#1 |
Member#: 105340
BAIC
Vehicle:2006 WRX |
I am replacing the stock turbo and the nuts that connect the center exhaust pipe to the turbo are frozen on there. I tried my hardest and they wont budge. Is there a secret to getting them off?
#2 |
Member#: 106439
NESIC
Vehicle:06 WRX TR |
Did you spray any lube on them? PB Blaster is my personal favorite.
#3 |
Member#: 198633
NESIC
Vehicle:2004 WRX Black |
6 point socket with a big breaker bar after a good soak in PB blaster or the like.
#4 |
Member#: 105340
BAIC
Vehicle:2006 WRX |
I got some liquid wrench and it did the job.
Thanks |
#5 |
Member#: 17256
Vehicle:04 STi Blue w/ custom bug splat |
PB Blaster overnight is my favorite. The six point socket is also critical to avoid rounding the nut.
A tip from the olden days (when I used to work on v8s) is to heat the offending nut with a torch (not too hot), then touch a piece of paraffin wax to the point where the nut and bolt meet. The heat immediately melts the wax and draws it into the threads. A couple taps with a hammer also helps. Works great. |
#6 |
Member#: 56297
Vehicle:2004 STi HTA Green MSPT Tuned |
soak it in PB blaster for a bit and use a long breaker bar.
try to clean off the threads that night help it some, maybe even try to tighten it and then losen it. if your working under the car and dont have the room to move much try using a jack to jack up the long breaker bar, or just lift some weights and try again when your stronger lol |
#7 |
Member#: 198053
Vehicle:04 STi WRB EFI Tuned |
burn that sucker
#8 |
Member#: 204222
don't be a sissy. use a torch
