Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-03-2009, 09:31 PM   #1
dejavecu
Member#: 222947
05 WRX
Default New engine, old turbo?
So I am getting my shortblock replaced, should I wait on installing a more powerful turbo, larger injectors et cetera. Should I keep PSI low till the engine breaks in?
dejavecu is offline   Reply With Quote
Old 10-03-2009, 09:40 PM   #2
2.5ReallySexy
Member#: 167943
2004 WRX
Might as well get it all on why it's apart and keep boost low for break in period
2.5ReallySexy is offline   Reply With Quote
Old 10-03-2009, 09:43 PM   #3
Wanarex
Member#: 173034
You might as well throw on the larger turbo with the SB since the larger will be easier to keep out of boost for a safer break-in period.
Wanarex is offline   Reply With Quote
Old 10-04-2009, 10:31 PM   #4
dejavecu
Member#: 222947
05 WRX
When I say I am getting it replaced, I mean the dealer is doing it free of charge. I know they must be capable (let's be honest if they can't do this they should not be putting the engine altogether) but I feel this will open a can of worms having them put all of this on. If they do not do a good job on the install, I can see them pointing the finger at the aftermarket parts.
Old 10-04-2009, 10:49 PM   #5
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
i had my shortblock replaced under warranty from a dealer, and i had a VF39 + supporting mods on when i came in, and there weren't any problems for them to put it back on (naturally since it's a VF series), and i had no issues during break in. just follow standard break-in procedure of course, and don't boost high until it's broken in. i don't think they will be too willing if you go with a non-subaru turbo, though. what are you looking to run?
unless the turbo is a rotated setup, there shouldn't be any problems having the dealer service doing it, except of course on the issue of tuning, which you will need to do with a new turbo anyway. if you're going custom turbo or one without an OTS cobb map that you can run on until you break in (VF39, VF34) then you might want to hold off.
BTW turbo installs are not all that difficult if you have the time and space except the injectors of course... ugh.
dLo R6 is online now   Reply With Quote
Old 10-04-2009, 11:49 PM   #6
dejavecu
Member#: 222947
05 WRX
It is a non-subaru turbo; Blouch 16 evo III.
Old 10-05-2009, 01:17 AM   #7
rougeben83
Member#: 115154
2003 Legacy L Turbo
as long as its a stock location turbo, there shouldn't be any technical difficulties in installing it at the dealer. Tuning, and whether they want to touch an "aftermarket modification" however, is up to them.
rougeben83 is offline   Reply With Quote
More Hot Topics on NASIOC...
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:51 PM.
