#1 |
So I searched and have been reading for the past three hours. I feel like my stock gutted uppipe is restricting my turbo, and an aftermarket one is in need. Now, I was really interested at the Grimmspeed, but I know it's slightly larger than the others and sometimes larger isn't better since it will cause lower spool, and others may be more efficient to keep the exhaust at velocity. So does anyone have any recommendations for an EVO III 16g 7cm, or 18g on 2.0? Yes it is protuned already. Also what about GS X-Pipe, is it worth it?
My Mods: SPT Short Ram Turbo XS Catless DP Apex'i N-1 CB APS Inlet FP EVO III 16g DW 650cc Injectors Hyperflow TMIC Perrin EBCS I think that is about it for pertinent exhaust and flow upgrades. Anyways, any feedback is welcome. Thanks in advance
#2 |
Member#: 131280
BAIC
Vehicle:2004 Impreza WRX WRB |
Depends on whether you plan on running an external wastegate or an internal one.
#3 |
I'm going to stick with internal for now
I realize that previous threads for this have been closed. I just want real users feedback on just the 2.0 that's why I put it in here, instead of the newbies. Please don't close. Move if you must, but I really don't see just cause. Last edited by SacksLax; 11-10-2009 at 12:46 AM. |
#4 |
Member#: 131280
BAIC
Go with a Grimmspeed Up-pipe.
#5 |
Member#: 126441
SCIC
Vehicle:02 bugeye |
invidia. comes with studs and nice gaskets.
don't do flex uppipe...diameter tapers down to oem or less than oem at the flex. |
#6 |
Amish Rake Fighting
Moderator |
http://forums.nasioc.com/forums/showthread.php?t=443943
If you keep what you have or use one hand forged by Jesus, you will net the same HP so you are spinning your wheels. |
#7 | ||
Member#: 136396
Vehicle:96 L 10 Genesis 99RS |
Justin |
#8 | |
I recently searched and found all the old threads regarding this, sorry for making another one, but I also didn't find much on crosspipes. Anyone have any insight to these? I know the factory one is restricted pretty bad around the flex section. |
#9 |
Member#: 216273
Vehicle:05 9-2x |
Maybe Jesus makes crosspipes? I live in the Bible Belt, I'll ask around.
#10 |
