Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-21-2009, 10:14 AM   #1
undertaker6fd
Member#: 169474
2005 Impreza WRX
San Sumo Red
Default waste gate flutter
would an up pipe leak make the normal turbo spool up whine have a small little tick in it? it sounds like whiiiiiiiiiiiitifiiiiiiiiiiiitifiiiiiiiiiitifiiiii iine? but really fast? or is that what a waste gate flutter sounds like. searched both topics but no straight answer. and yes I read the unibomber page on waste gate flutter.
undertaker6fd is offline   Reply With Quote
Old 10-21-2009, 10:18 AM   #2
mentalcase87
Member#: 223960
2009 WRX Sedan
Dark Gray
Thats a hell of a descrption =) any chance you coul get a sound clip? i know nothing about any of this.
mentalcase87 is offline   Reply With Quote
Old 10-21-2009, 10:22 AM   #3
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
In my experience, wastegate flutter occurs when reaching max boost as the wastegate tries to control your boost, not before. Sound clips or more info would be good, but I don't think you're describing WG flutter.
magicstop is offline   Reply With Quote
Old 10-21-2009, 10:23 AM   #4
undertaker6fd
Member#: 169474
2005 Impreza WRX
San Sumo Red
ill try but it is kinda quiet and dosnt do it the entire time its spooling. maby this will work. It sounds like an exhaust leak, i.e. that speed of a tick and everytime it ticks the whine stops for that split second. kinda like whistling into a fan.
maby to 'cause im anal about my car. I drive around with the with no tunes so I can listen for stuff like that.
More Hot Topics on NASIOC...
Old 10-21-2009, 11:26 AM   #5
Subian
Member#: 202804
2002 WRX Sedan
PSM, needs more cowbell!
Not to highjack, but on the highway cruising @70ish, is a catless up-pipe pretty loud? I dont think it's the transmission, more or less something that either has to do with the manifold or the up-pipe with turbo spool, even if it's out of boost.
Subian is offline   Reply With Quote
Old 10-21-2009, 11:38 AM   #6
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
1. Are you on internal wastegate still ?
2. Is it cracked ?
UFOpilot is offline   Reply With Quote
Old 10-21-2009, 11:45 AM   #7
undertaker6fd
Member#: 169474
2005 Impreza WRX
San Sumo Red
The turbo and WG are all stock. The noise is pretty faint but I notice it.
Old 10-21-2009, 12:16 PM   #8
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
It's not wastegate flutter. Not sure what it is, but what you're describing isn't wg flutter.
Old 10-21-2009, 12:29 PM   #9
Defiant Autospeed
Member#: 155450
2007 FXT
http://forums.nasioc.com/forums/show...hlight=flutter
I am not convinced its flutter, but the above maybe helpful.
Defiant Autospeed is offline   Reply With Quote
Old 10-21-2009, 12:35 PM   #10
undertaker6fd
Member#: 169474
2005 Impreza WRX
San Sumo Red
thank you I read that before posting. The thing is that makes is sound like you get an audible hiss about once a sec. mine is alot faster.
Old 10-21-2009, 12:43 PM   #11
Defiant Autospeed
Member#: 155450
2007 FXT
Well at full boost I would say its 2-3 times a sec.
Here is the thing.
Unless you just installed the parts and it started right after, then its highly unlikely that its flutter. It isnt something that randomly starts.
Up pipe leaks typically dont make a noise like you are describing either, they make a constant noise, when you are on the gas hard.
Its hard to tell man.
Do you have a boost gauge? What is the boost level doing?
(if you dont have a boost gauge, GET ONE. Even if its the $54 autometer from autozone. Its a turbo car, it should have come with one from the factory @companies that sell turbo cars without a boost gauge)
Old 10-21-2009, 01:00 PM   #12
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
I'll try to post a recording of my wastegate flutter later today. It's very pronounced. Again, it really occurs at WOT once you've hit full boost, as the noise is the wastegate trying to control your boost. It doesn't happen on spool-up, I don't believe.
Get a recording if you can. Even if it's a quiet noise, try to record it. And find a way to log or get some feedback from your system.
Old 10-21-2009, 01:30 PM   #13
undertaker6fd
Member#: 169474
2005 Impreza WRX
San Sumo Red
Here is the thing.
Yes the car has a guage in it. Stock I think. It boost good up to about .05-.06 then just holds there. it dosnt seem to waiver back and forth or fade off. It is definately alot faster then 2-3 times a sec. and it comes in when you get that nice loud turbo whine (the good kind) and only for a few sec. like if I hold at say 2800rpm I get a good whine then I slowly give it throttle then the whine picks up and I hear it very faint, almost like an exhaust leak mixed with the whine. but it all sounds like it is all coming from the turbo. Also this happens from about -.02 to .02. Please let me know if Im not making any sense
Old 10-21-2009, 04:28 PM   #14
thisisntjared
Member#: 177891
06 wrx wagon
cgm
ive got something similar when accelerating from 1700-2500rpm but above that its gone. also, in the same rpm range when the vacuum goes to roughly -10hgmm i hear the turbo whine a bit.
thisisntjared is offline   Reply With Quote
Old 10-21-2009, 05:46 PM   #15
Rusty Hanger
Member#: 202930
2007 WRX AP Stage 2
CGM aka silver
View Member's Myspace Profile
When I replaced my DP, I too, notice this very noise. It sounds like an exhaust leak, but I can't find a leak anywhere. Only happens at lite throttle. Open it up, and all I can hear is boxer, no ticks. I assumed it was because the DP is a thinner material, you could hear the ticks. Kinda like a header.
Rusty Hanger is offline   Reply With Quote
Old 10-21-2009, 07:23 PM   #16
undertaker6fd
Member#: 169474
2005 Impreza WRX
San Sumo Red
That might be it
Old 10-21-2009, 07:26 PM   #17
GLrunner13
Member#: 216238
2002 WRX Sedan
Ya I heard the same thing with catless UP and aftermarket DP.
On another note, how can you tell if your turbo is on its way out? I still get good boost but I don't hear a high pitched whine anymore
GLrunner13 is offline   Reply With Quote
Old 11-03-2009, 01:43 PM   #18
Subian
Member#: 202804
2002 WRX Sedan
2. Is it cracked ?
Internal waste gate, and no crack if you were referring to me.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 02:24 PM.
