Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-27-2009, 10:54 AM   #1
subySerb
Member#: 155411
07 Impreza
Default Inside Line Tire Test: All-Season vs. Snow vs. Summer
CN's: Inside line used a Civic Si to test Snow Tires vs. All-Season vs. Summer. Snow tires are best in snowy condidtions, and summer tires are best in the wet and dry conditions, All-Seasons are OK everywhere.
Will It Grip or Will It Slip?
By Dan Edmunds, Director of Vehicle Testing | Published Oct 26, 2009
It's a chilly February morning in northern Minnesota, and a broad expanse of groomed snow stretches before our thermally booted feet. We're standing on the 54-acre snow VDA (Vehicle Dynamics Area) at Automotive Enviro Testing (AET), a company that builds and maintains a sprawling, snowy proving ground in Baudette, Minnesota, each winter for those bent on testing the performance of cars and tires in winter conditions.
And testing tires on snow is precisely why we're here. It's Step One of our quest to quantify the differences among three types of tires (summer, all-season and winter) in three types of driving conditions (dry pavement, wet pavement and snow).
When we're done playing on the white stuff, we'll ship these tires to a specially built facility for wet-asphalt tire testing in Arizona (of all places) for Step Two and then haul them back to California to finish off the rubber with our usual testing regimen on dry pavement. This test sequence — snow before wet before dry — is critical because it ensures that the tread stays in top condition for each successive test.
When we're done, we hope to answer some important questions. Do snow tires represent a big advantage in winter driving? What's the best type of tire for wet pavement? Are all-season tires really a helpful compromise? Are the differences really all that significant?
The Tires
You've heard it before: Tires are much more than black, air-filled cylinders that provide protection for your shiny alloy rims. The four fist-size contact points that exist where the tires meet the ground represent the only link between the multiple thousands of man-hours of complex engineering in the car above and the wide range of road and weather conditions that can exist below.
Tires matter — a lot. The variety of possible road conditions is so vast that you can significantly alter the performance of your vehicle with a simple change of tires.
Let's meet the players in our little experiment:
Summer tires — known simply as "tires" before all-season tire use became widespread — are currently marketed as "performance" or "high-performance" tires. The tread is generally comprised of large tread blocks with high lateral stiffness, while wide circumferential grooves expel and sequester water. The rubber formulation is calibrated for warm weather and pays little heed to snow and ice.
Snow tires, on the other hand, utilize rubber compounds specifically formulated to produce grip at low temperatures and a tread that features a pattern of elements that are oriented to physically bite into snow. A network of hair-thin cuts — known as "sipes" — crisscrosses the tread blocks, subdividing them into numerous edges for added grip. The result is a squishier, less stable tread than you'd see on any summer tire.
All-season tires can't be as singled-minded as these others. Their tread pattern seeks to serve both dry-weather grip and snowstorm bite, so we see medium-size tread blocks that provide some lateral stiffness along with an increased number of biting edges. Sipes are present, but not in great numbers. An intermediate rubber compound with a wider temperature range is often employed.
And because all-season tires are the default tire on many new cars today, they have to somehow simultaneously minimize noise levels, maximize tread life and promote fuel economy with low rolling resistance. In short, all-season tires are asked to do everything.
Selection Criteria
As you might imagine, this test represents a big undertaking, with many potential pitfalls. We took pains to eliminate as many variables as possible before we booked hotel rooms in the wilds of northern Minnesota.
Reduced traction on slick surfaces makes at-the-limit situations likely in everyday driving.
For starters, we would test same-size tires to isolate the effects of the various tread patterns and rubber compounds. We also sought a trio of test tires that were produced by a single tiremaker — it didn't matter which — to ensure that they were developed with a shared engineering philosophy. Beyond that, we wanted original equipment tires (OE) that were developed specifically for a particular car and installed on the assembly line. Finally, we planned to test the tires using the very car for which they were developed.
The ideal tire candidates would therefore come from a vehicle that offered same-size, same-brand summer and all-season OE alternatives, straight from the factory. Winter tires, of course, are always aftermarket replacements.
