Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-01-2009, 11:58 PM   #1
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
Default Welded on the car, broke a bunch of electrical stuff...
So, I had to throw some TIG on a weld nut that started spinning in the subframe, and even though I unhooked the negative terminal on the car before I started welding, when I turned it on the airbag light came on and the horn no longer works.
My friend checked the fuses, and they seemed intact. Any ideas on how I should diagnose what the problem is?
SomeoneWhoIsntMe is online now   Reply With Quote
Old 10-02-2009, 12:16 AM   #2
Lunes
Member#: 143959
1997 Impreza
Soon to be Silver
My first guess would be check to make sure you didn't just affect a ground somewhere near the front bumper/radiator support when you were under there welding... air bag sensors and horn are usually dependent on grounds, I know both my 97 Impreza and one 90 Legacy have both had issues with disconnected body grounds. (its easy to unplug/disconnect stuff, or mess up a sketchy connection when moving stuff and welding too...) check that first, after that, good luck.
Lunes is offline   Reply With Quote
Old 10-02-2009, 12:28 AM   #3
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
Hm... I pulled the steering rack and put it back in a couple times, since this whole thing started with a steering rack bushing install from hell, so that's definitely a possibility.
However, I know the horns are grounded straight through their brackets, and I just used that ground to install some other stuff today, so I know their ground still should be good. I may poke around with a multimeter tomorrow, and see what I can see.
Old 10-02-2009, 12:36 AM   #4
Lunes
Member#: 143959
1997 Impreza
Soon to be Silver
The steering rack is not near any of the grounds I had trouble with on my 97, so I don't think that would affect the airbag either, but you never know where the connections are made without a bit of luck or a LOT of knowledge... but check every possible bolt, metal to metal contact, etc...
More Hot Topics on NASIOC...
Old 10-02-2009, 01:36 AM   #5
Uncle Scotty
Member#: 16200
bah straw and coal
straw and coal as always
subarus use a switched negative system which is a bit different than most.....
Old 10-02-2009, 07:26 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO
When you had the rack out, did you turn the steering wheel? If you did the clockspring/roll connector was destroyed, and that would explain the two symptoms (airbag light and no horn). It is not an electrical issue.
Getting the airbag code read will confirm where the problem is, but most likely it will point to that circuit.
Old 10-02-2009, 08:57 AM   #7
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I would vote on roll connector as well if I just heard the symptoms. I don't think it had anything to do with welding though. I think I have an RS roll connector if you want it, but not sure if it fits and 02 properly.
garface is online now   Reply With Quote
Old 10-02-2009, 04:05 PM   #8
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
Yeah, I did turn the wheel, so that makes a lot of sense. If that's all that it is, that's fantastic.
Old 10-03-2009, 02:09 AM   #9
Uncle Scotty
Member#: 16200
bah straw and coal
until ya realize that it cost ~$200
Old 10-03-2009, 03:45 AM   #10
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
**** me, do they hand forge it from unobtainum and overnight it from japan?
Old 10-03-2009, 02:03 PM   #11
Uncle Scotty
Member#: 16200
bah straw and coal
nah...its just aintgotanyum, and it controls a lot of important junk
Old 10-03-2009, 02:55 PM   #12
garface
Member#: 1581
MY00 RS/STi7
I checked two dealers at some point and one wanted $280, the other like $319. Sucks.
Old 10-03-2009, 03:03 PM   #13
garface
Member#: 1581
MY00 RS/STi7
http://www.subaruparts.com/cart/?pn=83116AE010
Try that if you want a new one. $230 shipped, not too bad.
Old 11-02-2009, 03:18 AM   #14
crpwrx
Member#: 180710
2002 PSM WRX
protuned@ 316hp and 285tq
You are supposed to hang chains from the frame to the ground to well... ground it out, when you weld like that.
crpwrx is offline   Reply With Quote
Old 11-06-2009, 07:38 AM   #15
ncarn8
Member#: 71419
are you serious
ncarn8 is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 01:15 PM.
