Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 10-30-2009, 12:02 AM   #1
halleedizzle
Member#: 216467
05 wrx wagon
wrb
Default in desperate need of help please read!!
i have a 05 wrx wagon with 92k on it and recently i did a 20g,750cc injectors,walboro255 fuel pump and a header uppipe install..... after a couple of maps from pdx tuning im on my way. it pulls great and is doing fine when all of the sudden when i hit 5k it falls on its face. contact pdx and the next day a new map comes and its solved. a couple of weeks pass and i get a flashing check engine light. #3 misfire... i reset the ecu with the accessport and everythings ok.... a few weeks later it does it again but this tiime its #3 and#1. again, i reset the ecu andit clears and runs fine. it keeps running well for another 5 days and the #3 comes back. i reset it and take it to my mechanic. he swaps out my plugs with 1 step colder ngks but when he does its on 24/7 no reset will fix it. the next night swapped out coil packs. ran like a dream then randomly a week ago it started #3 again. it runs and shakes violently and dies whenever you take it out of gear. i did some research and saw people said the valves stick so i seafoamed it and changed the oil. problem solved , no reset necessary. ran fine for 3 days and now it wont stop misfiring and resetting the ecu dosent work anymore.... any info would be very apriciated i have a lot of confused people trying to solve this mystery with me. and yes the injectors were flow tested by deashworks thank you, kelley
halleedizzle is offline   Reply With Quote
Old 10-30-2009, 12:04 AM   #2
Dirty25RS
Member#: 56731
2004 STi WRB,03 EVO8
2010 Volvo C30R-design
timing belt?
Dirty25RS is offline   Reply With Quote
Old 10-30-2009, 12:07 AM   #3
Tut4u2
Member#: 40424
02 GDB #2
MBP
Do you have a light weight flywheel?
Are the spark plugs gapped correctly?
Which intake are you using?
Get a compression test.
Tut4u2 is offline   Reply With Quote
Old 10-30-2009, 12:12 AM   #4
halleedizzle
Member#: 216467
05 wrx wagon
wrb
flywheel is stock, plugs are correctly gapped and im running the cobb short ram... also the other day when it was doing the studder and shake i floored it and i heard the power kick on and for a good 30 seconds i wasent misfiring
More Hot Topics on NASIOC...
Old 10-30-2009, 12:13 AM   #5
Tut4u2
Member#: 40424
02 GDB #2
MBP
Swap MAFs with someone and see if that fixes it. Your MAF might be maxing out.
Old 10-30-2009, 12:18 AM   #6
halleedizzle
Member#: 216467
05 wrx wagon
wrb
would that cause the cylinders to do all that?
Old 10-30-2009, 08:34 AM   #7
Dirty25RS
Member#: 56731
^A bad MAF/a MAF thats not scaled or incapable of proper scaling for your airflow can make a car act like a complete disaster. Without the MAF the engine is basically blind to whats coming at it. I've seen quite a few MAFs go bad and your symptoms could be from that. If you can get the car to do a good 6 or 7000rpm pull and datalog it, log the MAF signal and see if it looks as you'd expect it.
is the timing belt original?
Old 10-31-2009, 01:47 AM   #8
halleedizzle
Member#: 216467
05 wrx wagon
wrb
timing belt is original and maf was cleaned today with no luck
Old 10-31-2009, 02:04 AM   #9
JohnJ
Member#: 186769
Join Date 2002
18g wagon
Honestly I had a lot of the same problems with my emailed tune from PDX aswell. I needed one so I could make a trip to get it protuned. I gave a list of all my mods and so on to them, but for the 5 days until I could get tuned it had all the same problems as yours. Once I got it actually tuned, I haven't had a single problem. And it makes more power, runs better, and seems WAY more accurate than an email tune. 20,000 miles later I'm still happy. FWIW
JohnJ is offline   Reply With Quote
Old 10-31-2009, 02:07 AM   #10
spinningcain
Member#: 176490
2004 WRX VF39
I went thru the same ....swap mafs with someone even though you cleaned it rule it out
spinningcain is online now   Reply With Quote
Old 10-31-2009, 02:08 AM   #11
halleedizzle
Member#: 216467
05 wrx wagon
wrb
will do thank you... as far as a protune.... whats the average price ?
