#1 |
Member#: 227033
Vehicle:02 WRX |
Hey guys just a quick question. Im sure this has been beat to death, but I just wanted a quick poll of what you guys thought.
When you take your headlights apart and reseal them should you add more silicone or just heat up what is leftover from the factory and just stick them back together? I just dont want any moisture problems later. Thanks guys
#2 |
Member#: 150248
SCIC
Vehicle:05 WRX/WRB UTEC Stg 3 |
There is plenty of goop in there, just be sure to bake it again when you're done to melt the sealant back together. You shouldn't end up losing any of that stuff, so you're not going to need more.
No moisture in mine! |
#3 |
Member#: 62439
Vehicle:2004 WRX STi Silver |
same here 5 years later and no moisture and still lookin pimp
#4 |
Member#: 161333
NWIC
Vehicle:09 wrx WRB |
the stuff that's used from the factory is butyl, not silicone. Silicone fully cures and cannot be re-sealed simply by heating it back up. Butyl can re-seal itself.
I say it all depends on how clean the butyl looks when you open up the headlights. if it looks pretty good, no need to add anything else. If it's uneven or missing pieces, just put a bead of silicone as a backup. |
#5 |
Member#: 227033
Vehicle:02 WRX |
Awesome thanks guys I'll just take the silicone back that I bought today.
Thanks again thats what I wanted to hear. |
#6 |
Member#: 228675
Anybody know a spot that hooks it up with painting your rear tail lights red in So Cal?
#7 |
Member#: 97495
NWIC
Vehicle:05 LGT SWP |
I have only reused what was there for both sets of lights I've done and both came out perfect. You can't even tell they've been apart besides the clear/paint.
I use the oven to separate and to re-heat before reassembly. I also take a minute to prepare the butyl since it can string a bit and stretch when you pull the lights apart. I even move some butyl around, stealing a bit from heavy spots for areas that could use a bit more. |
