Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-26-2009, 02:45 PM   #1
swy81
Member#: 37875
02 WRX
Angry Antifreeze smell inside car
About a week ago, I noticed a faint odor coming from the vents of my wrx. Upon looking closer, I could see "smoke" coming from the vents even when the heater was not on. There was also the "oily" streaks on my windshield.
At this point, I'm almost definite there is an issue with the heater core. But, I'm just not sure how severe the issue is. There is no damp carpets from the leaking.
I've brought it to a couple of dealerships and they're looking at roughly $1200 to replace the heater core. The labor is what makes it so expensive. Needless to say, that is very pricey (car is out of warranty).
I've been reading about the radiator stop leak additive. As seeing as my problem could possibly be fixed with this, I've been itching to try it out. Would definitely be a better option than replacing the heater core.
Has anyone tried this out and how easy was the process?
swy81 is offline   Reply With Quote
Old 10-26-2009, 02:51 PM   #2
T_Racer69
Member#: 188079
2003 Stg 2 Bug Wagon
Sonic Yellow
As much as it sucks, I for one am against radiator stop leak. Many others will chime in, but the premise of it just seems to leave a mess. I have heard of people using it and finding crud in the coolant passages, radiators, etc. that was a mess. It is a stop gap, but does seem to work for what it does. To me, it is a remake of putting pepper in the coolant(old car trick my grandfather told me about. Ask him how he knows that if a little is good, a lot is better. )
Maybe see if someone in the area could help you change it out, and buy the part and DIY. Surely someone in the Subie community would help get it done for you.
Travis
T_Racer69 is online now   Reply With Quote
Old 10-26-2009, 03:06 PM   #3
swy81
Member#: 37875
02 WRX
Travis
I'd probably blow up the car trying to do it myself.
Old 10-26-2009, 03:08 PM   #4
T_Racer69
Member#: 188079
Sonic Yellow
I bet there are a lot of people in the Tri-state area that could help. But I understand, you may have to have someone fix it. I just don't like the rad stop leak, and am not really sure if it would work in the heater core. May try an independant shop as well, see if a good one is any less expensive.
Travis
More Hot Topics on NASIOC...
Old 10-27-2009, 12:05 PM   #5
BKscooby
Member#: 163601
I used the rad stop leak for few days, as I had no choice and had to get back home. Problems have been reported with it. Blocked heater core, blocked water pump. Well that is as far as for subies. After 2 days I flushed this crap out with destilled water 3 times, again with a radiator flush, and water again, and swore I'll never put that crap in my car again. Don't cheap out on a heater core. $1200? Is that what the stealership wanted to charge you. The heater core on the internet runs at about $180, it will take 4-5 hrs to install. Go figure. If it was motor than I would take it to the dealer, but any good mechanic can replace the heater core.
BKscooby is online now   Reply With Quote
Old 10-27-2009, 12:07 PM   #6
BKscooby
Member#: 163601
P.S. I did it myself, but would rather pay 400-500 bucks for the labor.
Old 10-27-2009, 12:40 PM   #7
MENU
Member#: 208002
2004 WRX
Brack stage roflcopter
deff not a fun job
MENU is offline   Reply With Quote
Old 10-28-2009, 12:53 AM   #8
bryan_johnson
Member#: 78987
When I looked at what was involved, I got some quotes around town. The dealer actually came in the cheapest at about $600. Not sure if they lost money on the deal or not, but I think it was worth it.
bryan_johnson is offline   Reply With Quote
Old 10-28-2009, 03:41 PM   #9
BKscooby
Member#: 163601
if its 600 with parts installed, go at it.
Old 10-28-2009, 07:05 PM   #10
sc_frontier
Member#: 227641
2004 Wrx
That stop leak stuff is temporary, and will ruin your coolant system. Find a local mechanic that will replace it for more like $300 labor.
sc_frontier is offline   Reply With Quote
Old 10-28-2009, 08:16 PM   #11
recce02
Member#: 13815
02 GCRally prepped
Mods done now needs tune
If you are mechanically inclined DIY is the way to go. It really isn't that difficult to take out the dash and get to the core housing. Just time consuming. There are a lot of screws and just a few nuts and bolts. take pics as you go along and then reverse the process.
recce02 is online now   Reply With Quote
Old 10-29-2009, 09:52 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
before you do ANYTHING i'd make damned sure it IS the heater core.
i had a cracked upper radiator plastic endtank that would only squirt a tiny spray when the car was good and hot.
i've also had a leaky upper turbo coolant hose right at the reservoir hose clamp do the same thing.
in both cases i smelled coolant in the car.
were the "oily streaks" on the inside, or the outside of the windshield?
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:42 PM.
