Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-07-2005, 02:44 PM   #1
imp2.5
Member#: 11354
2009 LGT
BF3 tag: Snbrd4evr
Default wideband calibration (hydra)
I have a relatively simple question,
I'm trying to calibrate my wideband to reach 20.8 according to this . I set my wego zero cal at 126 like it says and change the wego grad cal. But when I change the wego grad cal the afr stays the same. If I change the wego zero cal, it will change and I can get a steady 20.8. Does anyone know what I should do? Just keep it the way that works? or should I just try it again later and see what happens? Thanks everyone and I searched for something like this but couldn't find anything.
Kelly
edited for spelling
imp2.5 is offline   Reply With Quote
Old 01-07-2005, 05:56 PM   #2
imp2.5
Member#: 11354
2009 LGT
BF3 tag: Snbrd4evr
Hey hey!!! I figured it out. Now to figure out the car. We just took it for a run, the first time with the turbo on. We have a loong night figuring things out.
Calibrating wideband, changing WEGO GRAD CAL question... PirateSanchez Other Engine Management 1 11-11-2009 12:13 PM
hydra wideband calibration question! Bariga Other Engine Management 3 03-27-2009 12:40 PM
Problem with keeping LC-1 wideband calibrated 2gnt2wrx Electrical & Lighting 9 03-31-2008 12:37 AM
Is my wideband calibrated correctly? mneste8718 Factory 2.0L Turbo Powertrain 17 04-08-2007 07:50 PM
Normal to have to calibrate wideband after 3 weeks? JDM 3SGTE Engine Management & Tuning 12 12-29-2005 08:30 AM
Message Board Statistics All times are GMT -4. The time now is 05:23 AM.
