Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 02-23-2005, 02:40 AM   #1
500whp.com
Vendor
Vendor Sales Rating: (7)
Member#: 71884
2003 Evolution VIII
FOR SALE-88 RX-7 T2-PM ME
Subaru Stars Buddy Club coming to America!
The Buddy Club Racing Spec Damper system was developed based on the data collected from both actual racecars and the high-performance streetcar. Depending on different applications, adequate spring rates, damping force adjustment, and enough damping stroke were all put into consideration to create the one of the best available and balanced suspension systems for the drifting and circuit enthusiasts alike.
Because strut type suspension absorbs the shock directly from the road, it requires a high strength design. Buddy Club utilizes the inverted shock design for its high durability. The inverted shock tubes are manufactured with corrosion free chrome plated steel.
15 Way Compression / Rebound Adjustment
15 different settings are possible with just a simple click on a knob. Inverted shocks have the adjustment knob on the top of the shaft. The others have the knobs at the bottom of the shell case. The basic compression (softest setting) offers excellent comfort for daily street use of the suspension kit. About 4kg/mm spring rate increase is expected with the damping force set to all the stiffest setting.
Pillow Ball Upper Mounts
Steering response will be dramatically improved by adding upper pillow ball mounts instead of the factory rubber bushing. Aluminum upper mounts will let you adjust the camber on several strut type suspension kits.
Original Springs
High quality original springs are used on all of our suspension kits. A special coating gives extra protection against any corrosion caused by the everyday driving.
Bracket Adjustable
Buddy Club has eliminated the need for helper springs by using the adjustable bracket system. A Super low ride-height is possible without having any free play of the springs. One complete turn of the adjusting bracket will lower the ride-height approximately 2mm. The shell case finish is an off black coating to prevent corrosion and offer a high quality feel.
Mono Tube Design Shell Case
All Racing Spec Damper uses the mono tube design shell case instead of an inferior ordinary cartridge type. Strut type application uses a 36mm piston and wishbone type uses an extremely large 46mm piston for greater control of the damping force.
Spring Seat, Lock Seat
This aluminum material spring seat / lock seat will let you adjust the height 2mm for every one full complete turn. By using the pre-loadable adjusting bracket it is now possible to change the spring pre-load without the vehicle height.
Spring Rating GDB:
Front: 8 kg/mm
Rear: 6 kg/mm
Spring Rating GC8:
Front: 8 kg/mm
Rear: 6 kg/mm
Spring Rating BE5:
Front: 8 kg/mm
Rear: 8 kg/mm
GDB 1513.00 + shipping
GC8 1513.00 + shipping
BE5 1513.00 + shipping
500whp.com is offline
Old 02-23-2005, 02:46 AM   #2
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Question
Buddy Club Rims
With the motor sport field which rivals 1/1000 seconds light weight conversion at the gram unit is required. But if light weight conversion is pursued, the extent which is done, strength * rigidity becomes sacrifice. The wheel which it fuses with the new forging technology, where this the element which is contrary, you use aluminum material " A6061 " and " tearing open forging manufacturing method " and is born is the " P-1 Racing QF ". The QF = クオリファイ, in the sense that qualification is given. With field of motor sport, it is used in preliminary round = time attack and the like. In order to run fast, in order to put out the time which is faster than everyone, and the racing wheel where it can give the qualification in order to win. That is the strongest model " P-1 Racing QF " of the birdie club * P-1 racing series.
It pursues the light weight of the extremity by the fact that each size private complete individual program is set and actualizes most light weight.
You use the aluminum material A6061 and at the forging processing by the 8000t hydraulic press machine you actualize high density & high intensity & high rigidity.
It actualizes being close and uniformity conversion of the aluminum molecule by tearing open forge in normal temperature state. Super it is secret of light weight * high rigidity.
For surface strength rise it administers shot processing with paint head-end process and furthermore raises strength and rigidity.
Here is the Wheel Sizes please contact me for pricing! thank you!
Old 02-23-2005, 02:50 AM   #3
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Buddy Club Exhausts
The racing specifications muffler is light weight conversion & the high functional muffler which designate circuit travelling as prerequisite. Layout although being straight structure, seriously considering the torque guaranty in the concave fast limits, the high efficiency intermediate silencer - (the torque bulge) has equipped in the main pipe. The racing specifications muffler which seriously considered basic efficiency in the turbo car skill can receive the sound feeling which in the NA car penetrates the bass which is force heavily in the high rotary limits.
0.8 Power!
The ローダウン doing to the extremity, the circuit travelling it is the competition private special muffler which becomes complete was developed in prerequisite. Although the function which altogether does not learn the excessive decoration (exhaust efficiency) with being the straight tubular straight muffler which makes light weight conversion preferential, for torque guaranty of the concave fast limits the high efficiency intermediate silencer - (the torque bulge) it has equipped in the main pipe.
