Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 03-31-2005, 01:45 PM   #1
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
Default does anyone tune unichips
same as post so i called turboxs and asked if they knew anyone and they said no dammit
turbocolin is offline   Reply With Quote
Old 03-31-2005, 03:38 PM   #2
ZoomnWRX
Member#: 11605
2002 01G WRX stg2
2007 Acura TSX
i heard someplace in conn. tunes chips but i could never track them down. i think it was a dsm shop mostly...
gp moto does reflash them though, they did mine for like 50 bucks. its not a custom tune but it's something
ZoomnWRX is offline   Reply With Quote
Old 03-31-2005, 09:23 PM   #3
speedbuggy67
Member#: 9041
blaze yellow 1-450
what tune did u need and which one do u have mapped already?
Scott
speedbuggy67 is offline   Reply With Quote
Old 03-31-2005, 10:25 PM   #4
turbocolin
Member#: 43539
95L 97L 03hedgehog
i need stage 2 it is at st 4
Old 04-01-2005, 12:43 AM   #5
BugeyeWagon
Member#: 73201
i got a TurboXS stage 2 unichip for sale, if u want it
BugeyeWagon is offline   Reply With Quote
Old 04-01-2005, 01:31 AM   #6
turbocolin
Member#: 43539
95L 97L 03hedgehog
how much
Old 04-01-2005, 11:17 AM   #7
BugeyeWagon
Member#: 73201
not really sure.
how much you looking to spend?.. lets start with that, we can work something out
Old 04-01-2005, 03:50 PM   #8
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
check boxer4racing
PerformanceAutoSolutions is offline   Reply With Quote
Old 04-01-2005, 06:02 PM   #9
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
Stage 2 Unichip = HELLO PART THROTTLE STUDDER!
Murray is offline   Reply With Quote
Old 04-02-2005, 12:59 AM   #10
turbocolin
Member#: 43539
95L 97L 03hedgehog
what do you mean murry
Old 04-02-2005, 08:28 AM   #11
wrxunderpressure
Member#: 81665
Hey Ill Trade You My Turbo Xs Stage 2 For The Stage 4 If Thats What You Need
wrxunderpressure is offline   Reply With Quote
Old 04-02-2005, 11:50 AM   #12
I WANT AN STI
Member#: 79983
2005 STI
what are the different stages? are there hp differences or is it just mods......what mods equal a stage 1,a stage 2, etc...im new and learning the suby language......my buddy twelvz has a stage 4 so i kind of have an idea because he has a some nice upgrades....but want a solid definition.....
I WANT AN STI is offline   Reply With Quote
Old 04-02-2005, 12:46 PM   #13
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
TXS:
Stage 1 is stock
stage 2 is TBE
Stage 3 adds a up-pipe and TMIC
stage 4 adds STI injectors
all of these require the Unichip or UTEC.
even the TXS stage 1 was a slight change in performance over a true-stock car i believe.
Cobb has different stages,
not familiar with them off hand.
stage 2 i think is up-pipe and TBE, stage 4 is a VF30/34 turbo with STI injectors.. then with or without upgraded I/C.. dont quote me on this though.
Old 04-02-2005, 01:50 PM   #14
I WANT AN STI
Member#: 79983
2005 STI
what is tbe?...turbo back exhaust with upgraded downpipe?....
Old 04-02-2005, 03:57 PM   #15
speedbuggy67
Member#: 9041
blaze yellow 1-450
stg 1 unichip was an axleback muffler and silencer removed. STG 2 turboback, STG 3 was intercooler and wasn't stg4 injectors and upgraded turbo?
