![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 223046
I bought my car this summer which came with BF Goodrich G-Force T/A KDW2 summer tires (225/45 zr17 90y) and since I found out that there's a problem with my suspension, my rear two tires are completely bald and needs replacing. I'm planning on replacing the tires asap once I get my lateral arms replaced on my rear driver side wheel. I live in NJ and since winter is coming up soon, I'm not sure which route to take. I know that having dedicated summer/winter tires are the BEST option, but I'm quite limited on funds at the moment and only have one set of wheels on my car (17' Enkei wheels).
Options: 1. Since I only need to replace the rear two (front two still have 90% tread), I can get 2 of the same tires and swap them for $250 on tirerack, then buy winter tires in a couple months (Blizzaks $580 total on tirerack) and swap those on all 4 wheels when it gets cold. ($830 total ) This would hurt my wallet a lot.2. Buy a pair of cheap All-seasons for now, Kumho Ecsta ASX (348 total on tirerack), and keep my two summer tires and buy two more in the summer and swap those after spring. 3. Your opinion Winter in NJ can get cold on some days and hot on others judging from last winter. From Jan-March, temp variates from 60 degrees one week to 10 degrees the next week - Thank you global warming. Any input and suggestions would be great. Thanks in advance.
#2 |
Member#: 203055
If budget is a concern I would just grab a set of four inexpensive all-season tires and save up through the winter for a pair of summers that match what are currently on there. If you have 90% tread on your fronts it would be a waste to toss them out with the bald ones. This has a couple of advantages. First, its cheaper. Second, if you have a blowout or something that ruins your summers you've always got the other set in reserve.
#3 |
Member#: 16200
Vehicle:bah straw and coal straw and coal as always |
dont think 'STAT' and you will be far better off
and this forum is full of tire talk search some and read some and make fewer threads |
#4 | |
Member#: 223046
The only reason I say stat is because I need to drive and my rear two are about to go, so I need to make decisions quickly. I've also read through a lot of threads and not many tailored to my specific situation. Wish you could have given some more helpful information instead of the same "use the search button" response. I appreciate the response though. |
#5 |
Member#: 223046
double post, sorry!
#6 |
your decision depends on how much money you want to spend. being that you're limited on funds, i would buy the best all-seasons available: cec dws, pirelli pzero nero as, bridgestone re960as are the top rated at a fairly decent price.
#7 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 362 |
option number 1 makes sense to me
#8 |
I had the ASX's on my B5 S4. Good solid tire. There are definitely better ones out there, but not for the price. AWD makes up for a lot of the deficits these tires have, especially laterally hydroplaning resistance. They were solid in the winter and I never got stuck. Just a little squishy in the corners.
#9 |
Member#: 223046
I ordered ASX's in 225/45/17's. I'll keep you guys posted when I get them.