Only one car satisfied all of these specific requirements: the Honda Civic Si. It can be bought with your choice of Michelin Pilot HX MXM4 all-season tires or, for $200 more, Michelin Pilot Exalto PE2 high-performance summer tires, both in size 215/45R17. And Michelin builds an aftermarket snow tire in that very size, the Michelin Primacy Alpin PA3.
The Tests
Online tire seller Tirerack.com agreed to provide new mounted and balanced test tires for our effort and it shipped them straight to AET's door, ready to go. They're sitting outdoors in the snow, acclimating to the temperature as we survey the test course and install our VBOX data logger in the bright red 2009 Civic Si four-door we drove up from Minneapolis last night.
Typical tire validation tests in snow focus on a tire's performance in city and suburban traffic situations, so 0-40-mph acceleration and 40-0-mph braking tests are the norm. We're adding these tests to our usual 60-mph evaluations and will continue to use them on all three surfaces.
But we're not running our usual 600-foot slalom because the multiple runs required to get good data create deep ruts in the snow that skew the results. But we can still use a skid pad for lateral grip measurement because we can get representative data with no more than a single pass in each direction on AET's snow circle.
Lest you think that performance testing is inconsistent with the careful driving necessary to survive on slippery roads, consider this: Reduced traction on slick surfaces makes at-the-limit situations likely in everyday driving. And along these same lines, we'll be keeping our Civic's traction control system up and running during all of our tests because, if not now, when?
Snow Test Results
No one expects the snow tires to come in anywhere but 1st place on this wintry surface at AET. The point here is to see how big their advantage really is over all-season and summer tires.
It takes 11.7 seconds for our Civic Si to accelerate to 40 mph on snow tires, and 14.5 seconds to get there on all-season rubber — nearly 3 seconds and 24 percent slower. As for the summer tires, well, they require, ahem, 41.7 seconds as they struggle to 40 mph. That's no typo; it takes a half-minute longer — 257 percent more time — for the summer tires to reach this modest speed.
What about our traditional 0-60-mph test? Well, snow tires get to 60 mph in 19.1 seconds, while the all-season treads arrive in 22.9 seconds, nearly 4 seconds later. Forget the summer tires, however. The available 3,650 feet of snow — seven-tenths of a mile — isn't enough. We figure 67 seconds and 3,100 feet are needed to get there, and then there's the small matter of needing to stop again.
And that brings us to our next test: full stops with ABS engaged. Here again the snow tires dominate, stopping from 40 mph in 156 feet, some 28 feet shorter than the all-season tires' 184-foot performance. Meanwhile, our summer tires skate to an ultimate distance of 351 feet, the ABS actuator rattling for all it's worth the whole way.
Increase the starting speed to 60 mph and these distances more than double. It takes 362 feet for the snow tires to stop and 421 feet for the all-season donuts. The summer tires sit this one out because they can't manage to get themselves to 60 mph in the first place. (We do the math instead and come up with an estimate north of 800 feet.)
Skid pad results follow the same now-predictable pattern. Our snow tires pull 0.30 lateral g, the all-seasons manage 0.28g and the summer tires produce a pitiful 0.15g despite a heroic effort by our shivering hot shoe.
Wet Test Results
As with the snow test, it takes a purpose-built test surface to get meaningful and accurate wet test results. What's needed is a large flat VDA with a special asphalt formulation and a water-delivery system that can maintain a uniform depth of water (the approximate thickness of a quarter), so there's a consistent coefficient of friction across the entire surface.
We find it at Arizona Proving Ground (APG) near Phoenix, formerly a Volvo facility and now branded as Ford. Its pristine micro-pool looks gorgeous on this May afternoon as the surrounding mountain peaks, little fluffy clouds and spring sunlight reflect in the glassy surface.
It turns out we can test everything to and from 60 mph here, so for brevity's sake we'll stick to a discussion of those results. Those who want to can find the 40-mph results on the accompanying charts.
