Old 05-15-2004, 10:05 AM   #1
Paul V
Member#: 59912
1993 Liberty(Legacy)
Cool Engine Whistle
Hi everybody i posted this question a while back and have found the answer, i hope this prooves helpful to someone.
This post concerns an engine whstle at idle, my Legacy 93' EJ 22 non turbo engine was making.
The sound is a single high pitched sound more noticeable when engine under load and Air Conditioning on
The sound is noticeable from 800 rpm to 1300 rpm and when iake my foot off the gas it dissappears untill the rpm drops to 850 rpm (minimum idle).
The high pitched sound is more noticeable when the engine is warm.
The timing belt has been recently changed and the belts seem in good condition also power streering, alternator and air conditioning belts are all ok, when i remove these belts the noise is still there, if i remove the timing belt left and right side covers the noise does not change (get louder).
It dose not sound like a wwwrrr sound
The answer is the sound was coming from a clogged throttle body, running an upper cylinder clean cured the problem.
Paul V is offline   Reply With Quote
Old 05-15-2004, 10:30 AM   #2
Sojuuk
Member#: 61423
2004 Outback H6
Champagne
yeah ive got the same general thing except mines at 1800-2000 and it is definately coming from the area of the intake manifold.
Sojuuk is offline   Reply With Quote
Old 05-15-2004, 03:10 PM   #3
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
just tell girlies its your turbo spooling
fibuz is offline   Reply With Quote
Old 05-15-2004, 10:36 PM   #4
jackacc
Member#: 53188
2013 WRX 5 door
my wrangler sounds like that with a hollowed out cat and a dynaflow... "kind" of a whirring sound... at least way different then stock anway...
jackacc is offline   Reply With Quote
Old 05-16-2004, 04:09 AM   #5
Chi_San
Member#: 53558
2002 WRX Wagon
Mine makes a whistle when going 50+. Does it in gear and out, and it isn't the wind. It's always done it, so it's not a concern to me.
Chi_San is offline   Reply With Quote
Old 09-03-2013, 12:24 AM   #6
aaronka
Member#: 367247
My 2003 GT has always produced a very noticeable high-pitched whistle from the engine (I assume its the intake) under heavy acceleration. It was a bit concerning at first but it doesn't seem to be anything serious. I chalk it up to the engine sucking some air through a pin hole somewhere in the air intake plumbing.
aaronka is offline   Reply With Quote
Old 02-20-2014, 11:14 PM   #7
Mucci
Member#: 257420
Is the whistle temperature based at all? I get a whistle at idle and lower speeds after the car is fully warmed up only.
Mucci is offline   Reply With Quote
ej257 engine feeler C-DAY Engine/Power/Exhaust 38 06-12-2010 02:18 PM
GF8 STI block of the engine Mirone Car Care & Detailing 2 06-02-2010 08:35 AM
2.2l Engine whistle at high RPM boyleia1 Normally Aspirated Powertrain 11 10-24-2007 04:37 PM
06 Stock STi - Sudden Engine Whistling Noise After High Speed SixSigma Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 02-09-2006 09:43 PM
Liberty (legacy) 2.2 lt engine whistle Paul V Legacy Forum 6 04-21-2004 10:20 AM
