Old 07-31-2004, 04:58 AM   #1
manman99
Member#: 51343
Talking Difference Between VF36 and VF37 in details
Hi Guys,
Does anyone know the difference between a VF36 and a VF37
in details?
Anyone has the specification or Dyno Chart for VF36 and VF37?
Or anywebsites that has info on this VF36 and VF37?
Thks
manman99 is offline   Reply With Quote
Old 08-09-2004, 06:17 PM   #2
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
Only info I have, VF36 = twinscroll VF34 and a VF37 is like a twinscroll VF30.
Essentially they spool quicker and yeild larger power bands than the previous 30/34 siblings.
The 36 is supposed to have a titanium compressor wheel along with the ball bearing cartridge.
They are limited to 300-330 whp for the most part because they run out of efficiency when boosted too high.
def
dug-e-fresh is offline   Reply With Quote
Old 08-09-2004, 06:34 PM   #3
samowrx
Member#: 8403
vf36 - ball bearing
vf37 - thrust bearing
that's what i've read in the forums. both turbos have very similar characteristics.
samowrx is offline   Reply With Quote
Old 08-09-2004, 06:40 PM   #4
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
BTW- I run a VF36 (12.05 @ 115.2) and I am dabbling with a VF37 looking for ways to upgrade it.
def
Old 08-09-2004, 06:45 PM   #5
Rallycarperson
Member#: 53971
#35 SP Rally Car
MAP-RALLY.com
They are very similar turbos.
This is another example, like the VF34 and VF30.
-Mark
www.MAPmotors.com
Rallycarperson is offline   Reply With Quote
Old 08-09-2004, 10:17 PM   #6
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
def
are u running stock 14pound wastegate? if not which one did u get?
YaZahX is offline   Reply With Quote
Old 08-09-2004, 10:40 PM   #7
MauroMotorsports
Vendor
Member#: 22359
Change the wastegate spring....it'll run 11's
MauroMotorsports is offline   Reply With Quote
Old 08-09-2004, 11:25 PM   #8
jefersun
Member#: 37716
2002 ej257 Black WRX
def
is that on 93 or c16 octane?
jefersun is offline   Reply With Quote
Old 08-10-2004, 01:14 PM   #9
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
the spring on the VF36 is a 9lb'er. I have additional springs on the the actuator holding it shut 'til 20, still wont hold that to redline though.
def
Old 08-10-2004, 01:18 PM   #10
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
both. for me there was only a 10 whp difference in my pump gas tune vs my race gas tune.
I dyno'ed 310 on 94, 320 on C16... same boost levels. Hitting ~18 psi, tapering to ~15 to redline @ 8k.
Keep in mind that this was through a stock mid-pipe w/resonator, I have since upgraded from that 2.25 inch peice to a full 3 in section.
Also, just after the tune, my rear-end grenaded 5 miles from Turbo XS. I was told that it didn't effect my numbers... but well, I really don't know.
Another thing to keep in mind is I had a major exhaust leak on the passenger side head/manifold. I have since fixed that and spool-up is unbelievable!
def
Old 12-19-2004, 02:35 AM   #11
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
What's the difference between ball bearing and thrust bearing?
WRXRallyBlue is offline   Reply With Quote
Old 12-19-2004, 04:47 AM   #12
SaabTuner
Member#: 67608
Adrian~
SaabTuner is offline   Reply With Quote
Old 12-20-2004, 03:20 PM   #13
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
Wow, thanks.
The only problem is it's too early for me to understand that..
Old 12-20-2004, 05:22 PM   #14
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Great pics -- where did you get those?
jblaine is offline   Reply With Quote
FS: VF36 and VF37 Twinscroll Turbo Kits. sanjay Engine/Power/Exhaust 56 02-28-2009 02:14 AM
what's difference between LWG and HWG in ap2? EJ20_lee AccessPort 4 04-27-2008 07:55 PM
Whats the difference between RA and STI in 5 Speeds? josh04 Transmission (AT/MT) & Driveline 3 10-03-2006 09:44 PM
Difference between 21mm and 22mm in front? Traffic Brakes, Steering & Suspension 66 01-07-2005 10:19 PM
Differences between stock and premium sound in '02 WRX palmerx141 Interior & Exterior Modification 3 04-25-2004 10:07 PM