Acceleration testing provides the first surprise, as the all-season tire trails the pack with a 15.4-second 0-60 run. The snow tire's 12.7-second effort for 2nd place is significantly better, but the summer tire tops them all with an 11.9-second performance, over 20 percent quicker than the all-season tire. In fact, the all-season tire began encountering trouble near 40 mph, where it had been only 0.4 second behind the summer tire's performance when hydroplaning and wheelspin paid a visit.
Things are much the same when braking from 60 mph. The summer tire's 157-foot stop is the shortest, the snow tires come up 2nd at 181 feet and the all-season tires lag further behind in a flurry of ABS activity on the way to a distance of 215 feet, some 58 feet longer than the summer tire.
On the wet skid pad the summer tire smokes them once more, even delivering a little tire squeal as it churns out 0.81g — a figure many car-tire combinations can't match on dry pavement. The winter tire trails with a 0.71g run characterized by noticeable squirm, presumably from the side loads acting on the numerous sipes in its snow-biased tread pattern. That said, it still bests our all-season tire, which once again brings up the rear with a disappointing 0.65g showing.
Dry Test Results
Home sweet home. We're back at our usual test ground at Auto Club Speedway in Fontana, California, for some good old dry asphalt. This is the surface we're all familiar with, so we figure we can predict the finishing order with ease: summer, all-season, then snow.
And so it is. The summer tires (actually you could also think of them as three-season tires) top the charts in acceleration (8.7 seconds), stopping distance (120 feet) and lateral acceleration (0.86g). OK, this acceleration figure isn't the best we've ever achieved with a Civic Si, but for the sake of consistency we're still using traction control for these launches.
Our all-season tire ties for top honors in the 0-60 test with another 8.7-second run, but its stopping distance and lateral grip figures sag in comparison to the summer tire, with marks of 131 feet and 0.84g, respectively. Not bad, but still second-best.
Pity the poor snow tires, as they are well and truly out of their element here. They manage a competitive 8.9-second acceleration pass to 60 mph, but the 155-foot braking runs and 0.81g lateral acceleration laps take a visible toll on the tread, which might not make it to the car's next oil change if we keep this up. And the noise they make when cruising straight and level reminds us of a lifted off-road pickup.
Summing Up
What can we make of all this? For one, low-friction surfaces demand respect. Our stopping distances in the wet range 30-40 percent longer than those recorded on dry pavement. Meanwhile, stops on snow consume at least three times the distance as they do on dry asphalt, even with the use of best-case tires in each situation.
Second, no single tire type excels on all surfaces, and the differences between each are sometimes striking. These differences are so massive, in fact, that we feel that certain generalizations can be extrapolated from our small trio of carefully selected test tires.
To the surprise of exactly no one, our winter tires dominate in snow and the summer tires dominate in the dry. The eye-opener here relates to wet performance, where a well-developed summer tire embarrasses an all-season tire made for the same car by the same folks. Anyone who never sees or visits snow would be very well served by summer tires for year-round use.
Another key take-away from this exercise is the utter worthlessness of those same summer tires on snow. Anyone who uses snow tires in winter and summer tires the rest of the year — a good strategy to maximize performance and control all year — needs to time the switch-over carefully to avoid getting caught out by the first rogue snow accumulation of the season.
And the lameness of summer tires on snow makes it easy to see why the California Highway Patrol and other local authorities can have a hair-trigger when it comes to requiring snow chains. It also explains why so many carmakers spend a lot of energy on all-season tires; they don't know where you live or where you'll drive, so they want to make sure you've got passable winter rubber.
But in delivering this capability, all-season tires sacrifice a noticeable bit of dry and wet performance. Meanwhile, snow and summer tires provide clear benefits to those who can use them. In this particular test, at least, all-season tires live up to the old figure of speech our old dad used to trot out on occasion: "jack of all trades, master of none."
subySerb is online now   Reply With Quote
Old 10-27-2009, 11:02 AM   #2
El Camino
Member#: 78760
This just in - women are evil, poop is smelly, and r0bman likes star wars.