The material adopted all stainless steel SUS304 and 1 mm thick material and the main silencer - used the ultimate 0.8 mm thick material to the section in the main pipe and pursued the limit of light weight conversion. And, the silencer - inside has adopted exhaust efficiency and the torque bulge which seriously considered sound.
The main silencer where light weight conversion was done to ultimate - as for the installation hook of the section it is not welding and also durability has improved substantially by adopting the band stay hook.
The private inner silencer - it has belonged to all line-up. When installing it becomes safety standards volume.
As for tail end in slanted slash cutting & slanted splashing up type Spartan design.
Brand logograph and the main silencer which are cut in the tail pipe - the RACING SPEC plate which is deposited is super light weight and proof of the advanced muffler.
Buddy Club Spec III GC8 or GDB: 509.00
Balance point to the element which although succeeding the Racing SPEC muffler, calls the basic structure such as straight & light weight guaranty and sound arresting of exhaust flux use with the street new with the adoption of the super silent structure which it developed in prerequisite, is contrary in the higher-order origin, the inner silencer - not installing, as safety standards volume is cleared, it actualizes the wide power band from the medium speed limits to the high-speed limits.
Exhaust efficiency and compatibility of sound arresting it succeeds in balance doing in the higher-order origin. When it is usual, sound arresting has kept installing those which become exhaust resistance such as partition and sound arresting valve. We to hold down exhaust resistance to the utmost and grope the method sound arresting of doing, the result of trial and error The straight structure which guarantees exhaust flux it succeeds in the development of the super silent structure which shows the splendid silencing effect. The material which is formed high endurance, furthermore is the light weight design with the all
stainless steel.
Exhaust flow spreads pipe and due to exhaust pressure in the silent the circumstance whose of the low and medium-speed time is weak relatively is discharged by way of the sound-absorbing section.  Without spreading inside the silent pipe the り it passes through exhaust flow directly in the circumstance whose exhaust pressure at the time of high-speed * high load is high and is discharged.
So far, tail finish of the completely new design there is no type tightens rearview. The shell silencer - with as for connecting the tail pipe new manufacturing method and press manufacturing method of non- welding are adopted and improvement and light weight conversion of durability are actualized. The tail pipe and the shell silencer which administer slanted slash cutting & cirque ended processing - fusion overwhelms the person who is seen and the existence impression indicates racing spirits.
[ Super light weight and 0.8mm thick SUS304 stainless steel ]
The main pipe which forms the muffler adopts all 1mm thick SUS304 stainless steel. In addition, the shell public wall adopts the 0.8mm thick SUS304 stainless steel and super light weight actualizes high endurance.
[ Super lightweight band stay hook ]
While the main silencer - as for the installation hook of the section, not to be welding and maintaining strength and durability, light weight You adopt the band stay hook which administers conversion. Contribution to light weight conversion is possible delicate adjustment at the time of stallation of course.
Buddy Club Spec IV GC8 or GDB: 509.00
Old 02-23-2005, 02:53 AM   #4
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
At the Track
-Proper hold characteristic and best driving position thoroughness pursuit.
-As for weight of seat itself super lightweight design of barely approximately 5kg.
-It actualizes high rigidity the buckle frame (the framework) by allotting effectively.
-The material color the RED / the GRAY, prepares the BLACK / the GRAY 2 colors.
To adopt the high quality twill mesh material which is superior in tension characteristic to the surface material, high endurance. The wool mat which is superior in disposition is used to the lining material and sweat characteristic is pursued.
You adopt buckskin cloth for the shoulder section and portion of the side. Wearing out and the like with the seat belt is prevented.
Light weight conversion high intensity you adopt new development buckle frame work in order to be compatible in the higher-order origin and are thin the thick design it actualizes high rigidity. Preeminent hold characteristic is maintained regarding the radical driving scene.
Regular Seats: 328.00
Wide Seats: 340.00
Rails: 144.00 (Bride Rails)
Shoulder Harness Red/Black: 25.00/Pair
Old 02-23-2005, 02:54 AM   #5
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Radiator Caps: 20.00
Oil Caps: 38.00
Shift Knob A/B: 30.00
Old 02-23-2005, 02:55 AM   #6
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Thumbs up
It is the showroom one pushing item where the ground and the battery voltage stabilizer become united.
The case where electric load increases with advanced condenser loading powering down is prevented.
Furthermore it improves electrification performance with the ground system and actualizes various efficiency rises.
Furthermore blue illumination of high brightness LED engine cheerfully dress rise!
