#1 |
Member#: 66934
Vehicle:2004 JBP ForesterXT! 2002 cammed OBS - RIP |
where there' smoke, there's ???
looking for possibilities here... 2004 (new to me) forester XT with 102k on the clock drives great, idles well... use it as a daily driver, not abusing it Started smoking from the exhaust and a little from the turbo area last week, enough to cloud up an intersection and be rather embarrassing. Does this every time, begins once it it starts to warm up, until about 10-15 minutes of driving at normal temperature, especially when idling. It's definitely not coolant, white grey oil stink. After driving for a while it goes away and does not come back until the next time i use the car I'm not loosing a significant amount of oil...but what the hell? DS1 disassembled everything...it's not the banjos, the return lines or the turbo (no shaft play). Compression is 150-160 on all cylinders. Leakdown was <5% on all cylinders. drained the oil (not sure what brand they put in at last change) and am now on valvoline 5w30 dino...still smoking. what are the possibilities here???
#2 |
all signs point to the turbo seals.
#3 |
Member#: 104742
BAIC
Vehicle:2006 STi & 09 FXT Black |
I would say most likley^^ but also check the turbo oil feed hard lines. Sometimes they crack.
#4 |
Member#: 66934
all the turbo lines were clean and uncracked.
DS1 doesn't think it's the turbo after inspection (stock td04) |
#5 |
i would go to another shop. DS1 doesn't have the best reputation on here...
your compression and leak down are good, you're not losing a significant amount of oil...it's gotta be the turbo seals. it's fairly common. why i state that DS1 doesn't have a good rep: http://forums.nasioc.com/forums/show....php?t=1864015 http://forums.nasioc.com/forums/show....php?t=1302564 |
#6 |
Member#: 66934
ds1 does have a good rep... that is one particularly angry customer who swears a lot at anyone he can find and doesn't seem to be very reasonable....
#7 |
Member#: 63647
Vehicle:05 FXT 12.5 @ 109 |
Your symptoms point to turbo seals in my opinion as well.
#8 |
Member#: 104206
South East
Vehicle:2004 WRX JBP Sans Motor |
You can have minimal shaft play and still have bad turbo seals.
#9 |
Member#: 16200
Vehicle:bah straw and coal straw and coal as always |
PCV valve
replace it |
#10 |
Member#: 202124
Vehicle:2009 ImprezaWRX 5 Dr Obsidian Black Pearl |
#11 |
Member#: 125687
SWIC
Vehicle:2002 WRX Wagon, sold 05 LGT sedan 5MT |
#12 |
Member#: 66934
ordered.... anything else to try pre turbo swap or (as theorized) ringland (but not ring) failure?
#13 |
Member#: 66934
Turbo was NOT ok....
swapped with another used td04 in good condition. old turbo had at least 1/4" to 1/3" of radial shaft play!! needless to say, i'm not smoking or burning significant oil anymore ![]() |
#14 |
Member#: 26068
NESIC
Vehicle:2007 07 wrx tr S.W.P Bren tuned |
and Ds1 is a good shop ?
#15 |
#16 |
Member#: 66934
at this point i'm not sure...
i drove the car for almost 200 miles after ds1 saw it with the problem getting worse before i had the chance to swap the turbo |
#17 |
Member#: 230320
im having the same problem but smoking from the muffler.....just when i sit not when i drive...
#18 |
Member#: 66934
that's how it started for me...
