Old 04-19-2004, 06:31 PM   #51
deft
Member#: 46624
2004 WRX
Here I even found it for ya,
I think the guy says get two bags of both, 0.2 and 0.12, the radio takes .12, the hvac takes 0.2. here's the link
http://forums.nasioc.com/forums/show...d&pagenumber=3
deft is offline   Reply With Quote
Old 04-20-2004, 10:19 PM   #52
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Originally posted by ATX25RS
has anyone tried just removing the condoms, and not replacing them...what color are the bulbs? yellowish or white?
Pale orange - I just did it and it looks surprisingly good
I would suggest this as only a temporary thing, though, the condoms look better
WRXRallyBlue is offline   Reply With Quote
Old 04-23-2004, 01:01 PM   #53
sirbryanclark
Member#: 59643
2003 Impreza Wagon
Midnight Black Pearl
so the radio takes .12 and the hvac takes .2, but what does the gauge cluster take????
sirbryanclark is offline   Reply With Quote
Old 04-23-2004, 06:44 PM   #54
deft
Member#: 46624
2004 WRX
If you search around a little bit, I know I've seen people talk about it, or even just message someone that has done it.
Old 04-25-2004, 02:57 PM   #55
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
The bulbs in the gauge cluster are about twice as big as the HVAC, so I'm guessing .3 or .4? Search around and post your findings.
Old 05-03-2004, 02:12 AM   #56
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
this is from sisqocqk
Correction!
Bulb condoms for the Hvac are .20 and you'll need 2-4 of them depending on model/year car. (mine needed 2 for my03 wrx)
You'll need about 10 (a couple extra) .12 or (.20 also work) size bulb condoms for the gauge cluster but it won't turn out so well because of the green film.
You'll need 1 .12 size cover for the keyring light (if your car has it)
And finally 2 (1 for each) .12 sizes covers for the cruise and fog switches.
I tried bulb condoms from partsexpress and it didn't work out too well at all!
Look at my writeup on I C L U B as i used DIRECT REPLACEMENT LEDs here:
http://www.I-club.com/forums/showth...;threadid=43144
* i never edited it but some of those are 'dead links'... instead goto http://www.autolumination.com/ as it is the same dealer of the same exact bulb(s)...just different name
My results are as follows (for bulb condoms and LEDs...yes i tried all the colors in each type)
In order of brightness.
In inst cluster with green film:
1) Green LEDs in the Inst panel
2) Blue LEDs in Inst panel
3) Amber LEDs in Inst panel
4) Red in Inst Panel (faint red/brown at best)
5) same order but with condoms
for the Hvac:
1)Red LEDs worked best
2)Amber LEDs
3)Green LEDs
4) Blue LEDs
5) same order for bulb condoms
Keyring light:
Any color will be fine because it's clear/opaque plastic
Any other questions just PM me nd i'll be more than happy to help.
ERIC
ATX25RS is offline   Reply With Quote
Old 05-03-2004, 02:15 AM   #57
ATX25RS
Member#: 4597
also i've got some questions. is the 04 cluster the same configuration? can anyone confirm that they are #74 bulbs in there? if they are then i found some white led's, in my quest for a white cluster. also i know people have complained about "hot spots" with led's. i was at autozone the other day and had an idea. has anyone thought of installing the little wide angle led "accent" light in the cluster for more ambient light?
Old 05-03-2004, 02:22 AM   #58
ATX25RS
Member#: 4597
Old 05-15-2004, 10:08 PM   #59
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
wouldn't painting the bulbs cause them to grt hot or burn out???
ej25_TS is offline   Reply With Quote
Old 05-16-2004, 08:34 AM   #60
mixup52
Member#: 39691
2002 WRX Wagon
It hasn't on mine. But if you think about it, bulb condums hold in heat as well.
Food for thought.
chris
mixup52 is offline   Reply With Quote
Old 05-20-2004, 09:07 AM   #61
green-impreza
Member#: 35863
1995 impreza
green w/ yellow stripes
Originally posted by mixup52
I used red model paint that you by at walmart.
won't the red paint fade?
