#1 |
Member#: 211625
SCIC
Vehicle:2003 WRX Midnight Black |
I recently noticed my boost needle bounces between .05 and .1 mpa when I'm in 3rd gear pedal to the floor, but when I get into 4th with the pedal to the floor the needle stays near .08 mpa without bouncing. Does anyone know what could be causing this symptom? The car is stock as well.
#2 |
Member#: 176490
SWIC
Vehicle:2004 WRX VF39 silver |
Could be a lot of things.Id start with cleaning the maf
#3 |
Member#: 162062
South East
Vehicle:'04 WRX World Rally Blue |
Did you remove the pill from the line when installing the gauge?
#4 |
Member#: 145069
W. Canada
Vehicle:2003 impreza wrx WRB |
^those...
if those aren't the case you may need to adjust your WG actuator arm (you shouldn't since im guessing you haven't messed around with that before). i had this problem for a long time, i ended up having to switch to a new bcs but this may/probably isnt the case with yours. (The restrictor pill is located in the turbine vac line, so if you didn't touch these vac lines it wont be the pill obviously). |
#5 |
Member#: 211625
SCIC
I'll buy some maf cleaner today and spray it down.
The gauge was factory installed which is why I posted those stupid mpa units. hahaha I haven't done anything to the turbo so I'm not sure if adjusting the wastegate arm will do anything, but how would I go about adjusting the arm? Last edited by orangecurtain; 10-27-2009 at 08:33 PM. |
#6 |
Member#: 162062
South East
check all your vac lines for signs of leak or brittle spots.