Old 10-31-2009, 02:09 AM   #12
JohnJ
Member#: 186769
Join Date 2002
18g wagon
$300 to $400 on average. Depends on the tuner.
If you fill out your profile, it'd be easier to help and find a good local tuner.
Old 10-31-2009, 02:10 AM   #13
halleedizzle
Member#: 216467
05 wrx wagon
wrb
thanks man... so as far as the same problems, it would missfire a cylinder off and on then just all the time?
Old 10-31-2009, 02:15 AM   #14
JohnJ
Member#: 186769
Join Date 2002
18g wagon
I had everything from #1 and #4 to #3 and #4 to all misfires. Car would act up, and even after installing all I did, it just felt wrong. I knew an 18g should feel more than the email tune provided. I was correct, I gained over 50whp and 40wtq from a protune vs. email tune.
Old 10-31-2009, 02:37 AM   #15
halleedizzle
Member#: 216467
05 wrx wagon
wrb
i just loaded the cobb 16g ots map to see and it still missfired... b4 i got the pdx maps i used that map to get around. no boost but it drove ... its still all misfires now
Old 10-31-2009, 09:36 AM   #16
JohnJ
Member#: 186769
Join Date 2002
18g wagon
This might sound like an obvious question, but by what method are you "resetting" your ecu? If you're not completley disconnecting the battery, try that.
Old 10-31-2009, 09:45 AM   #17
yerrow
Member#: 59094
'04 wrx wagon
world rally blue
and also depress the brake pedal a few times with the battery disconnected.
yerrow is offline   Reply With Quote
Old 11-02-2009, 03:14 AM   #18
halleedizzle
Member#: 216467
05 wrx wagon
wrb
update... its not the maf people said pcv valve or front o2... could that be causing this?
Old 11-02-2009, 03:35 AM   #19
ano2186
Member#: 158938
05 wrx 18G
i had maps from PDX and the car never ran right always wanted to die... your best bet is to take it somewhere and have it protuned by someone... once i had mine tuned all problems were solved
ano2186 is offline   Reply With Quote
Old 11-02-2009, 07:04 AM   #20
jaxscuby
Member#: 10613
blue
just for chits & giggles time for compression check..
Old 11-02-2009, 02:56 PM   #21
2.5ReallySexy
Member#: 167943
2004 WRX
You have people saying it's your tune, I would agree. Get a pro tune you will be happier
2.5ReallySexy is offline   Reply With Quote
Old 11-02-2009, 03:26 PM   #22
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
Did you ever do any logging? it sounds your car might have been trying to tell you it was not happy with the tune. compression test time. ECU reset is not a magical "fix"
crampfan is offline   Reply With Quote
Old 11-02-2009, 03:42 PM   #23
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
04 Jetta tdi 91 Legacy SS
Could be 2 other items I didn't hear mentioned.
Out of tolerance valve lash can cause incurable missfires (incurable at least until a valve adjustment is done).
Also a bad Front O2 sensor can cause your car to run like you explained. Put the car in open loop (WOT or above a certain RPM) and it will run fine, but when its in closed loop using the front O2 differently it will sputter, stall, backfire, etc . . .
MY99 2.5GT is offline   Reply With Quote
Old 11-02-2009, 05:23 PM   #24
thejordan
Member#: 185374
your bad tune might have fuel soaked the plugs and ruined them...
thejordan is online now   Reply With Quote
Old 11-02-2009, 06:46 PM   #25
Dirty25RS
Member#: 56731
+1. This can happen literally in 10 rotations of the motor (I've seen it)
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 04:08 PM.
