#1 |
Member#: 12408
VIC
Vehicle:2000 Toyota Hilux SR-5 TD |
How realistic/expensive is it to do a diesel engine swap (like the KZ-TE or KD-FTV) from a Hilux into a North American-market Tacoma? A friend of mine is curious about it.
#2 |
NASIOC SUPER Supporter
n00b jesus Member#: 200000
South East
This thread is relevant to my interests
#3 |
Member#: 199998
Depends on how much you get your doner parts for. After that it is mostly labor.
http://vpizza.org/~jmeehan/toyotadiesel/ |
#4 | ||
Member#: 12408
VIC
#5 |
Member#: 199998
#6 |
Member#: 34631
Vehicle:2006 Legacy GT brilliant silver |
I've seen a lot of aborted projects... none actually completed.
I wanted to do the same, ended up w/ a LS1 |
#7 |
Member#: 33287
#8 |
Member#: 82470
International
Vehicle:My God, it's full of stars! |
#9 |
Member#: 135556
BAIC
I've contemplated doing this at some point in the future. But having read about how complicated it might be, it could be an even better option to put a 4BT in a truck like that since you're doing new engine mounts, etc, anyway.
edit: nevermind, the 4bt weighs 750lbs |
#10 |
Member#: 199998
A 4BT is a heavy engine, not sure how much the newer toy diesels weigh, but I would guess they are much lighter.
http://www.dieseltoyz.com/Toyota_die...nversions.html |
#11 |
Member#: 82470
International
Swap in a 12 valve Cummins ISB.
#12 |
Member#: 22035
SCIC
Vehicle:2008 STI White |
dont bother with those cummins. they are great, but even the 4banger is like 800lbs
to much weight for a yota. and if you do swap, the axles arnt going to last long.a toyota diesel is a great but hard to find parts for in the states. you can pick them up for some what cheap too. another great option that a lot of the US guys are doing are the VW TDI swaps. more power and TQ. I am still trying to figure out what diesel i want to put in my runner EDIT, would this swap be done in the US or canada? |
#13 |
Member#: 159682
Vehicle:1995 Impreza coupe 1969 360 |
I know nothing about toyotas, but in searching for jdm subaru front cuts, I've noticed that the importers are starting to bring in toyota hilux diesel front cuts.
#14 |
Member#: 4739
Vehicle:2009 Later. It's been fun. |
PM Hurley959. He's a Rover guy, but I'm sure he has some info about various other 4x4 diesel options.
#15 |
Member#: 87015
SWIC
Vehicle:- rouge says I'm dickier. |
#16 |
Member#: 165457
SCIC
Vehicle:'01 CBR F4i Red '89 4Runner Black |
22r is basically a diesel
#17 |
Member#: 199998
#18 |
Member#: 82470
International
#19 |
Member#: 199998
I am pretty sure a 6BT or ISB alone would exceed the GAWR of the front axle on a taco, let alone the rest of the truck, passengers, cargo, etc.
Just a thought... |
#20 |
Member#: 82470
International
#21 |
Member#: 12408
VIC
#22 |
Member#: 82470
International
#23 |
Member#: 42145
Vehicle:6-4 jockin da bish- es and slappin the ho's. |
It depends on what you can do and what tools you have, for me and my friends it would not be difficult. We've also body dropped trucks and built custom vehicles for years, including swapping engines into vehicles that didn't belong.
If you ahve the whole front clip, getting it to run is not the problem, fabricating everything is the biggest concern. Normally when you swap an engine, the first thing you do after stripping the vehicles is fitting the drivetrain phyiscally. I'm sure it's not a big deal in this case, but making sure that you have a place to fabricate motor mounts and run exhaust. You may have to make clearance with teh firewall, which isn't a big deal if you have a sledge hammer, plasma cutter and a welder. Once you get it mounted, then it's usually a question of cooling system, trans mount, intake setup, trucks are usually a lot less of a big deal over cars. Changing the dash is bigger deal, I just got done doing a FULL 06-07 forester FXT swap into a 00' forester, in order to do all the HVAC and dash and everything, we had to rebuild the firewall by welding up holes and making new ones so that the 00 firewall looked like the 06. We could've used the 00 dash and A/C, but that wouldn't have been as cool. It really isn't that difficult to do a "similar" vehicle swap, even doing something like converting a honda to RWD actually isn't THAT hard if you have the tools and the means. If you don't have the tools and means, the trade off is money, either buying parts or paying someone that does have the means and tools. There's a point at which you would be better off to buy a vehicle that someone all ready swapped, someone that did all the research, hunted down all the parts and worked out all the bugs. But then what? You spent thousands of dollars to save a few bucks a month at the pump and you lose money trying to find replacement parts from australia. But you have the cool factor. |
#24 | |
Member#: 62783
RMIC
Vehicle:2002 WRX Midnight Black Pearl |
There's a guy that put a 4BT in a Taco with upgraded springs and it worked out pretty well. The problem is the 4BT is too tall to fit in a taco and keep 4WD unless you also swap in a solid front axle. The guy that did the swap had a 2WD Taco. |
#25 |
Member#: 42145
Just like when you body drop a truck, why not just modify the hood to fit the engine instead?
