Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2010
Old 10-23-2009, 12:32 PM   #1
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
Default Need the pros in here...Coolant still bubbling
I tore down my stroked 205 because I was getting 'fizz-like' bubbles coming up into the coolant take when the motor was running. This seems like a pretty clear case of bad HG. I installed new OEM HGs and newly machined heads onto my same block. The deck was checked with a straight edge and looked great. After starting the motor again yesterday and driving ~30 miles, I'm still getting the same fizz-like bubbles (picture what happens from a glass of beer once the head is gone).
I did have a few questions about the o-ringed deck:
See http://forums.nasioc.com/forums/show....php?t=1781881
My question now, is whether there could be anything else causing this that doesn't require a new block (which I'm buying now...)? I'd like to do a few more test before ripping it all apart again, but I've pretty much accepted that is what is going to happen.
CKxx is offline   Reply With Quote
Old 10-23-2009, 12:58 PM   #2
avg
Member#: 183970
2004 WRX
My car has been in the shop for the last week and a half because exhaust gases were detected in the coolant (was having the radiator replaced after it blew), so i did my research on the topic and a bad head gasket is just the best scenario. I was trying to find where I read about it, but if I remember correctly it could be a bent rod or a problem with the block.
Anyway, is that the only symptom your are getting? I never checked for fizz-like bubbles in my coolant, but I had noticed that no matter how much I tightened the coolant hoses, coolant was still leaking out of radiator.
Let me know if you find out what the problem is.
avg is offline   Reply With Quote
Old 10-23-2009, 08:34 PM   #3
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
View Member's Myspace Profile
Honestly - I'd start looking into your IAC valve. Your having problems with it, and your getting "air" into your coolant..
Initially it wouldn't make sense as this is happening at idle and there is only a vacuum at idle, however I do believe if the iac valve is/could be malfunctioning it could be diverting "low pressure" air into the coolant passage of the IAC...
Last case it could be a cracked head/block....
-Jerod
JSarv is offline   Reply With Quote
Old 10-24-2009, 01:25 AM   #4
69subaru360
Member#: 159682
1995 Impreza coupe
1969 360
In your other thread, the surface finish on the deck doesn't look right. It looks too rough.
More Hot Topics on NASIOC...
Old 10-24-2009, 01:31 AM   #5
Uncle Scotty
Member#: 16200
bah straw and coal
straw and coal as always
i had a funny fizzy bubbling when the lower coolant hose on the turbo was pinched......the cooant coming into the upper tank was like foam
Old 10-24-2009, 12:12 PM   #6
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
-Jerod
I don't have coolant running to my TB anymore. Heads are new. Cracked block is what scares me.
I have nothing to compare to at this time, so I can't agree or disagree. Only thing I can say is that it worked fine with at 306whp for 40,000miles. That's when I thought I popped the HG and took it apart. Just reassembled, and here I am.
I will look into this. I used press-fit -8 AN lines, but the one coming off the head has a decent bend to it. I'll make sure it didn't collapse.
Also, I've got the coolant running through the turbo (30r) in the opposite-of-stock direction for clearance reasons. Could this be an issue? Just wondering.
Old 10-24-2009, 03:31 PM   #7
classicaddict
Member#: 220619
04 wrx wagon
this may have been done and i dont mean to insult. but have you tryed a simple coolant compression check? sears sells a kit you attach to the rad cap and compress the cooling system. let it sit and see if it looses pressure. also a cyl leak down test would be a good idea too.
classicaddict is offline   Reply With Quote
Old 10-24-2009, 04:25 PM   #8
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
I could try it. I will see if any friends have a kit. It isn't dripping any coolant though and has been heat cycled at least 7-8 times in the same spot in my driveway.
Old 10-25-2009, 12:43 AM   #9
02 Scoob-TN
Member#: 176010
Default These issues are a bia to track...
Others may have suggested this but I want to help, check your upper radiator hose while the cars been running for like 15 mn, if its hard as a rock then you may have a hg issue. Since you've had the heads off a few times and are using arp head bolts you may not have torqued them down correctly since the process is a lil different than with stock bolts. Obviously replace all factory coolant hose clamps(they suck) with new ones that are the band type and a silicon hose kit is a cheap upgrade just for peace of mind(get the 11 piece kit and change them all). Finally if all else fails you may want to try the copper head gasket sealant on your head gaskets. Is the car overheating or is it that you just noticed air in the system? Is your coolant resorvoir/overflow full after test driving? Its hard to track the culprit down, but I usually start with the radiator since the plastic factory one tends to crack and leak, water pump seal, thermo/seal, and work your way to the hoses. The worst is when your bleeding air pressure in the system under acceleration due to the boost in pressure lifting the heads and causing the exhaust pressure to enter the system. Ive even seen turbos bleed air into the coolant system from cracks in the turbo seals. I had these issues and replaced all the basic stuff first than finally tore her down and got her fixed but since I replaced my turbo and all hoses at the same time as rebuild i cant really say what it was...My bubbles did start out small then eventually grew to the point that it would blow most of the coolant into the overflow and i would loose my heater function and all.. The ej205 block is actually pretty stout same with the heads especially if unported..But at least its easy to weld aluminum..Good luck with tracking it down...
