Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-27-2009, 12:11 PM   #1
jasv11
Member#: 117862
2006 STi 10.85@129.4
Innovative Tuning
Default Bolt in cage test results
It didn't hold up too well apparently.
http://forums.themustangsource.com/s....php?p=5753663
jasv11 is offline   Reply With Quote
Old 10-27-2009, 12:14 PM   #2
highjumpharry
Member#: 166834
02 WRX
wow... never skimp on weld in cages i guess
highjumpharry is offline   Reply With Quote
Old 10-27-2009, 12:19 PM   #3
sourcandy
Member#: 212410
Kind of crappy they don't have close up pics of the cage meeting to the floor.
Even bolt in cages are suppose to have adequate flanges welded into the floor for just this reason. The floor on any car is not strong enough to simply bolt a cage to. It will punch right through it as shown. Welding the flanges helps in dispersing the loads so it is not focused on one small point.
Either way... those two are REALLY lucky!
sourcandy is offline   Reply With Quote
Old 10-27-2009, 12:20 PM   #4
dub c
Member#: 145069
2003 impreza wrx
aaah.
thanks a bunch for posting that up!
i can't believe they were unharmed!
is it weird that the inspector let that roll bar pass in whatever class that was racing in?
dub c is offline   Reply With Quote
More Hot Topics on NASIOC...
Old 10-27-2009, 12:22 PM   #5
Mechie3
Member#: 120152
2006 WRX, ESP 92
CNY Overall Pax Winner!
Couple things:
What kind of roll cage? I know for Subies the Cusco 6pt is known to be for show only while the autopower bolt in's are meant for actual protection. What is a purchased or custom piece? If it was custom, they might have bolted it wherever without any structural testing.
IIRC, autopower (or maybe it's the SCCA?) requires that you put a 1/4" thick plate on the back side of where you bolt into to prevent the floor from ripping like that.
A welded cage could potentially do the same thing if the same size tube was welded to the same size floor patch it would still rip the floor. The force per area wouldn't change except for the added stress risers due to holes. I still believe welded > bolt in and some bolt ins > other bolt ins.
Mechie3 is offline   Reply With Quote
Old 10-27-2009, 01:19 PM   #6
axelthrasher
Member#: 144779
200X ZOMG a car
Back to the Mustang - if the roll bar/cage was mounted on or near the frame rails it more than likely would have been a lot more stable. I tried to find more pictures on the system they were using, but came up with nothing. Mechie is right in saying that if it had been welded in the same points that the bolt in was it would have done the same thing.
axelthrasher is offline   Reply With Quote
Old 10-27-2009, 01:33 PM   #7
Xclusive
Member#: 225704
1999 Outback Sport
Green/Tan :(
Seems to me the bar didn't fail, the floor did. If it was mounted properly or at least better, it may have worked.
Xclusive is offline   Reply With Quote
Old 10-27-2009, 01:38 PM   #8
imma_stocker
Member#: 97043
08 310awhp STI
02 zero hp Z28
A poor weld-in cage does the same as a good bolt-in. To work, both require a large, well-placed flange to weld to the floor. Otherwise the bars will still punch through.
If you think welding that little circle around the base of the tube will hold up to a force like that, don't take passengers to prove me wrong.
imma_stocker is offline   Reply With Quote
Old 10-27-2009, 01:43 PM   #9
Yotsuya
Member#: 935
Tony Pond Fan Club
Reminds me of the midget wrestling face-skid gif.
Yotsuya is offline   Reply With Quote
Old 10-27-2009, 01:50 PM   #10
69subaru360
Member#: 159682
1995 Impreza coupe
1969 360
Poor choice of floor plate location more than roll bar fail. I have seen a drag car with weld in 6 point rollbar on the roof with the rollbar punched through the floor.
The last car I owned with a rollcage had 6x6 plates welded to the floor on top of the framerails with an additional tube going through the floor to welded and bolted in subframe connectors.
A bolt in cage could possible have survived this with proper floor plates.
Old 10-27-2009, 02:11 PM   #11
sperry
Member#: 8636
94 SVX, 02 WRX, 01
F-250 SuperDuty
Does this image imply they had to exit the car via the trunk?
sperry is offline   Reply With Quote
Old 10-27-2009, 02:12 PM   #12
sperry
Member#: 8636
94 SVX, 02 WRX, 01
F-250 SuperDuty
Old 10-27-2009, 02:21 PM   #13
White out
Member#: 46277
H1 OpenTop
Dodge Viper GTS ACR
I'm surprised that wing didn't save them. . .