El Camino is offline   Reply With Quote
Old 10-27-2009, 11:04 AM   #3
merlot
Member#: 16935
'08 DGM STI
'03 Suzuki SV650
404 - OT Relevance Not Found
merlot is online now   Reply With Quote
Old 10-27-2009, 11:08 AM   #4
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
What a giant ****ing waste of time that testing was. Tomorrow I am going to go out and test to see what gets me more ****ed up...a beer, a joint or a syringe full of heroin...
ZMANNH25rs is online now   Reply With Quote
More Hot Topics on NASIOC...
Old 10-27-2009, 11:10 AM   #5
subySerb
Member#: 155411
07 Impreza
Probably the most interesting thing from the article is how much better the summer tires are in the wet than the all seasons, but that would probably change if the temperatures were around 40 degrees instead of 80+.
And also shows how much better the snow tires are on the snow than the all seasons.
Old 10-27-2009, 11:10 AM   #6
StuBeck
Member#: 19546
2009 VW Rabbit
Thats a more relevant test than this.
StuBeck is online now   Reply With Quote
Old 10-27-2009, 11:10 AM   #7
Dogbert2
Member#: 6641
2003 WRX Sedan MBP
Thanks for the CN.
Dogbert2 is online now   Reply With Quote
Old 10-27-2009, 11:12 AM   #8
DrDRum
Member#: 41589
Suff erer Club
Founder (RGSSC)
Good article.
DRum
DrDRum is online now   Reply With Quote
Old 10-27-2009, 11:14 AM   #9
express_wagon
Member#: 68346
'96 FZJ80 unlocked
'96 FZJ80 3x locked
What the eff is going on?
express_wagon is offline   Reply With Quote
Old 10-27-2009, 11:15 AM   #10
NJSwamplands
Member#: 97227
i was thinking that also
NJSwamplands is offline   Reply With Quote
Old 10-27-2009, 11:16 AM   #11
Pheasant Plucker
Member#: 62198
2008 STI
White/Ag
Snow, dry or wet pavement. Is that it? The more useful information would be intermediate Winter conditions such as slush (wet snow), heavy frost, ploughed surfaces, ice, heavily salted surfaces and so on.
Pheasant Plucker is offline   Reply With Quote
Old 10-27-2009, 11:18 AM   #12
subySerb
Member#: 155411
07 Impreza
Also it seems that they used performance snow tires and not full on snows like Blizzaks etc... and Si's stock all seasons are crappy
Old 10-27-2009, 11:19 AM   #13
subySerb
Member#: 155411
07 Impreza
or just plain old cold dry pavement
Old 10-27-2009, 11:22 AM   #14
Iconoclast_WRX
Member#: 43271
I re fuse to put
some cute saying here
This..and with maybe some limited brand testing as budget would allow. The big names such as Hydro Edge, Triple Tread, Nokia WR etc.
Iconoclast_WRX is online now   Reply With Quote
Old 10-27-2009, 11:24 AM   #15
WRXVT
Member#: 17979
2009 BMW 335i xdriv
2009 Tribeca
I think the interesting part of this article is this quote:
this is basically saying that snow/winter tires suck in the dry. They also get damaged if you push the car in the dry. And the article shows that all seasons are much, much, much better than winter tires in the dry. They even used performance winter tires, and they still don't hold a candle to all season tires in the dry.
and here's my over-analysis of it:
People think that if you live in moderate climates (ie areas where it snows sometimes but isn't super cold, like NYC/NJ/MD/DC), you should still get snow tires on your awd car instead of all seasons.
The problem with that is that for the 90% of the days in the winter months when it doesn't snow, you are riding around with compromised handling, and if you push the car, ruined winter tires.
That's a cost/factor that people don't talk about or consider, but should.
The other complication that this quote illustrates manifests itself in the decision between buying an car that comes in either rwd or awd variants (ie BMW 3 series, Infiniti G, Mercedes). In a car that comes in rwd or awd, I would choose awd in these geographic areas because with rwd, you almost need snow tires because all seasons won't cut it in a rwd car in the snow. And then you are stuck with compromised handling when it doesn't snow. This is in contrast with fwd where you can probably get by with all season tires in the winter in these moderate climate areas.