I was going to use blue paint on my bulbs, but I decided to put leds in instead.
green-impreza is offline   Reply With Quote
Old 05-20-2004, 11:24 AM   #62
mixup52
Member#: 39691
2002 WRX Wagon
I haven't notice a fade with mine.
Old 05-28-2004, 07:52 PM   #63
VSGTS14
Member#: 60497
2005 WRX STi
i used red translucent paint and it works awesome
VSGTS14 is offline   Reply With Quote
Old 05-29-2004, 10:57 AM   #64
ej25_TS
Member#: 59670
2008 Lexus IS250
Starfire Pearl
ok I did mine blue and they look like crap... very dark and i did a light coat of paint too.
well i want leds now. what size? where? any info would be great.
thanks
Old 05-31-2004, 05:03 PM   #65
ATX25RS
Member#: 4597
iirc they are #74 .....and a few posts up is the website...
Old 06-01-2004, 01:37 PM   #66
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
OK, I'm definitely tired of the orange now.. Did anyone have any success with blue whatsoever? Anyone use blue condoms? I don't want to go through the hassle of buying and installing if it won't look good anyway..
Old 06-06-2004, 05:18 PM   #67
ATX25RS
Member#: 4597
okay so i just did the HVAC and the Stereo without any condoms or paint. its pretty easy to do, and the color without the condoms is a nice orange color.....i will leave it like this and see how it goes with the white cluster when i finish...i will try to post some pics soon
Old 06-10-2004, 03:47 PM   #68
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
[email protected] Record Run.
ANYONE! where can i buy the lil condom things? The Paint keeps get scratched off when i insert them.
96Imprezadent is offline   Reply With Quote
Old 06-10-2004, 04:23 PM   #69
WR^2X
Member#: 37617
partsexpress.com
Shipping is expensive though. Mine arrived today! 10 each of .12" and .2", red. I will be doing as much color changing as I can while still not knowing how to remove the HVAC/radio trim on an '05. So that means just the ignition ring and cigarette lighter.
WR^2X is offline   Reply With Quote
Old 06-10-2004, 05:12 PM   #70
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
try trial and error. thats what i did with my MY96 Impreza. Thanks for the site
Old 06-10-2004, 05:22 PM   #71
WR^2X
Member#: 37617
Once my alarm comes I am going to have to figure it out... I'll probably wait. Just did the ignition ring and cigarette lighter. Took about 5 minutes. Looks good from what I can tell so far (too light outside to really know.) Used .2 on them both and had to trim the bottoms off a bit because they were a little long.
Old 06-13-2004, 07:22 AM   #72
SparkysJDMSpeedWagon
Member#: 52530
2004 For Sale:
Silver 04 wagon w/18g
Does anybody know the actual bulb sizes for the HVAC/stereo/dash bulbs? I want to actually change out the bulbs themselves, w/o painting them. Normally, I'd paint em, but I want blacklight bulbs to match my Blitz BLM gauges
SparkysJDMSpeedWagon is offline   Reply With Quote
Old 06-13-2004, 11:56 AM   #73
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
the AC controls and temp on my car are 74. i m not sure if that is what is on the newer models. As for the dash, i havent taken that apart yet.
Old 06-13-2004, 06:11 PM   #74
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Ooh, that's a good idea
Old 06-18-2004, 03:58 AM   #75
Member#: 52530
2004 For Sale:
74's? Cool. I think, judging by the pics, that a couple of them on the dash are wedge-type (194, IIRC). Any idea how many of them are in the radio/HVAC/dash? I live in Alaska, so I'd like to order all the bulbs at once, so I don't have to pay for air mail twice on them.
wtb: hvac and radio surround for 07 acemyles2.5i Private 'Wanted' Classifieds 1 05-05-2010 02:06 AM
How do they change the lights on Radio towers? Sephro Off-Topic 67 11-01-2006 06:13 PM
For everyone wanting to change the HVAC colors on the '05 STi WR^2X Electrical & Lighting 15 08-08-2004 10:22 PM
HVAC and Radio bulb change? unloadmydodads Electrical & Lighting 1 06-12-2004 10:04 PM
how hard to change the rear and front brakes on my 00 legacy GT? mprezme Brakes, Steering & Suspension 2 10-02-2002 11:14 AM
