#1 |
Member#: 91836
SCIC
Vehicle:2003 Impreza WRX Sonic Yellow |
I took my '03 WRX into a local mechanic recently complaining of some gear and center diff whine. I recently changed out the gear oil to a brand-name 75w-90 (although I don't recall which brand) non-synthetic and since then, the shifting has been a bit sloppy with some increased whine.
When the mechanic took my car for a test drive, he noticed that my transmission is a bit worn and recommended to change the gear oil to the following cocktail to prevent further damage. 1 qt. Royal Purple "Synchro Mesh" (Synchromax?) 3.5 qt. Mobil 1 75w-140 Synthetic Naturally, I questioned the shop about this choice of cocktail, since it's not really the spec that is specified by Subaru, and they replied that while they normally use Subaru "Extra -S" gear oil, the cocktail above is a bit thicker and would eliminate the whine in my case while providing some extra cushion to the gears during shifting. They also said that this cocktail does not work without the Royal Purple "Synchro Mesh." Is there any potential downside to this cocktail? Can I use non-synthetic 75w-140 in place of synthetic?
#2 |
See the Uncle Scotty's cocktail thread. I have not heard anything good about Mobile1 in our trannys. If you are going to put a cocktail in use one that many other people have used for many thousands of miles.
#3 |
Member#: 140244
Whatever you do, DO NOT run that mix.
Use either Extra-S or Motul in your transmission. A lot of local subaru shops carry Motul gear oil. Extra-S can be found online in quart bottles. http://www.fredbeansparts.com/servle...ra-S%22/Detail you'll need 4 quarts for transmission, and 1 quart for rear differential. and subarus come with non-synthetic gear oil from factory. Motul is synthetic lube, and Extra-s (oem fluid), is hightly proccesed mineral oil, non-synthetic. In that link they state that its synthetic, but they're wrong. |
#4 |
Member#: 166975
Vehicle:2002 impreza wrx black |
Possible that the mechanic hasn't driven a manual subaru? I Know mine feels a lot less smooth than previous cars I've owned which could make one think that the transmission is worn.
#5 | |
Member#: 91836
SCIC
At this point, I should comment that this shop (Auto Headquarter) services Subarus on a regular basis and the head mechanic a certifed Subaru (and Honda) Master Technician and seems to have quite a lot of experience. In fact, as I pulled in to the shop, the entire parking lot was filled with WRXs, so was the garage, and, as I was sitting there, another WRX came in for a transmission issue. They are in fact, quite specialized to Subarus and WRXs in particular.
I should also say that he diagnosed and fixed a misfire issue faster than I can jack my car up. Not only that, he was very thorough in proving to me what the problem was (*very* dirty sensors in the intake due to an open airbox - flame me all you want here) and in solving the issue. Afterwards, I went on an extensive test drive with the mechanic, who was again, very thorough. They went on to diagnose a brake noise issue and recommended a proper fix (which I will do myself).Based even on my limited experience there, I would definitely recommend them to others owning WRXs. Anyway, the point here is that the shop's recommendation might actually be a good one - probably not deserving of comments like (although I do agree with the rest of rexman's post). Also, in regards to Quote:
Finally, the shop said that their cocktail cured others' tranny problems; although I don't know how well those results held up over time. In the end, while my tranny is a bit worn and a little notchy; I'll probably pick up some Extra-S from a local dealership (at like $7-9/qt.) and use that, as I'm cautious of mixing transmission fluids together (since the owner's manual warns against it). Anyway, if anybody has run a similar mix, please let me know how it went. Other comments are also appreciated. |
#6 |
Member#: 140244
Try it then, If the guys at the shop know subaurs, and post back with results. In case you won't like the feel, you can always change it to something else, the ones I mentioned in my other post for example.
#7 |
Member#: 131432
Vehicle:2004 WRX FP TDO5 18G! 07 6mt yay |
I've been using 1qt motul gear300 and 3 quarts redline lightweight shockproof and it works great, smooth shifts every time.
#8 |
Member#: 141720
South East
Vehicle:2007 WRX Wagon black pearl |
#9 |
Member#: 160814
Vehicle:2002 WRX Wagon PSM |
You're not really supposed to run shockproof in street cars where you're not going to be changing the fluid all the time.
2 quarts Redline 75w90NS and the rest (1.x quarts) Redline MT-90 is where it's at. |
#10 | |
Member#: 131432
go go smurfblood ![]() |
#11 |
Member#: 103232
Vehicle:GDA Built 2.5hybrid AKA SLEEPYBEAR soblowme |
#12 | |
Member#: 16200
Vehicle:bah straw and coal straw and coal as always |
you could not possibly convince me to put THAT in MY car no way in hell |
#13 | |
Member#: 160814
#14 |
Member#: 160814
#15 |
Member#: 160814
edit wrong thread
#16 |
Member#: 16200
#17 | |
Member#: 91836
SCIC
I think I'll go with Subaru's Extra-S for now. Sorting through the information/misinformation on here is dizzying... ![]() |
