Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 06-14-2004, 11:20 PM   #1
edkwon
Member#: 453
2013 VT
Default My first CEL - Catalyst Efficiency below threshold?
Here's my setup:
UTEC stg 2, TXS TBE with single hi-flow cat, velocity stack intake, JDM Sti TMIC. I had most of this installed a couple months ago and tuned. I haven't had a CEL until today when i was just cruising along highway speeds. I pulled the code and this is what came up:
P0420 Catalyst Efficiency below threshold
anyone know if this is a major problem or something that is normal with my mods. I've reset my ECU and just waiting to see if it comes up again.
Ed
edkwon is offline   Reply With Quote
Old 06-14-2004, 11:40 PM   #2
edkwon
Member#: 453
2013 VT
Ok after doing some reading, i found this is the error code i'd get if i ran the catless race pipe. I wonder if my cat is going bad for some reason.
Ed
Old 06-15-2004, 09:43 AM   #3
timo
Member#: 43949
2003 WRX
WR Blue
there's probably nothing wrong with the cat, as p0420 is expected with only one high flow cat instead of 3 normal ones
When I replaced my uppipe and downpipe and drove for a few thousand miles I got the cel as well, but now that I have the accessPORT it's gone(the port takes care of it)
timo is offline   Reply With Quote
Old 06-15-2004, 10:04 AM   #4
BeeGee
Member#: 27724
2003 WRX Wagon
Yep, I got it after installing my Stealthback w/high flow cat and uppipe. I called TurboXS and they said probably 30% of their customers got the CEL with just the SB, and just about everybody got it if they added a catless uppipe to the mix.
The good thing is that the bung on the SB is located perfectly for installing the mechanical O2 sensor fix which will eliminate your CEL without the need to do any splicing of your sensor.
BeeGee is offline   Reply With Quote
Old 06-15-2004, 12:18 PM   #5
edkwon
Member#: 453
2013 VT
ok thanks, luckily this happened right after i got my car inspected, so no OBDII scan hassles
Ed
Old 06-15-2004, 12:39 PM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Ed: Check out the mechanical fix. It will get rid of that pesky P0420 CEL.
http://forums.nasioc.com/forums/show...hreadid=424666
mbiker97 is offline   Reply With Quote
Old 06-15-2004, 04:55 PM   #7
mixup52
Member#: 39691
2002 WRX Wagon
Or you can find one on Ebay. This code has to do with the removal of your Downpipe cat. Has nothing to do with your high flow cat. I have done the mechanical fix and it works great.
Chris
mixup52 is offline   Reply With Quote
Old 06-15-2004, 07:59 PM   #8
Celly
Member#: 48724
Crazy Question.... I thought the UTEC Blocked this code? No?
Celly is offline   Reply With Quote
Old 06-15-2004, 08:13 PM   #9
Uncle Scotty
OK Houston
we have an Uncle
NO....you CAN disable the Check Engine Light.....but THAT would be very VERY foolish.
On the P0420 CEL....do the 'mechanical' CEL fix for the rear o2 sensor and done.
Old 06-15-2004, 08:27 PM   #10
Celly
Member#: 48724
I hate you.
Perhaps we can get the TurboXS guys to block it. They are smart dudes. This would just give me another reason to lust after the utec...
BTW: 4 - 5 Car starts, and this CEL goes away...
Old 06-15-2004, 08:33 PM   #11
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
The UTEC has no way of knowing what's going on in the ECU to cause the CEL to come on. They just disable the thing completely if you want that. There's plenty of easy ways to do away with this specific code. I've been catless for about a year with nary a CEL.
Macabre is offline   Reply With Quote
Old 06-15-2004, 11:20 PM   #12
mixup52
Member#: 39691
2002 WRX Wagon
But you need the cel with the utec to know if you are knocking.
Old 06-16-2004, 06:59 AM   #13
Uncle Scotty
OK Houston
we have an Uncle
If you set it to 'disable', the ONLY time it will flash is if you knock(or have a misfire....I think).
THAT is why it is a BAD idea to disable it.....
Engine Misfire = Catalyst System Efficiency Below Threshold skifree09 Normally Aspirated Powertrain 9 02-25-2010 07:28 PM
P0420 — Catalyst System Efficiency Below Threshold (bank 1) smoky Built Motor Discussion 4 11-13-2009 03:14 PM
CEL - P0420 - catalyst system efficiency below threshold (bank1) Gilbert927 Newbies & FAQs 19 01-11-2008 07:42 PM
P0420 Catalyst System Efficiency Below Threshold Al Thorp Engine Management & Tuning 12 02-03-2007 10:56 PM
CE light - catalytic converter efficiency below threshold 2.5GT General Forum Archive 1 03-26-2001 04:55 PM
Message Board Statistics All times are GMT -4. The time now is 10:15 AM.
