Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 07-22-2004, 10:36 PM   #1
Kwyjibo
Member#: 17851
R.I.P. 7.27.2005
Default Sound Stage in WRX...components in rear doors, tweeters on deck?
I haven't seen this asked before and just kinda thought of it today.
With an amp in the trunk it would be easy to put a crossover for some two way components in the trunk, then run a wire for the tweeters through the rear deck and mount them there, keeping the midbass in the rear doors.
I have NO idea how this would affect the sound stage for people in the rear, but i'm more interested in having a decent sound stage up front, and with the tweeters in the door location it sucks.
tia.
Kwyjibo is offline   Reply With Quote
Old 07-23-2004, 02:41 AM   #2
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
if you are interested in having a better staging up front, then invest your time and money in front component and installation. keep the stocker for occasionnal rear passenger. when you have a strong frontstage, you really don't miss rearfill. if you absolutely want rear fill, i would go with 6 midbass driver on the rear deck. the imaging will shift to rear but the midbass is so much better than in a stock door
NicEJ25 is offline   Reply With Quote
Old 07-23-2004, 05:27 AM   #3
WRX/Z28
Member#: 65582
'04 WRX
Platinum Silver
The problem with rear deck speakers is that it pulls your ear rearward. Think of it this way, if you went to a concert, do you face the performer? or the back wall? How many times do you see huge speakers behind you? none. Go with the best you can afford up front, and don't spend more than $100 on co-ax's for the rear.
WRX/Z28 is offline   Reply With Quote
Old 07-23-2004, 09:24 AM   #4
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
Putting components up front with the tweeters in the sail panels rather than stock locations is about a 200% improvement in imaging as well.
I ran for 6 months with my tweeters in the stock location then I moved them one day and couldn't believe the difference...
I also haven't had the rear speakers faded in since January...I faded them out when I was checking levels with a RTA and never faded them back in. I didn't notice till a passenger asked me to turn on the rear speakers for them.
-- Dave
AcquaCow is offline   Reply With Quote
Old 07-23-2004, 04:53 PM   #5
UncleMeat
Member#: 33256
2010 subasuckbox
vomit
Don't put anything in the rear. I let my passengers listen to bass. If you're not cool enough to ride in the front, you don't deserve music. HAR HAR HAR
Unless of course you drive from the back seat? Even then you would want the tweeters mounted on B pillar or something like that.
UncleMeat is offline   Reply With Quote
Old 07-23-2004, 04:58 PM   #6
UncleMeat
Member#: 33256
2010 subasuckbox
vomit
Oh serious answer...
Tweeters in a WRX generally sound GREAT in the A-Pillar aimed at each other or maybe slightly forward (not much). Just put them up high enough to clear the dash.
Some people say when mounting here, to wire them out of phase with the components, but I say experiment as that didn't work well for me at all.
Old 07-23-2004, 09:58 PM   #7
raamaudio
Member#: 50340
05 FXT
Crystal Grey Metalic
The reply before this one was the best and the others have thier place as well. Probably less than 1% of audio competition cars have rear speakers at all except subs and they are up front as well is some of the best(in the rear of some of the other best)
Normally out of phase for A pillar tweets is the correct solution but not always as pointed out already here
Next lay out some towels on your dash and take a good listen, then remove them and try again. Use your best sounding CD's for this and play it moderately loud to medium loud for best results but not really loud and do it while parked with the engine off.
Most vehicles benfit from those ugly dash mats, too bad, I use them myself though.
Rick
raamaudio is offline   Reply With Quote
Old 07-24-2004, 01:10 PM   #8
manu10
Member#: 42343
99 Impreza RS
this is all exellent advice you are getting. invest in quality, amped, front components and your ears will thank you for it. if you have good components in the front with a good amp powering them you will not miss the real fill at all trust me, i know i don't. also keep in mind the more you separate the tweets from your mids the worse frequency response you will get. speakers are made to be listened to on-axis, which is pretty hard to do in a car environment so you have to do your best to minimize how off axis you are.