Ground Kit: 135.00
Battery RSB-25: 119.00
Battery RSB-30: 162.00
Old 02-23-2005, 09:17 AM   #7
psyber_0ptix
Member Sales Rating: (25)
Member#: 60671
1992 Turbo Miata
351whp/344tq
ooOOOooooh aaaaHHHHHHhhh
psyber_0ptix is offline
Old 02-23-2005, 02:52 PM   #8
drivrswntd
Member Sales Rating: (7)
Member#: 55818
2003 Ram 2500 CTD
Grey
how about their wings?
drivrswntd is offline
Old 02-23-2005, 07:57 PM   #9
Safe Drives
Vendor Sales Rating: (129)
Member#: 75146
1998 Impreza Wagon
Are the seats FIA Homologated?
Safe Drives is offline
Old 02-24-2005, 02:01 AM   #10
TygerStile
Member Sales Rating: (10)
Member#: 14531
02' Stage4 wrb WRX
06' Mazdaspeed6, 85' AE86
That's a lot of Buddy Club... good stuff.
TygerStile is offline
Old 02-24-2005, 02:27 AM   #11
BoostdBoxer
Member#: 53163
I am running buddy club spec III now and it is farking AWSOME.. DO NOT BUY THESE ... THEN I wont be the only original one in San diego with B Club hehe
BoostdBoxer is offline
Old 02-24-2005, 04:48 AM   #12
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
thats a No on teh FIA seats! But they been using their racing seats in japan for a long time!
Old 02-24-2005, 04:52 AM   #13
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
The Wings are 1020.00
3.9kg
Wing Width: 1,500 mm and 1,600 mm
Bracket Height: 195mm and 225mm
Old 02-24-2005, 10:59 AM   #14
drivrswntd
Member#: 55818
2003 Ram 2500 CTD
Grey
Is that spec 1 or spec 2?
Old 02-24-2005, 12:13 PM   #15
shicane
Member Sales Rating: (18)
Member#: 70456
07 335i
alpine white
pmed you ... didnt get a reply ...
do you need a JDM dp to mate with the spec 3 catback??
shicane is offline
Old 02-24-2005, 02:26 PM   #16
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Calling Buddy club right now!
for the wing i the price are the same but you can pick which 1 you want!
Old 02-24-2005, 02:46 PM   #17
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Difference between Spec 3, and Spec 4 is the Muffler! Spec 3 is a lot louder and have a little bit more power! The Spec 4 is build to fit in the street, it have a silencer build into it!
Piping is 76mm = 3 inch
Old 02-26-2005, 02:37 AM   #18
schuey_1
Member Sales Rating: (3)
Member#: 72524
05 Subaru WRX Sti
Do i need a JDM down pipe or my stock up pipe will work?
And can you PM me the RIMS prices i'm only interested in size 17's 5X114
I have a 05 Sti
schuey_1 is offline
Old 02-26-2005, 02:59 AM   #19
FastS2k
Member#: 59577
04 fxt notansti
s2000 reallynotthatfast
My STi is stock right now, but I run the BC Coilovers and exhaust on my S2k and love both. I actually broke the adjustment on one of the shocks and BC repaired it for free. Good company and good products. The Coilovers are nice because the height is adjustable by either the spring perch or the shock mount. I'm considering the seats for my S2k next. Good stuff!
FastS2k is offline
Old 02-26-2005, 04:16 AM   #20
shicane
Member#: 70456
07 335i
alpine white
any answers yet?? ..
shicane is offline
Old 02-28-2005, 03:15 PM   #21
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
Schuey_1: The Version 3, and 4 will need the Japanese DP. The Pro Spec III will not need the JDM DP!
Old 02-28-2005, 11:00 PM   #22
Blacksubie
Member#: 43785
2004 WRX
JavaBlack
Do you have a full pic of the spec 2 and a price
Blacksubie is offline
Old 03-01-2005, 01:51 AM   #23
schuey_1
Member#: 72524
05 Subaru WRX Sti
Tempting where in CA are you ? And how much for the S&H
schuey_1 is offline
Old 03-01-2005, 02:00 AM   #24
500whp.com
Vendor
Member#: 71884
2003 Evolution VIII
im in LA area, shipping for exhausts are usually 40-55 dollars depending on weight of the exhaust and zip code!
Old 03-01-2005, 02:22 AM   #25
schuey_1
Member#: 72524
05 Subaru WRX Sti
Send you Pm
Maybe i can just pick it up i'm at TEMECULA
Rj
schuey_1 is offline
Closed Thread
Ford to merge U.S. and European performance lines; Focus RS coming to America? Dirty25RS Non-Subaru News & Rumors 45 02-24-2010 10:33 PM
Eye for an Eye Punishment Needs to Come to America chowder31 Off-Topic 70 09-12-2007 03:45 PM
B4 Coming to America??? CRAZY KEN Mid Atlantic Impreza Club -- MAIC 0 10-28-2000 10:20 PM
Coming to America!!! Harj General Forum Archive 6 08-07-2000 08:18 PM
