Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-13-2009, 04:21 PM   #1
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Default 10" sub under the seat? Yes! Pics inside!
Some of you may remember from about a month ago my project to lighten my car but still have decent audio. First I installed the Pioneer TSD1720 components and moved my Alpine amp from my trunk to under the driver's seat. The midrange output of the components was great but my music was still lacking and I decided that I still wanted a sub. I got rid of my 12" sub in the trunk that weighed almost 40lbs! So what was I to do?
Some people on here helped me with some ideas from a passthrough box to an underseat box on the passenger side. I finally settled on underseat. It would be a lower center of gravity under there anyway. I looked at 6.5" shallow mounts and 8" shallow mounts and almost went with the pioneer 8" shallow mount. I wanted more though! I looked at every 10" shallow mount woofer but they all required 0.4 cubic feet of box space which is way too big for under a seat. What good is a shallow mount sub if you need a crapload of space to run the speaker anyway?
I finally found this solution after some people on here told me to go with an eD 6.5" sub.
This sub is the eD SQ-10 subwoofer. http://www.edesignaudio.com/product_...roducts_id=106
While they were at it I had them build me a custom box to these specs.
First I think I will need 1/2" material to get enough volume and then use fiber fill to stuff it.
A - 5"
B - 11.5"
C - 14.5"
D - 3.5"
If you visualize this the box slopes.
Anyway, here all the installed pics.
Best of all it weighs only 18lbs and has a much lower center of gravity than in the trunk. Its also easy for my to remove for autocrosses.
If you are thinking about this call Brett at http://www.edesignaudio.com/contact.php and ask him for an STi underseat box.
Thanks for looking
rxer311 is offline   Reply With Quote
Old 10-13-2009, 04:30 PM   #2
OAKOS Automotive
Member#: 18261
2002 Impreza WRX +P
www.oakos.com
View Member's Myspace Profile
Nice! My 2.5rs has the factory underseat sub!
Bart
OAKOS Automotive
OAKOS Automotive is offline   Reply With Quote
Old 10-13-2009, 04:40 PM   #3
djerickd
Member#: 3782
02 Old Skool WRX
WFC #040 Still Flossin!!!
whoa I bet ur GF loves that!!
djerickd is offline   Reply With Quote
Old 10-13-2009, 04:44 PM   #4
Giganticprune
Member#: 147662
2006 wrx tr stage 2
wrb protuned by jorge
no carpet? :\
Giganticprune is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 10-13-2009, 04:45 PM   #5
XanRules
Member#: 157348
1997 Oh BS
Correct Fitment Crew CEO
which alpine amp do you have? I was worried about mounting mine under the seat because apparently they get really hot.
XanRules is online now   Reply With Quote
Old 10-13-2009, 05:17 PM   #6
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Originally Posted by Giganticprune View Post
no carpet? :\
Carpet adds weight
I may paint it black some day.
Old 10-13-2009, 05:19 PM   #7
rxer311
Member#: 107099
'07 STI
Satin White Pearl
I have an alpine f-450 amp. It does get hot. Best way to do it is put it on "feet". Pretty much mount each corner to a 1/2" peice of plywood or similar. That keeps it off the floor to help with cooling. Also there are air vents under your seat (when you put the switch to the feet position). If it gets hot...crank the A/C on it!
Old 10-13-2009, 05:20 PM   #8
rxer311
Member#: 107099
'07 STI
Satin White Pearl
The wife hasn't ridden in the car with the new sub yet .
Old 10-13-2009, 05:22 PM   #9
djerickd
Member#: 3782
02 Old Skool WRX
u will have to surprise her!
Old 10-13-2009, 05:27 PM   #10
rxer311
Member#: 107099
'07 STI
Satin White Pearl
By the way there is only 75watts going to this thing and it sounds better than the crappy MA audio 12" sub I had in my trunk with 150 watts going to it. I was pleasantly suprised at how well it works. It is very well balanced with the components I have. I actually have the subwoofer turned down right now.
Old 10-13-2009, 05:31 PM   #11
XanRules
Member#: 157348
1997 Oh BS
I've got an Alpine...something. 250?
It's nailed on my back seat right now.
Not literally nailed. But whatever.