manu10 is offline   Reply With Quote
Old 07-24-2004, 10:21 PM   #9
WRX/Z28
Member#: 65582
'04 WRX
Platinum Silver
Manu10 had it right, try to separate your tweeters from the woofer as little as possible. Otherwise you get pathlength differences that will hurt your sq and how the tweeter blends with the woofer. Think of every good home speaker you ever heard, how many seperated the tweeter more than 4 inches from the woofer, probably none. Boston has the solution, Ambient Tweeters that add nothing to the sq... just lift the sound stage. Its a second set that sit up high, while the main set sit close to the woofer. http://www.bostonacoustics.com/ca_pr...?CategoryID=15
Old 07-24-2004, 10:26 PM   #10
WRX/Z28
Member#: 65582
'04 WRX
Platinum Silver
javascript:void window.open('Manuals/Neo5Tech.pdf','','height=600,width=700').focus()
oh yeah... and read this as well... they work really really well
Old 07-25-2004, 03:20 PM   #11
raamaudio
Member#: 50340
05 FXT
Slight info correction here guys Most car speakers are designed for off axis listening, due to the way cars are built. This is not saying being on axis is a bad thing but since the path lenghts are so vastly different means on axis is generally going to focus more energy on one side of your head than the other. Car audio competitors figured several ways around these issues many years ago, to bad the car manf do not hire some of us to help them get it right. Some of the newer high end audio systems from the factory are better but none are really correct.
1) kick panel mids and tweets, just not do-able in many cars and a bit tricky to get it right, overall best results can be obtained this way. Start with just the mids, have them as far back and low as possible, you want to equalize the path lenghts as much as possible. Us a very good vocal CD that you know has the primary vocalist in the center of the sound stage(easier to find this with a good home system or headphones) Normally I aim the mids 5" in front of and 1.5" down from the center of the primary listeners ear opening. I aim the speakers at the side windows, the idea is to reflect the opposite speaker into the listeners ear, may sound bizare but it works, exceptionally well and I would be glad to demo this to anyone interested Then the tweeter, generally mounted low and closer to the listener, may be aimed the same or sometimes slightly up and forward to get it to couple with the mid better. I port the rear of the sealed kick panels(sealed before I port them into the lower A pillars and stuff a bit of Dacron into the pillars. I cut a hole in the back of the kick panels to correspond to the opening all cars have into the pillars there, if not able to match them up I may cut and smooth out a hole into the metal to make this work. Some like to port into the carpet and it does have a good effect but not nearly as good as into the pillars, remember, car speakers are not meant for sealed boxes(another generality but almost always true except many subs of course)
2) Pillar mounted tweeters, this is a relatively simple and very effective way to get great center imaging and a high sound stage. Best to sink the tweeters as flush as you can into the pillars to widen the stage, mount them a couple of inches above the highest point on the dash and generally wired out of phase to help time align them to the mids. The midbasses generally work well in the doors, just deaden them well and mount them solidly.
I am not an audio snob or elitist, I have owned the best gear ever, competed at high levels, etc, but most of what I know I am passing on knowledge I have gained from alot of study, hard work, rework, more rework but mainly from associations with some of the worlds most successfull audio competitors and installers. World titles under their belts means they really have put thier hearts into what they have acheived, it is not easy to win at that level. So, If I say something works, please believe me, not doing this for recognition, I want to help you get the most you can from your efforts and expenses pursuing higher end car audio, my reward is in making you happy and saving money if possible as well
For those that do not know, I am in the car audio business but it is far more my passion(as is performance and racing) than business to me and always will be.
Have a great week!
Rick
Old 07-26-2004, 03:10 PM   #12
tad_02Wgn
Member#: 66426
Have a great week!
Rick
Good advice Rick - you hit a lot of important points there.
On another note, are you still selling raammat? I know there were a few people over on SD wondering where to get it a few weeks ago.
-tad
tad_02Wgn is offline   Reply With Quote
Old 07-26-2004, 04:26 PM   #13
raamaudio
Member#: 50340
05 FXT
Thanks, just trying to help out, I rewrote a bit of if it and added more info in a new thread, I will get a bit more detailed in the future or as questions come up. Yes, I still sell RAAMmat
Old 11-07-2004, 03:50 PM   #14
grue
Member#: 17903
For what it's worth, my Jetta uses an 8 speaker system... normal woofers in all 4 doors, and tweeters in the front sail panels, and right next to the rear door handles. If I fade out the rear, I lose the imaging I get from my rear tweeters, and it's VERY noticable.