+1 for poor placement & plate choice.
Nick
White out is offline   Reply With Quote
Old 10-27-2009, 02:21 PM   #14
White out
Member#: 46277
H1 OpenTop
Dodge Viper GTS ACR
Nick
Old 10-27-2009, 02:47 PM   #15
KC
Member#: 442
2000 Honda S2000
It's the Autopower Street Bar... not even a complete cage.
What does autopower say about this bar? (from another forum)
http://www.autopowerindustries.com/rollbars.asp
STREET ROLL BAR
This roll bar will give your street car a performance look and style.
* In most cars rear seats and/or convertible top remain in place and useable.
* 4 point roll bar is made of 1.750 x .120 DOM mild steel tube.
* All necessary installation and mounting hardware with back-up plates is included.
Why anyone would think any roll *bar* can withstand an incident such as this is beyond me. Where they had it mounted... doesn't surprise me one bit why it punched through.
--kC
KC is offline   Reply With Quote
Old 10-27-2009, 03:09 PM   #16
Element Tuning
Member#: 54918
Yeah a roll bar is inadequate for that type of incident. I would even think if it had larger welded plates it still would have pushed through the unibody. That's just too much weight/force being supported by two mounting points.
Element Tuning is offline   Reply With Quote
Old 10-27-2009, 03:17 PM   #17
Bimmubishi
Member#: 48713
1988 Raider-1JZGTE
DSG PLEASURE EVO DRIVER
...Poor Ted Williams dead frozen head.
Bimmubishi is offline   Reply With Quote
Old 10-27-2009, 04:21 PM   #18
djosbun
Member#: 202176
2004 WRX wagon
'07 Tribeca
HAHAHAHAHAHAHA (not at the crash, but at the Ted Williams quote).
djosbun is offline   Reply With Quote
Old 10-27-2009, 04:33 PM   #19
Beaverboy
Member#: 44501
'16 Nissan 510
Brown
Even if the floor had held.. how much would a roll hoop without a diagonal brace put up with?
They're probably lucky the bar did what it did, rather than folding in half and piercing their heads/spines.
Beaverboy is offline   Reply With Quote
Old 10-28-2009, 01:00 AM   #20
WgnWheel
Member#: 63605
04 Wrx Wagon -TTS
08 MX-5, 10 Golf TDI
yeah, that scares me worse about this crash. high speed, heavy car landing flat on the roof would probably destroy that bar. it's unbelievable to me that they chose to install that thing in the first place.
WgnWheel is offline   Reply With Quote
Old 10-28-2009, 02:09 AM   #21
imma_stocker
Member#: 97043
08 310awhp STI
02 zero hp Z28
How did they escape without being crushed? The roof looks about even with the hood.
Old 10-28-2009, 09:49 AM   #22
REX8
Member#: 24038
E46 /// ****box
Godspeed Cale...
Certainly better than nothing
Old 10-28-2009, 09:49 AM   #23
REX8
Member#: 24038
E46 /// ****box
Godspeed Cale...
Pushed to the side.
Old 10-28-2009, 10:14 AM   #24
djosbun
Member#: 202176
2004 WRX wagon
'07 Tribeca
Nice how they installed the slotted rotors on the wrong side of the car (the 'slots' should be pointing in the other direction).
Next time, hire a real racing shop to build your car.
Old 10-28-2009, 10:19 AM   #25
neilschelly
Member#: 94902
1999 Red OBS #28FSP
1992 Black BMW 325i
Assuming they installed it correctly and that it resembles the AutoPower bar I've got, the bar should have had reinforcement plates for the outside. Each point would have been a bar welded to a decently large plate (3"x4" I think), with 3 strong bolts through that plate then the floor, then an identical plate under the car.
Without the diagonal, it's a show bar, as KC pointed out, but it appears to have held up as well as any 4-point roll bar would hold up in an accident of that nature. To have that much force pushing down on the plates, I wouldn't expect any floor to hold up that much better. They really are designed for the more typical rollover scenario which would have far less severe forces acting on the bar. It's unfortunate that in a fluke accident like this, the bar essentially became a very heavy and hard object to potentially hit the passengers in the cabin.
Anyway, I think it's fair to say that only a full cage would have faired better in this case, and it would still have been pretty severely damaged I imagine.
-N
neilschelly is offline   Reply With Quote
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 06:43 AM.