02 Scoob-TN is online now   Reply With Quote
Old 10-25-2009, 01:34 AM   #10
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
The upper hose gets quite hard, but it is hard to describe. I torqued the studs in the same sequence as factory, but simply 45-65-85ft/lb.
I'll also start checking hoses. Like I said, nothing is leaking out of the system, and it is pressurized, so I don't quite follow how else air would be getting in (assuming its not a HG prob). It can't be my turbo because the return line from the turbo feeds the top of the tank. I can see the bubbles coming from below.
There is no issue with overheating, or heat at idle, but I've only driven the car for 40miles. Again, I bleed the system VERY thoroughly, and know what the normal large burp bubbles looks like.
Check this out. It isn't my car, obviously, but pay close attention at exactly 8-10 seconds. Ignore that one big surface bubble. My coolant tank looks like that (the little bubbles). Maybe a TINY bit less frequent...but otherwise similar.
Old 10-25-2009, 01:48 AM   #11
JSarv
Member#: 163445
l33t *******
The upper hose will always be hard - all hoses should be fairly hard I mean its a pressurized system. Having an overly hard hose or radiator/hose failure is generally the result of a bad radiator cap (not venting properly)
A radiator cap will vent enough coolant/air for a blown head gasket making it only noticeable with overheat/bubbles/exhaust smoke.
Honestly man - If its not over heating - I'd drive it. If you've gone through it with a fine tooth comb and can't find anything and its something serious - it will eventually show its ugly head (IE cracked head/block)
I'm a huge fan of having everything magnafluxed before building.. If you did this it should have caught any issue or potential issue.
I'm leaning toward sleeve or cracked head - but you would be loosing alot of coolant into the overflow if this was the case...
99.9999% of the time a blown HG WILL cause excessive smoke or over heat...
Old 10-25-2009, 01:50 AM   #12
JSarv
Member#: 163445
l33t *******
have you PH tested it?
Old 10-25-2009, 01:53 AM   #13
JSarv
Member#: 163445
l33t *******
Old 10-25-2009, 02:01 AM   #14
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
Yea, the checking for exhaust gas is next. I'm waiting for my IACV to show up in the mail (it broke also, just to insult me) then I will take it to my friend's work and stick the emissions sniffer above the open fill tank. You can tell by the computer's readout the amount of C0 present.
I would have done this already, but my car has the IACV CEL, and ia killing cyl1 and idling at like 1700...it makes for an interesting drive.
EDIT: Like you said, I am going to drive it a bit and keep trying to solve smaller possible causes until I either (a) solve it, or (b) it gets 1000% worse and is obviously a blown HG.
Old 10-25-2009, 02:05 AM   #15
JSarv
Member#: 163445
l33t *******
I bet.
What all did you have done to the block and heads before/during the build?
IE: Bore/Hone/P&P/Magnaflux
Old 10-25-2009, 03:41 AM   #16
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
I bet.
Heads were fully inspected by machine shop, block had already been in the car for a few years. New OEM HG and ARP studs.
Since the heads were good, this leads me to believe it was a block-related issue all along.
No magnaflux of block since it was already used and the issue seemed to be a basic HG problem.
Old 10-25-2009, 10:31 AM   #17
JSarv
Member#: 163445
l33t *******
id drive it
Old 11-01-2009, 07:38 PM   #18
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
id drive it
One week later...that is what I have been doing. Still doing the same thing. I am going to begin taking it apart soon...
Old 11-01-2009, 09:23 PM   #19
scby rex
Member#: 104878
02 wrxbastardchild
aw
just bubbles or overheats too? Maybe I missed it.
scby rex is offline   Reply With Quote
Old 11-01-2009, 09:30 PM   #20
666stars
Member#: 221364
2002 Wrx EJ207 nside
Wrb now with 100% more V7
My car has been doing this for a few weeks, first the radiator cracked, replaced it with a mishimoto, and filled and did radiator burp by the book. Just kept pushing coolant into overflow and superstiff upper hose. I just hit 200,000 miles so I bit the bullet on a V7 sti longblock. I started pulling my motor today and put the new one in tomorrow.
666stars is offline   Reply With Quote
Old 11-01-2009, 11:02 PM   #21
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
No overheating yet, but I am also only driving in vac. I haven't really had a chance to blow a lot of coolant out like it did before the tear-down. That did eventually lead to overheating.
It is likely that you were leaking and pressurizing the system, thus cracking your old rad, but the upper hose is normally stiff when the system is hot.
Old 11-02-2009, 07:06 AM   #22
jaxscuby
Member#: 10613
blue
-Jerod
found same in friends 02 wagon..
crack from cc to water jacket triangle port between the
2 cylinders..
jaxscuby is online now   Reply With Quote
Old 11-02-2009, 10:56 AM   #23
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
2 cylinders..
Interesting. Was is readily visible when the motor was cold?
Old 11-02-2009, 05:57 PM   #24
jaxscuby
Member#: 10613
blue
well if i had removed the head and saw it with
my beady eyes, yes..
Old 11-02-2009, 06:29 PM   #25
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
Haha, that is what I meant. Disassembled.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 06:49 PM.
