#1 |
Member#: 211133
NWIC
Vehicle:2002 Impreza WRX Midnight Blue |
#2 |
Member#: 208332
Vehicle:02 Silver Rex Evo3 16g EWG |
14.7 for stock
#3 |
Member#: 211133
NWIC
does what gear I am in affect how much boost the computer allows?
#4 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
the gear affects engine load and THAT affects how much boost you will see
#5 |
Member#: 60685
SCIC
Vehicle:bug eye WRB |
14.7 is the stock boost on an STi. A WRX is 13.5 iirc. Either way you should peak more than 12 pounds but from what i've read here 12 pounds is a normal consistent pressure.
Mine peaks around 16.9, I have seen the low 17s but that's with a stage two reflash. |
#6 |
Member#: 118209
Vehicle:2002 WRX Sedan |
13.61 is stock. I had thought it was 14 something but I doublechecked on an original map, guess not.
![]() Last edited by rkramer; 10-17-2009 at 12:08 AM. |
#7 |
Member#: 211133
NWIC
If I am truly not hitting 13.5 psi, what could be preventing me from getting full boost?
It seemed like the consistent boost level was about 11 psi. |
#8 |
Member#: 115276
South East
Vehicle:04 PSM WRX p&p fp 16g -- UTI tuned |
even at wot in 4th gear..?
#9 |
Member#: 211133
NWIC
just took the car through third and couldn't get a long hard pull as I was already 15mph past said speed limit. But i didn't see the needle peak past 12psi.
#10 |
Member#: 212410
Your location might play a part. Your in washington, base map pulled from ECU is pressures at sea level.
#11 |
Member#: 211133
NWIC
Elevation here is 2376 ft on average. I am no science whiz, but does this elevation constitute that amount of boost? or lack there of?
#12 |
Member#: 211133
NWIC
Any other ideas out there?
#13 | ||
Member#: 60685
SCIC
#14 |
Member#: 99677
South East
Vehicle:2002 AW Impreza WRX VF-39, 06 5spd, 20psi |
pressure at sea level is 14.7 psi, so if your 2k or so feet up, there is less pressure, making it harder for your turbo to make the 13.61 psi because there is less atmosphere pushing it...i guess...
#15 |
Member#: 211133
NWIC
I did some pretty hard pulls later on and its pretty consistent at 11 psi. I am going to check for vacuum leaks tomorrow. I will chime back in and let you guys know what I find.
#16 |
Member#: 198633
NESIC
Vehicle:2004 WRX Black |
What kind of boost gauge? How was it installed? Where does the needle sit when the car is off? Where does the needle sit when the car is idling?
#17 |
Member#: 82242
Vehicle:2005 wrx wagon wooh wooh!!!!! |
you should come close to max by the end of 3rd???Is that were your getting your boost readings from
#18 |
Amish Rake Fighting
Moderator |
Please read the sticky threads before posting, we have on titled Gauge FAQ that answers this. Repeating of questions dilutes our search engine, please search and read the sticky threads, then post. If searching or reading the sticky threads is not your forte, please post in the newbies and faq forum.
