#1 |
Member#: 168101
NWIC
Vehicle:07 STi Limited Surgeline Tuned UGM GT35R |
As the title say... I need a Defi Genome Control Unit power cable. Does any one have ANY idea where I can find one of these? Is this the same cable as the standard Version 1 control unit? Will a Version 2 power cable work?
Defi can not be contacted directly, but I have a dealer looking into it (with no answer on how long it could take to find out). Japanparts.com can not help me. This is not a US spec'd product and I'm really starting to wonder why I bought them...especially since I dont even know if they work ![]()
#2 |
Member#: 168101
NWIC
T T T
#3 |
Member#: 205930
Vehicle:2005 WRX Sedan Black |
Defi Part #: PDF01302H Power wire for control unit75cm (2 1/2ft) MSRP $11 USD. Top of Google - http://www.carcandymotorsports.com/p...ir-Parts/4438/
#4 | |
Member#: 168101
NWIC
who knew trying to find one little power wire would have been so fun ![]() |
#5 |
Member#: 205930
Im 99% positive its the same 6 pin 4 wire connector...
#6 |
Member#: 148597
Vehicle:00 GDA MBP 04 GGA PSM 97 SF5 St/b |
yes it will work, i switched my genome controller to a version 2 controller using the lovely genome wiring harness. works with no problems.
and i used the genome controller to wire up a boost gauge in my forester with the power cable that came from the version 2 controller. |
#7 |
Member#: 205930
I was wondering if the genome worked with a V2 controller...
#8 |
Member#: 148597
you can use genome gauges with a v2 controller, but you can not use v2 gauges with a v1 or genome controller, for the v2 controller you can only daisy chain similiar gauges so one port you can have the v1 gauges and the other port for your v2 gauges.
