
non odbs are the easiest
yes WRX's are different i realize that.
GDA is offline
Old 02-25-2001, 12:29 AM   #22
Tuning Factory Inc.
Vendor
Member#: 3600
Post
Yes I can make any OBD-II test pipe and downpipe but only make them for Hondas now. I use a piece of a small cat to fool the O2 sensor into thinking the cat is still on. Pretty simple solution and cheap of course. No need to fool around with the ECU. I myself will be going with a Power FC ECU so I will not have the problems associated with OBD-II. Remember, all JDM ECU's are OBD-I. OBD-II is only a North American regulation. Most UK ECU's whould be same as JDM spec.
Old 02-25-2001, 12:38 AM   #23
Tuning Factory Inc.
Vendor
Member#: 3600
Post
FOr reference, the MKIV board had instructions on how to make one yourself. This was the old link. It's not working at the moment. http://www.mkiv.com/techarticles/oxy...tor/index.html
Probably server problem.
Tune up time. Want your info shampy2k Service & Maintenance 11 06-26-2009 11:52 AM
Where to pick up brembo pad replacement? John2.5RS South West Impreza Club Forum -- SWIC 15 09-20-2006 09:03 AM
wrx turbo/up/down/cat-back/FP/short-ram/jdmstiDP... Jase Private 'For Sale' Classifieds 10 07-26-2004 02:11 AM
The landscapers dug up my cat. awdity Off-Topic 59 05-27-2004 12:15 PM
Anyone using the Helix Up/Dn/Cat-Back combo? How is it? DANACoOp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2004 12:40 AM
