Old 11-28-1999, 07:19 PM   #1
suber
Member#: 333
98 not a Leg 2.5GT
Quicksilver Metallic
Post attn: Patrick Olsen - lighting q&a
Hi Patrick!
noted you've installed a headlite harness from Uncle "Yene" Henderson's Comp. Ltd.
Easy? Plug-in add on? Did it include relay(s)? Didja get your bulbs from Comp Ltd too?
Did Gene have a harness and/or relay for the fog circuit?
Thanks for your opinions!
andy e
suber is offline   Reply With Quote
Old 11-29-1999, 06:18 PM   #2
GoFaster
Member#: 551
2001 S4
Talking
Hi Suber -
I bought a headlight harness kit which came with relays from Comp Ltd. It was an easy install, about 15 minutes. They had a special which included bulbs. I am very happy with the results. Friendly and fast service as well.
- Felix
GoFaster is offline   Reply With Quote
Old 11-29-1999, 10:45 PM   #3
suber
Member#: 333
98 not a Leg 2.5GT
Post
Thanks for reply! I'm very familiar with Comp. Ltd service as I've gotten rally stuff from Gene before...
Cheers!
Old 11-30-1999, 08:09 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Yeah, what he said! The install was pretty simple, came with the relays, no problems. Didn't check into the fogs, just put PIAA Superwhites into the foglights and left it at that.
I was not terribly overwhelmed by the "power" of the 80/100W bulbs. I probably should put the original bulbs back in again to do another comparison. Originally I got the harness and some no-name 80/100W bulbs from Comp Ltd, but those bulbs were garbage - when I went to high beams they turned noticeably yellowish. So, I replaced those with some new ones, also from Comp Ltd - Raybrig maybe? Some German company. They are definitely better than the first set I had, but like I said I'm not sure the improvement was worth the money I spent.
Patrick Olsen
'99 Legacy 2.5GT (WNTR-GT): removed intake silencer, K&N filter, 18mm SPD rear bar, 80/100W bulbs with heavy duty wiring, 205/55ZR-16 Yoko Nexus tires
Supercharged '89 Mustang GT convertible (SUMR-GT): 9# intercooled ATI supercharger, etc, etc...
Old 11-30-1999, 10:10 AM   #5
suber
Member#: 333
98 not a Leg 2.5GT
Post
Could the brightness or lack thereof be a result of Subaru's lens/reflector design? The early generation Legacy headlites responded pretty good to uprated bulbs but then you could use genuine H3's too!
CHeers!
Old 11-30-1999, 04:18 PM   #6
GoFaster
Member#: 551
2001 S4
Post
FWIW, I have a 97 GT and my kit came with Hella 80W/100W bulbs.
Patrick, how easy was the SPD 18mm bar to install? Are you happy with it's performance?
- Felix
Old 11-30-1999, 04:50 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Post
Suber - the reflector design could definitely be the problem. I've noticed that the little "hat" that sits on the top of the bulb ("top" being the point, which really aims straight ahead, not up, if you know what I mean) has gotten discolored. Looks like it's being overheated by the higher wattage bulbs - that says to me that a lot of the energy of the bulb is being wasted.
Patrick Olsen
Old 11-30-1999, 10:54 PM   #8
suber
Member#: 333
98 not a Leg 2.5GT
Post
That was bright! I meant "H4's".
Anyway, we used 55/100w's in the 93 Sport, with highs primarily used on last NER night rally & highway - no overheating problems that I noticed - but of course, Subaru's redesigned reflector & housing since then. Thanks, Subaru! Sounds like caution is still advised applying uprated bulbs to newer gen. Legacy.
attn: MattC, Ray, Wayne, Patrick Olsen, Paul G, Edwin, etc.. Fitz New England Impreza Club Forum -- NESIC 5 10-06-2002 08:38 PM
Attn: Patrick Olsen Prestige Motorsports Hawaii Impreza Club Forum -- HIIC 1 08-19-2002 06:02 PM
That's Olsen..... Patrick Olsen to you!! Fitz New England Impreza Club Forum -- NESIC 7 01-07-2002 10:50 AM
Attn: Patrick Olsen.. paultg New England Impreza Club Forum -- NESIC 1 04-15-2001 09:56 AM
Patrick Olsen Skirvdawg General Forum Archive 0 01-10-2001 12:28 AM