Scott
ps i know turboxs tuned the chips on the car for certain mods as well. I have seen in my own eyes a stg2 + AEM cold air intake written righton the chip
Old 04-02-2005, 06:06 PM   #16
LatentWagen
Member#: 50315
0806 LGTspecB & Saab
9-2xAero5MT DGM & MBP
Originally Posted by Murray
stage 2.5 is a VF30/34 turbo with STI injectors... quote me on this.
fixed
LatentWagen is offline   Reply With Quote
Old 04-02-2005, 08:16 PM   #17
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
the stage 2 chips (revision 2) have a "studder" that occurs at part throttle-partial boost(not full) with a medium load... like 3rd or 4th gear going up a hill at like 30-50% throttle..the car will hesitate, its how the chip was programmed, its not the car knocking and the ECU cutting timing or fuel, its just an annoying feeling..
i have a TXS stage 2.x with a Unichip..i get it all the time, researched it, and found theres a minor mod you can do to the chip to lessen the "problem".. but it doesnt get rid of it.. i think it just makes you need to be at a higher throttle postion before you feel it(has something to do with the fuel/timing program).. basically you wont ever feel this at 60% throttle because your rarely at 60, and 75 is considered WOT.
if anyone is local and wants to feel this "hesitation".. i'll gladly give them a ride in my car and show em.
just to make note of this.. i have a full catless TXS exhaust(now with STI muffler though), gutted stock up-pipe, and MBC with Stg 2 unichip programmed for 91 octane at 16.5 PSI.
im running 93 ocane(good old east coast gas is bettAr), 16 PSI... its NOT Knock.. i proved this is my running higher octane gas with less boost. it mostly happens at like 2-10 PSI..give it full throttle and it goes away. increase hte load on the car(more people, steeper hill or higher gear) and it gets worse.. not bad, but definatly annoying.. i've had many people ask what it was.
i'd like to find a place to re-tune the chip for an up-pipe and higher octane as well..but its unlikely that i'll find someone that can. though, its probly the same setup as a UTEC, with less parameters in each area. tappign into it may be the issue though
Murray
Old 04-03-2005, 11:37 AM   #18
speedbuggy67
Member#: 9041
blaze yellow 1-450
Murray i know the studder well, when i did the ground mod to the manifold it seemed to lessen the studder quite a bit. I bought a batty cable with two loop ends one to manifold other to the battery neg. Looks stock. I didnt bother with that nonsence connecting wires all over the engine bay. I found an add for turboxs(better by design) in NOV 02 of super street mag. STG 1 computer +30wheel HP plug and play 699$ 30 min install, stg 2 stainless DP center pipe hi flow cat and muffler 1699$ Thought that might be interesting.
Scott
Old 04-03-2005, 12:50 PM   #19
Murray
Member#: 11312
2009 Gray
Legacy 2.5i
i still hanvt done my grounding mod yet.. though i did hear it helps a bit on WRX's..couldnt tell much in my "RS" when i had it..
i got some black 8ga. wire laying around.. maybe i'll do a fire-wall and manifold-to-battery setup.. to keep the wires to a minimal.
if anyone finds a tuner for the chips..definatly post it up, theres tons of people who'd love to "upgrade" their old chip.
i've proven how effective they still are, my stg 2 Unichip'd wagon is faster than my freinds UTEC Stage 2 sedan... though he still has a 3rd cat.
MurrAy
Old 04-03-2005, 01:05 PM   #20
AugustusMaximus
Member#: 63060
0005 RS, 92X
silver, red
Supposed to be a little pricier then others but, XXTuning works with the Unichip. They have a new location in Conneticut, saw something about them in the tristate vendors or the vendor classifieds announcements. Had some nice cars at the Evo vs STI shootout at Englishtown last year.
AugustusMaximus is offline   Reply With Quote
Does anyone still tune Unichips? Pedestrian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 04-25-2004 05:01 PM
Anyone able to dyno tune unichip 7-28 or 7-29? Onederer Southern California Impreza Club Forum -- SCIC 2 07-27-2002 09:43 PM
Does anyone have Shiv's wire in directions for his unichip for stage 0 WRBLUEWAGON Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-15-2001 04:50 PM
Anyone w/ Cobb Tuned Unichip Get Boost Spikes? bedabi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-12-2001 07:34 PM
Does anyone what the map is like for Turboxs's unichip? WR-REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-04-2001 02:24 PM