Just something to think about...
grue is offline   Reply With Quote
Old 11-07-2004, 05:15 PM   #15
AVANTI R5
Member#: 73805
I am running the alpine componets up front(177X) and now wondering what to do for the rear also,Do you think the 17MB Alpines(mid ranges) mounted in the rear doors
is worth it, or a good idea?Or does it fall to the same answer of do not waiste money in the rear?
Old 11-07-2004, 06:06 PM   #16
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I wouldn't bother amp'ing them in the rear...
I don't seem to mind rear door speakers as much as I did rear deck. Rear deck speakers, esp with tweeters are really distracting to me. When the speakers are in the rear doors, I don't seem to notice them.
I'd just go with full range drivers in there, no co-ax or anthing. Raw drivers can be found fairly cheaply at most audio shops.
-- Dave
Old 11-08-2004, 11:30 AM   #17
BakedCookies
Member#: 21543
2009 Fit Sport
when you guys says wire the tweets out of phase, do you mean out of phase with each other or out of phase with each ones own mid?
BakedCookies is offline   Reply With Quote
Old 11-08-2004, 11:48 AM   #18
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
My guess is with each other. I haven't done this yet, but I'm getting ready to.
-- Dave
Old 11-08-2004, 12:39 PM   #19
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
i have the diamond hex s600s in the front, stock locations for the mids and tweets...
it is bizzare i actually decent imaging, but only in the driver or pass seat. I put my head in the middle where the distance would be the most equal, both for tweets and mids and the imaging goes to crap.
I know there are level and phase switches on the xovers for the tweets, but i don't know what the installer put them at (this was a rare instance of having someone else install my stuff)
oh yeah...don't do anything in the rear for the front passengers. unless you are doing actual multichannel you will hose the imaging. you end up with phase issues due to the multiple distances for the same audio info...
ptaaty is offline   Reply With Quote
Old 11-08-2004, 06:24 PM   #20
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
Actually, I have been to shows where there were speakers placed behind the audience. Namely Pink Floyd shows in surround
But I agree with the no rear fill stance many here have taken.
tcs007 is offline   Reply With Quote
Old 07-03-2007, 07:12 PM   #21
CyberJock
Member#: 151728
2007 Impreza WRX
N00b question, but is the dealer mid/tweets a easy drop in? Like is the tweeter wiring already there and I just pop in the tweets on the upper door panel?
CyberJock is offline   Reply With Quote
Old 07-04-2007, 10:52 AM   #22
rmarceau
Member#: 119018
2004 WRX STi
Have a great week!
Rick
Thanks for the info Rick, I just received my RAAMmat and Ensolite in the mail and can't wait to seal up my front doors. I've been running CDT components up front with no deadening for way too long now. Basically, they sound terrible as a result. I'm hoping this makes a huge difference in my sq.
Regarding the elevated tweeters you mentioned, have you, or anyone listened to the CDT upstage kit (additional tweeters placed on dash/pillars) in a Subaru? This may be my next move if im still not satisfied after matting the doors. From the discussion above, it sounds like this could be a good solution for imaging and better sq overall.
Ryan
Last edited by rmarceau; 07-04-2007 at 10:56 AM. Reason: spelt RAAMmat incorrectly
rmarceau is offline   Reply With Quote
installing front and rear door speakers on my 05 WRX g_$ Car Audio, Video & Security 7 04-23-2009 12:29 PM
Will 02 WRX Sedan rear door work on 05 STi ? ProdriveRex Interior & Exterior Modification 1 07-17-2006 01:26 PM
NY: In need of WRX Passenger Side Rear Door in WRBlue MACHWRX Private 'Wanted' Classifieds 5 10-04-2004 01:12 AM
Rear door tweeter-to-grill interference. Jon Bogert Car Audio, Video & Security 22 02-26-2004 04:08 AM
rear door speakers on WRX nhluhr Car Audio, Video & Security 2 08-06-2001 12:54 PM
