Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 06-23-2004, 07:02 PM   #1
dusktilldawn
Member#: 57766
1987 GL Wagon 4WD
The Silver Bullet
Question hot side of the radiator
Which side of the radiator is hotter, the water pump side, or the thermostat side?
dusktilldawn is offline   Reply With Quote
Old 06-24-2004, 01:01 AM   #2
Flowmastered87GL
WCSS Drunk
Member#: 8914
2005 Baja Sport
Regal Blue Pearl
uhhh which way does the water flow? (ya I know I should know this, but its late and the car is in the garge so I cant start it) If the coolant is drawn IN through the water pump than that side is cooler. If the water pump drives the coolant out into the radiator than the thermostat side is cooler.
Hmmm is your wagon Moon Silver code 787 like mine?
Flowmastered87GL is offline   Reply With Quote
Old 06-24-2004, 09:01 AM   #3
dusktilldawn
Member#: 57766
1987 GL Wagon 4WD
The Silver Bullet
The 787 sounds familiar, but the car is at my folks house torn into a million pieces. I am putting on 2 electric fans with adjustable thermostats, and a radio. I just need to know what side is hotter so I can mount the thermostat bulbs there. It's amazing how much I miss my GL when it's all torn apart!
Old 06-24-2004, 09:57 AM   #4
Calebz
Member#: 54398
1980 CB400 Hawk
1996 GrandCherokeeLimited
The stock mounting points for the thermoswitches is the passenger side of the radiator, if that helps at all.
Calebz is offline   Reply With Quote
Old 06-24-2004, 10:30 AM   #5
All_talk
Member#: 57843
2007 Spec B
The thermostat lets hot water OUT of the engine. So the Passenger side is “hot” on the EA cars.
Gary
All_talk is offline   Reply With Quote
Old 06-24-2004, 01:28 PM   #6
dusktilldawn
Member#: 57766
1987 GL Wagon 4WD
The Silver Bullet
That should be all I need to know.. Thx!
Old 06-26-2004, 11:53 PM   #7
dusktilldawn
Member#: 57766
1987 GL Wagon 4WD
The Silver Bullet
I just read the directions for the thermostats tonight.. They sit right in the inlet of the radiator, so I will install them on the thermostat (passenger) side. And yes, the car is paint code 787, although only about 70% of the car is really 787 paint. The rest is just...pretty sad..
The music when using AUX port only comes out of one side of the car...What gives? gatorREX Car Audio, Video & Security 22 04-23-2014 05:28 PM
sources of high-pressure oil lines/possible leaks on the pass side of the engine bay Jasper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 06-01-2007 06:27 PM
They get all of the good cars on the other side of the pond chrisarella General Community 16 06-02-2006 02:47 PM
which side of the line is the "IN" side of rrfpr? darioc Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-03-2004 03:00 PM
