Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 09-25-2009, 06:53 PM   #1
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
Default hmmm...intake manifold crack/leak?
ok im going nuts right now.
I just recently finished my build.
2002 wrx
06 sti ej257 block
sti heads
wrx intake manifold, tgv's, injectors, all accessories etc.
now since Ive gotten the car finished, ive driven it about 200 miles and the whole time ive had this bad hesitation, sputtering around 4000 rpms.
be it, wot, half throttle or just getting up in the rpm's...feels like it hits fuel cut.
ive done a leak test a couple times and im doing it again. and spraying every where with soapy water. and what do i find?
on top of my COATED grimmspeed intake manifold, bubbling soapy water!!!
on the very very top of the manifold, theres a little circle, recessed part. it seems to have a pin hole leak there.
anyone hear anything like this before?
IIdiceII is offline   Reply With Quote
Old 09-25-2009, 07:24 PM   #2
Haelan
Member#: 151045
2004 JBP WRX
Stage II - Monster TD04
Manufacturing defect?
Haelan is offline   Reply With Quote
Old 09-25-2009, 07:36 PM   #3
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
i dont see how...its my stock intake manifold thats been on the car since 02 and has been on 5 different turbos, countless different tunes and pressure test's and i never noticed it.
i sent it to grimmspeed to get coated and im assuming the sand blasted it and then coated it. thats the only thing i can think off that would make any sense.
Old 09-25-2009, 08:01 PM   #4
fastnoypi
Member#: 6886
MY01 HTA GT35RRRR'
ej207 AVCS ON!!
pin hole leak by the casting button?
fastnoypi is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 09-25-2009, 08:08 PM   #5
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
im uploading a video right now so you can see...
its VERY tiny and i highly doubt it has anything to do with my hesitation issue but im just freaking out about this. one thing after another with this f'ing car!
Old 09-25-2009, 08:11 PM   #6
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
ignore the first 10 seconds of the video and the loud compressor in the background lol
its really tiny leak but its still a leak!
its creating very small tiny bubbles and seems to be more than one pinhole.
Old 09-25-2009, 08:11 PM   #7
penusai
Member#: 102808
2002 v8 EJ207
v7 6spd FP Green
what was the condition of the motor? mileage?
get it from a reputable person?
if not, check timing etc before you put it in?
this is ontop of the manifold, right above the TB right?
penusai is offline   Reply With Quote
Old 09-25-2009, 08:16 PM   #8
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
the motor had less than 10k miles on it and i bought it from a very reputable seller. it looked brand new. oil drained perfectly clean, spark plugs were fine. I havent done a compression test or anything like that. it makes boost and idle 100%. Im pretty sure its a tuning issue. im running a modified version of my old map and there are a **** load of new parts.
I def need a tune bad but i also have a brand new clutch and flywheel that need to be broken in which is holding me back from getting it tuned asap. I need to put a few hundred miles on it before i can get tuned.
i did some logging the past couple days and just driving the car normally, its totally fine. not knocking or pulling timing or anything like that and my afr's are normal. my tuner said it didnt look bad. its only when I get around 4k rpm's and the wastegate starts opening that the car bucks and sputters, feels like its hitting fuel cut.
compared to the old map, I now have an ewg setup, new turbo, new motor, tgv deletes, ported throttle body and intake mani, perrin big maf, new turbo inlet, new header, new turbo back. and the car has no CEL's before anyone asks.
Old 09-27-2009, 12:03 AM   #9
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
View Member's Myspace Profile
So this got me thinking, my intake is painted and I took a look at that plug and on the.... passenger side of the plug itself the paint is missing for about 1/8" in the circumference and there is a black mark over the paint about the size of a ball point pen right where the paint is missing...
Weird? I'm going to pressure test it tom...
-jerod
JSarv is offline   Reply With Quote
Old 09-27-2009, 01:11 AM   #10
Uncle Scotty
Member#: 16200
bah straw and coal
straw and coal as always
i cant play that vid, here .....but
sometimes.....when the bolt is removed from the evap solenoid the wrong bolt is put back in....one that is too long....and it gets overtightened and cracks the mani in that area
Old 09-27-2009, 01:13 AM   #11
JSarv
Member#: 163445
l33t *******
I started that thread... (Or I think I did?) That definitely happened to me...
His leak is on the very top of the manifold, where the "freeze plug" is located...
Old 09-27-2009, 01:33 AM   #12
Haelan
Member#: 151045
2004 JBP WRX
That happened to me as well. Pulled that aluminum 'tooth' forward and ripped it right off. Had to beat it back on with a hammer and JB Weld it until I got the manifold replaced.
Old 09-27-2009, 01:37 AM   #13
JSarv
Member#: 163445
l33t *******
I actually ran a long enough bolt in, it ran into the runner for # 1 and put an in. long crack in the runner
Old 09-27-2009, 01:48 AM   #14
Haelan
Member#: 151045
2004 JBP WRX
"Oh look...a loose bolt...I can't have that!"
Crank crank crank...snap...misfire misfire misfire misfire...sputter sputter sppuuutteerr...
Mine didn't crack, but actually drilled a hole into the runner along with pulling the tooth off. I found out later the bolt belonged in the rear frame of the power steering pump.
Item #43 I need to thank the previous owner for...
Old 09-27-2009, 03:53 AM   #15
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
the leak is extremely slow. you cant hear it leak and if i wasnt looking almost directly at it in that area, i would have never really noticed the bubbles. it gets more foamy than bubbly.
I'm gonna take some better video in better light tomorrow and try and take some macro pics...my manifold is coated black so if there is a hole or a crack, its REALLY hard to see.
Old 09-27-2009, 04:07 AM   #16
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
While that is leaking, and you should fix it, I really don't think that is letting enough air escape to cause a stuttering issue.
What EM?
CKxx is offline   Reply With Quote
Old 09-27-2009, 01:53 PM   #17
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
yea its def not my stutter prob...i need a tune thats what that is...usimg stock wrx ecu and rom raider
Old 09-28-2009, 05:47 PM   #18
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
so you're running an avcs ej257 with a 16bit usdm ecu?
Old 09-28-2009, 05:53 PM   #19
IIdiceII
Member#: 90438
02 ej257/20g'd
kaaz gearbox
im using a gruppe-s cam sensor adapter.
edit: yea im using the usdm stock ecu with the ej257.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 09:02 AM.
