Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 11-01-2009, 05:36 AM   #1
riderome
Member#: 210603
Default turbo pressure bouncing
I took a drive up to the headless horseman's haunted house today and on the ride home I decided to just do a straight pull off the ramp onto the highway. Second gear my psi quickly hit 15 and then a split second after staying at a steady 15 pounds, it jumped up to 19 and then started bouncing between 19 and 10. Every gear is like this, not that the gear would matter.
Any ideas? I reset the ecu and it still occurred, cel did go on but is off now due to the reset.
riderome is offline   Reply With Quote
Old 11-01-2009, 08:54 AM   #2
bryan_johnson
Member#: 78987
Do you have any mods we should know about? Or is it bone stock?
bryan_johnson is offline   Reply With Quote
Old 11-01-2009, 03:05 PM   #3
riderome
Member#: 210603
Mods are basic bolt ons from the previous owner such as a Helix catless downpipe, HKS uppipe, HKS carbon ti exhaust, HKS ssqv bov, and a K&N short ram intake. The car has never been tuned or remapped whatsoever, still trying to find money to get a tune.
Any ideas at all?
Old 11-01-2009, 07:42 PM   #4
riderome
Member#: 210603
I just cleaned the maf sensor and the maf tube with some maf sensor cleaner and the same problem is still there. I hit a steady 14.5-15psi and then after 3 seconds or so it jumps to 18 and then back down.
More Hot Topics on NASIOC...
Old 11-01-2009, 08:27 PM   #5
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
I would start by replacing all the lines related to boost control with new ones. Take special care to use the same size line, as well as to remove the restrictor pill from the factory lines and re-use the factory "T".
In the mean time, do not keep doing that if it is going to boost levels higher than stock.
CKxx is online now   Reply With Quote
Old 11-01-2009, 08:38 PM   #6
riderome
Member#: 210603
Ok I'll pick up some lines tomorrow and see if that does the trick, thanks for the response.
Old 11-01-2009, 09:42 PM   #7
WhiteBgeye02
Member#: 224785
2002 wrx
aspen white!
i had this same problem prior to my opensource tune. with the diff dp the waste gate isnt used to .the extreme flow that a bellmouth dp has so it opens up and then it releases alot more than it was expecting so it slaps shut and it boosts way back up. so it opens again and looses too much pressure. its a theory my friend told me that knows ALOT about these cars. once i got a tune the pressure bouncing disappeared completly
WhiteBgeye02 is offline   Reply With Quote
Old 11-01-2009, 11:24 PM   #8
CKxx
Member#: 33458
1988 Justy 1.2L 4WD
2002 WRX 2.1L AWD
This is also possible, but he made it sound like it had worked fine for some period of time, then began to act up.
Old 11-01-2009, 11:46 PM   #9
jsalassi
Member#: 61261
04 WRX Wagon
Wingless+Blue+Stg2
try cleaning out the boost control solenoid wth some rubbing alcohol.
jsalassi is offline   Reply With Quote
Old 11-01-2009, 11:57 PM   #10
riderome
Member#: 210603
I had the car a little over 8 months now and the car ran 15-16 psi without problems. Lately the car has been having days were it feels very weak, even though the turbo pressure shows the same psi. I never had this psi bouncing issue up until last night. Then again the downpipe is massive and it is running on a stock map with no tune.
I took a look at all the hoses and noticed that the hose that connects the intake to the turbo had a loose clamp where it is supposed to be sitting on the center of the turbo spool. I began to tighten it and saw that it wasn't fully sitting on the turbo.
Could this mean that the MAF sensor is out of whack, due to the fact that air may be escaping under high pressure from where the clamp has slipped off? I couldn't get my giant hands to fit in and push the clamp back up there so my friend with the gti is going to try tomorrow.
BTW I checked out the mini boost control hoses connected with the T and they seem fine but I will replace them anyways.
Old 11-02-2009, 01:51 AM   #11
spulbi
Member#: 190378
2002 WRX stg2
w/ 2005 STI front conver
Your boost shouldn't be fluctuating like that even with all those mods and no tune. I would check for boost leaks.
+1 on checking the bcs
spulbi is offline   Reply With Quote
Old 11-02-2009, 05:38 PM   #12
riderome
Member#: 210603
Found the definate problem, the turbo inlet hose is ripped to hell by the hose clamp, ordered a new oem one so should be here by wednesday.
Old 11-02-2009, 06:06 PM   #13
spulbi
Member#: 190378
2002 WRX stg2
Why didn't you go with a silicone inlet?
Anyways.. yeah that's a pretty huge boost leak.
Old 11-02-2009, 06:17 PM   #14
WhiteBgeye02
Member#: 224785
2002 wrx
aspen white!
mine was also ripped very bad. got a cheapy on ebay. works great. a few guys around here are having great luck with them. if u canreturn it i would and buy a ebay one for like 80 bucks. glad u found the problem!
Old 11-02-2009, 06:39 PM   #15
TeamJTC
Member#: 224475
I hope this is my problem!
TeamJTC is offline   Reply With Quote
Old 11-02-2009, 07:57 PM   #16
riderome
Member#: 210603
my father is a shop foreman so he contacted a friend at a subaru dealer and got the oem hose and new clamps for $80, I was thinking of a Perrin silicone one but I hward they slip off at times and it is almost a massive $300! I'll let you all know how the car runs once I throw it on.
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 01:12 PM.
