#1 |
Member#: 213320
Vehicle:05 STi 35r PSM |
05 STi
I had some clutch adjustment problems (would not fully disengage ) I had a hell of a time hitting 4th and 5th it took 2 tries each gear to engage, I solved this problem today by adjusting the pedal and re beading the clutch, so I'm going back on wed for test and tune.Mod list... Perrin GT35r rotaed kit Tial 44mm ewg Perrin FMIC Walbro 255 pump PE 850's 91 oct fuel 91 EcuTek tune MBC @ 22psi Exedy Twin disk clutch HKS SSQV Crapp all season 245/45/17 all season tires and no launch control My time slips first pass coasted half track_______second pass________third pass R/T ... .067_______________.101_____________-.014 60' ... 2.038______________1.745____________1.845 330 ... 5.662______________5.352____________5.545 1/8 ... 8.742______________8.469____________8.747 MPH ... 77.36______________75.90____________79.49 1000 ... 11.741_____________11.167___________11.307 E.T ... 14.760_____________13.319___________13.493 MPH ... 71.29_____________103.44___________103.97 Let me know what you think...
#2 |
let us know what you do on wed cause those arent that good for a 35r
#3 |
Member#: 213320
Yeah the shifting problem really killed my times, but at a mile high everyone keeps telling me I will be lucky to hit low 11's with a 35r.
#4 |
Member#: 133146
Vehicle:07 WRX VF39 + E85 12.142@115.547mph ;) |
Three words........see my sig
![]() trap speed sucks for a 35r, but it depends on a lot factors. How much does the car weight? how much power did it put down? what is your altitude? how was the weather? |
#5 |
Member#: 213320
it weighs 3300 with me in it, it was about 80 degrees and I live a mile high and I'm at 470hp and 460 tq on 91 oct.
Like i said i think i fixed the clutch problem and I'm going back on wed for test and tune. |
#6 |
13.319 @ 103.44 corrected to sea level is 12.458 @ 110.56
http://www.greatlakesdragaway.com/co...onfactors.html |
#7 |
Member#: 137168
South East
Vehicle:06 Built SGM WRX Nasioc is the SHADY! |
ohhhhh.............
#8 |
Member#: 204644
Vehicle:2005 STi 11.61 @ 119 FPRED 498WHP 450WTQ 93oct |
#9 |
Member#: 152680
Vehicle:2002 Stock EJ205 Holset E85 6spd Wagon |
There has been a few run into the 10's with a 35r up here.. but it's not easy. You should see mid to low 11's. Get some practice... and hopefully now that your clutch is fixed you can drop those numbers down a bunch!! Do you ever run at PMP or just Bandimere?
A little off the subject but, according to that calculator I'm comparable to cars running an 11.1 @ 125.6 mph at sea level ![]() |
#10 |
Member#: 87653
South East
Vehicle:600 hp STI Limited |
your 1-2 shift is lacking big time.. those are terrible 330's
#11 |
I'm sorry but you either have something wrong with your car or your tune.
Trap speeds tell the story... 103mph trap speed in a stock weighted STI even with the worst driver would take no more than 250-275whp... You claim nearly 200 more than that (believable). You need to go see your tuner or similar as no matter how bad the run is, a trap speed will not be more than 3-4mph different from a good run to a bad run. -Jerod You @ 5000ft nm.. You should still trap well over 112-120mph with that power even @ 5000ft and a horrible run. |
#12 |
Member#: 161756
Launch control?
#13 |
Member#: 133146
#14 |
I think we should save the comments from when he gets back for the next attempt. My bone stock 04 trapped 104. Obviously there were issues, so hopefully at that power level she'll trap 120's.
#15 |
Member#: 213320
I also just picked up one of these hopefully it will do the trick...
http://www.flatironstuning.com/p-115...utch-line.aspx |
#16 |
Member#: 213320
1.7 60ft is not bad with out launch control isn't it?
#17 |
Member#: 133146
#18 |
Member#: 213320
what kinda 60' are you pulling juan?
#19 |
Member#: 133146
#20 | |
Member#: 213320
#21 |
Member#: 152680
No 1.7 with a big turbo and no LC is good. If you can make a clean pass after a 1.7 60ft you will run a good time...
#22 | ||
Member#: 133146
This is what I going to do the next time out, I think it can help you.
#23 |
Member#: 78165
South East
Vehicle:10.7 @ 132 @ 116oct 11.0 @ 125 @ 93oct |
Nice 1.7 60-ft.
This just shows how, with a big turbo car, fast shifting plays such a large role in getting a good ET. Get your shifting so fast that it grinds, then slow it down just a tad ![]() |
#24 |
Member#: 56345
Vehicle:93 Swapped L Green |
Something's wrong.
#25 |
Member#: 84482
Vehicle:2005 STI.UR gt40r ...573whp... |
on the 2nd run you gained 28mph on the back half which is pretty good, its the 1/8th mph that is soo slow
go back to the track and hit those gears hard |
