Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 08-23-2009, 11:40 AM   #1
goh2man
Member#: 197695
2009 WRX sedan
DGM stg2
Default Shift knob loose and turning easily
Recently had the clutch replaced on my daily driver car a 2002 Honda Accord Coupe(WRX is garaged during the week) by a local mechanic and when I got it back I realized the shifter knob easily turns left and right and has become very loose. Clutch feels fine and everything else seems ok, was there anything wrong with the install, any guesses of how I could fix this? Maybe if I can figure out how to take the boot off I have to just turn the knob to tighten the threads I'm guessing, just want other opinions since I have never done this. I know I can just go back to the mechanic but it’s a Sunday and trying to avoid a trip there if it’s something I can easily fix. Yes I know this is a Subaru thread but it’s a mechanical question having to do with MT and since my search came out empty for this type of situation and there are a lot of knowledgeable people on here I thought I'd give it a shot.
goh2man is offline   Reply With Quote
Old 08-23-2009, 11:52 AM   #2
tom@kartboy
Member#: 67
Our Shift
WON'T break!
righty tighty, lefty loosey. give it a shot. you dont have anything to loose.
Old 08-23-2009, 04:36 PM   #3
goh2man
Member#: 197695
2009 WRX sedan
DGM stg2
Thanks Tom i tried doing that and the whole leather boot twists with it, guessing i have to pull the boot down or off so it doesn't twist. No luck yet though
Old 08-23-2009, 05:21 PM   #4
nitroinsane
Member#: 216027
my stock wrx shifter does this.It is ****ing annoying.
nitroinsane is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 08-23-2009, 06:07 PM   #5
tom@kartboy
Member#: 67
Our Shift
WON'T break!
most factory based knobs have a plastic insert that screws onto the shifter shaft. if they get overtightened they can strip out.
T
Old 08-24-2009, 11:52 AM   #6
AndrewtechAutomotive
Member#: 99694
Wish I had
a car
I'd try holding the boot, then twisting the shift knob clockwise. The knob should spin in the boot, and tighten up.
If it's stripped, then you are out of luck.
Phil
Andrewtech Automotive
AndrewtechAutomotive is online now   Reply With Quote
Old 08-24-2009, 01:30 PM   #7
Ike83
Member#: 161681
2004 WRX
T
I was just getting ready to start a thread about this exact same issue that I am having. Recently, my buddy and I put a new OEM clutch in my 2004 WRX. Everything went fine (except for a little trouble re-installing the shift fork pivot bar), and the car was put back together rather easily.
However, after it's now all said and done, I'm noticing that my shift knob will not fully tighten down onto the plastic threads? What are my options here?
Somebody suggested that I try to use some epoxy on it, but if I know that if I go that route, the shift knob will probably never come off again in the future, and I don't want that.
The only other option that I can think of, would be to order a new shifter altogether. Is there anything else that I could try before ordering an entirely new shift lever?
Ike83 is offline   Reply With Quote
Old 08-24-2009, 01:32 PM   #8
tom@kartboy
Member#: 67
Our Shift
WON'T break!
the shifter threads are prob fine. its the knob thats jacked up. i say order up a kartboy knob or check around and see if anyone has a stocker on the cheap.
T
Old 08-24-2009, 01:38 PM   #9
Ike83
Member#: 161681
2004 WRX
T
So you're saying that the threads on the plastic knob which sits on the metal lever are probably okay? Because I've looked at the threads inside the shift knob, and they appear to be fine, whereas the threads on the plastic knob seem to be groovy on one side, and smoother on the other.
Is this a common problem? And if it is indeed the threads that are on the plastic knob that are jacked, what are my options at that point?
P.S. I have the silver shift knob that says STI on top of it. It came with the car whenever I bought it.
Old 08-24-2009, 01:45 PM   #10
tom@kartboy
Member#: 67
Our Shift
WON'T break!
I'm saying the knob is jacked. the shifter itself is most likely fine. a quick test to see if the shifter threads are OK is to try screwing a lugnut on there by hand. if it goes on fine then the shifter is OK.
T
Old 08-24-2009, 01:48 PM   #11
Ike83
Member#: 161681
2004 WRX
T
Cool. That's a good idea. But just in case. If the plastic threads on the lever are jacked, will I have to order an entirely new shifter to fix the problem?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 03:05 PM.