Old 10-13-2009, 06:30 PM   #12
jarencibia
Member#: 187021
2004 WRX Sedan
Awesome! I may have to copy your idea....
jarencibia is offline   Reply With Quote
Old 10-13-2009, 06:46 PM   #13
mr_hann
Member#: 165244
2007 2.5i
Does the sub hit the seat at all (ie can you still move the seat back and forth)?
And do you happen to have a shot from the side?
Your idea has sold me.
mr_hann is offline   Reply With Quote
Old 10-13-2009, 06:46 PM   #14
AcquaCow
Member#: 36838
2000 RS Sedan
2001 RSTi Sedan
STi seats?
I wonder if Rick has any more of his fiberglass/wood STi underseat sub boxes?
I actually have two eD 6.5"s in my car and I did test fit and noticed they fit under the passenger seat just fine... almost broke out the fiberglass and started building a mold of the floor/chair rails on the spot
I do plan to disassemble a wrx seat some day soon to steal the rails from it and use them to template a box using all of the air volume available under the seat...
-- Dave
AcquaCow is online now   Reply With Quote
Old 10-13-2009, 06:49 PM   #15
Back Road Runner
Member#: 60082
2002 Forester
...but...but...that's where my amps go.
Nice job. That's one benefit of the low Qts sub designs ED makes, tiny boxes.
Back Road Runner is online now   Reply With Quote
Old 10-13-2009, 06:58 PM   #16
rxer311
Member#: 107099
'07 STI
Satin White Pearl
With the box at this size the seat moves freely. You can pull the sub in and out. If I did it over again I would probably make it a 1/2"-1" shorter in length (if you stuff it with fiber fill you should still have enough volume). I love it though. Sorry no side shots right now. If I take it out again I will take more pics.
Old 10-13-2009, 07:01 PM   #17
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
rxer311
Looks good paint the box, a few coats of rattle can black and you would be surprised how it just completely disappear.
I'm glad this worked out for you.
R-
labcoat is offline   Reply With Quote
Old 10-13-2009, 10:04 PM   #18
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Originally Posted by labcoat View Post
rxer311
R-
Thanks for all the help
Old 10-13-2009, 10:08 PM   #19
Audiosavvy
I declare Shenanigans!
Member#: 150794
2.3 built bugeye
In it to win it
Alpine amps certainly don't get excessively hot. The PDX amps are the hottest-running of theirs that I'm familiar with (think power per sq. inch) and mine run FIIIINE under the seats. Keep in mind that they share the same climate as you, as opposed to the trunk, so are going to remain cooler under there than in the trunk
Audiosavvy is offline   Reply With Quote
Old 10-14-2009, 01:55 PM   #20
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
You're concerned about the weight of carpet but built an MDF box... (penny-wise/pound foolish??)
Fiberglass FTW... save weight AND space...
couchflambeau is offline   Reply With Quote
Old 10-14-2009, 02:23 PM   #21
STiML8
Member#: 103711
How much did it cost u?
STiML8 is offline   Reply With Quote
Old 10-14-2009, 02:58 PM   #22
JC
Member#: 692
I definitely don't think PDXs are their hottest running amps. They are Class D so they should run cooler than most Class A/B amps. I have a PDX-5 under the seat of my EVO and I drove ~8hrs with the stereo loud and the amp was still cool to the touch. I do have small AC vents under there, so that probably helped.
JC is online now   Reply With Quote
Old 10-14-2009, 03:08 PM   #23
b00st3d
Member#: 9891
2005 AW STi
Dom3 MZM Tuned
A - 5"
B - 11.5"
C - 14.5"
D - 3.5"
what do those sizes and letters correspond to?
b00st3d is offline   Reply With Quote
Old 10-14-2009, 03:14 PM   #24
labcoat
Member#: 33629
03 WRX Wagon
WR Blue
Search is your friend.
http://forums.nasioc.com/forums/show....php?t=1837426
Old 10-14-2009, 03:20 PM   #25
noktrnal1
Member#: 90957
2004 WRX
San Remo Red
Thats pretty sweet, I'd heard the factory sub wasn't much to speak of so I wanted to do a little something more. Thanks for the info and pics.
noktrnal1 is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 03:20 PM.
