#1 |
Member#: 96448
Vehicle:02 WRX VF34 |
I plan to tackle this over the weekend and want to know if it's necessary to get the alignment done after the wheel bearing replacement on front passenger side.
Also, what's typical cost of putting in new bearings into the hub? Thanks in advance.
#2 |
Member#: 215788
BAIC
Vehicle:2002 WRX MBP |
id like to know this as well. im doin it this weekend too
#3 |
Member#: 39086
Vehicle:2004 STi White |
Are you planning to remove the knuckle and remove the camber bolts in the process? If yes, you will need an alignment.
#4 |
Member#: 200756
RMIC
Vehicle:07 yellow clearbra swp sti "Pearl" |
was needed when my friend had his 05 done the other day, unless he just got hustled, which is a definite possibility
#5 |
Member#: 207324
Vehicle:2009 5-door WRX Obsidan Black Pearl |
