Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2010
Old 11-19-2009, 01:06 PM   #1
ADAS1223
Member#: 159853
2oo5 Lamborghini
glass on the h0000000000d
Question 3-port EBCS: difference between port 3 and 1???
why are they swapped if EWG or IWG?
If you're running a MEBCS (mbc in parallel), does it matter anymore?
and just run port 1 for the pressure?
Grimmspeed has an installation diagram in their website to make it clearer for anyone.
i've seen 2 MEBC setups that are routed utilizing the port-3 as vent to intake/atmosphere.
i guess im looking if anyone knows the inner workings of a mac valve to clarify why is the 3-1 ports swapped.
c/f: I have an IWG. can i run port-3 venting to intake, because im running a parallel setup?
ADAS1223 is offline   Reply With Quote
Old 11-19-2009, 01:10 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
I install stuff cheap.
I wonder this as well.
kpluiten is online now   Reply With Quote
Old 11-19-2009, 03:37 PM   #3
ADAS1223
Member#: 159853
2oo5 Lamborghini
anyone? bump
Old 11-19-2009, 05:52 PM   #4
GrimmSpeed
Member#: 136396
96 L 10 Genesis 99RS
I think usually a pic helps explain this better..check this out:
If you take a look at this image and compare it to the images we have in the install guide i think it will make more sense. Our solenoid is "universal", it can be plumbed either way.
GrimmSpeed is online now   Reply With Quote
Old 11-19-2009, 06:01 PM   #5
ADAS1223
Member#: 159853
2oo5 Lamborghini
perfect! thanks a lot
More Hot Topics on NASIOC...
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 01:36 PM.