WRXVT is offline   Reply With Quote
Old 10-27-2009, 11:24 AM   #16
CF-Ninja
Member#: 143114
2007 Impreza 2.5i
CGM
All winter testing should be done on Michigan roads. We have slush, salt, potholes the size of your car, potholes the size of semi-trucks. We truly have the winter wonderland of roads here.
CF-Ninja is online now   Reply With Quote
Old 10-27-2009, 11:25 AM   #17
StuBeck
Member#: 19546
2009 VW Rabbit
Anyone who doesn't know that already is stupid. "Hey, I'm using a soft compound, let me push it when its 55* out!"
Old 10-27-2009, 11:37 AM   #18
WRXVT
Member#: 17979
2009 BMW 335i xdriv
2009 Tribeca
I know, but that fact seems to be absent from most a/s vs winter tire debates.
Also, on the bimmerforums, it is almost every day that a person posts a thread with "535i or 535xi?" or "328i or 328xi?" as the thread title, and rwd fanboys always chime in with "u don't need awd y0, just get winter tires" when that's not really the whole picture.
Old 10-27-2009, 11:45 AM   #19
REX8
Member#: 24038
E46 /// ****box
Godspeed Cale...
On my RWD car now:
Bald A032Rs
REX8 is online now   Reply With Quote
Old 10-27-2009, 11:46 AM   #20
express_wagon
Member#: 68346
'96 FZJ80 unlocked
'96 FZJ80 3x locked
I have no idea what you're trying to say. What whole picture? So everybody that lives north of Virginia should get AWD + snow tires regardless?
Seems a bit excessive to me.
Old 10-27-2009, 11:47 AM   #21
ProDarwin
Member#: 134943
94 SW2
95 SW2
Given that the snow tires out stop the all season tires in both the snow and wet tests, and only 24feet longer in the dry, I'd say with all seasons you are riding around with compromised braking any time there is moisture on the road.
Its always a compromise. I'd much rather be cautious enough to drive on winter tires in the dry than drive on all seasons in the snow.
ProDarwin is online now   Reply With Quote
Old 10-27-2009, 12:00 PM   #22
WRXVT
Member#: 17979
2009 BMW 335i xdriv
2009 Tribeca
no, that's not at all what I'm saying. That may actually be closer to the opposite of what I'm saying. I'm saying winter tires have major downsides for those living in anything but the snowiest of climates. North of Virginia is not what I mean by snowiest of climates. if I'm in Minnesota, I'm getting a rwd with winter tires or an awd car with either winters or a/s. But if I'm in Baltimore, or NYC, I'm almost sticking with rwd and all seasons or going with awd. A rwd car with winter tires on it when it snows just a handful of days a year is what's overkill- and what comes with great compromise when roads are dry (most of the time)
It is always a compromise, and I respect your preference. I think winter tires are too much of a compromise on dry roads.
Old 10-27-2009, 12:06 PM   #23
subySerb
Member#: 155411
07 Impreza
It also depends on whether the roads are cleared regularly where you do most of your driving.
Old 10-27-2009, 12:08 PM   #24
ZMANNH25rs
Member#: 9401
. Truth is a
pathless land...
I think 'great compromise' is stretching it a bit here. I have driven around on snow tires for the last three years on my WRX. They handle just fine in the summer and dry conditions. The only time you are going to experience a difference is at the very edge of the limits of the tires. Which, unless you drive around like an ******* all the time, would only be under extreme circumstances or during emergency maneuvers. But being a some what skilled driver I don't feel that having snow tires on during the summer is in any way dangerous to me.
Car control and vehicle dynamics > tread compound when it comes to everyday conditions.
Old 10-27-2009, 12:11 PM   #25
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
I have Goodyear Eagle RS-As on my car because that is what I felt like paying for at the time.
Ba-domp bomp! :readingrainbow:
Kiel is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 10:48 AM.
