#1 |
Member#: 6785
Vehicle:2002 WRX Blue |
Hi everyone... I am in the process of doing leak down test.. using the old-school "stick" method to find the TDC.
Either the STi have very little valve overlap.. or the fact the cylinder is running sideway... which is giving me a very hard time.. Doing it on a I-4 engine was extremely easy.. ![]() Any trick(s) anyone can share? Thanks Wilson
#2 |
The crank marker. The service manual says how to do it. I forget what you need to look at though to make sure it is #1 that it at TDC.
#3 |
I use a TDC indicator I bought from Trick Tools. it is a little of a pain to screw in but it works perfectly. just make sure you are on the compression stroke not exhaust :P
