#1 | |
Member#: 206931
South East
Vehicle:2004 WRX Wagon Stg4+ 5MT JBP 318WHP//300WTQ |
Just as the title states, has anyone taken readings off their rear O2 signal?
Mine stays around .3-.4V cruising and idle. I know the range is 0~.9V IAW the ECU pinout. I am wondering because I thought cruising/idle was supposed to be around .7-.8V I am thinking this may be why my car is running rich. Probably not but possibly. The sensor inefficiency code may be turned off in the ECU, I cant tell- I have ECUtek bull**** and no tuner nearby to ask for help. EDIT: ANSWER= Quote:
#2 |
Member#: 206931
South East
Anyone know? Anybody?
#3 |
Member#: 151045
Vehicle:2004 JBP WRX Stage II - Monster TD04 |
The rear O2 sensor adds only very minor fuel trim characteristics. It won't make you run rich by itself.
#4 |
Member#: 16200
Vehicle:bah straw and coal straw and coal as always |
#5 |
Member#: 206931
South East
Thanks for the help. However I did already know that.
Does anyone know the voltages they are getting from the rear O2 sensor normally. Its not a completely uncommon thing to measure. |
#6 |
Member#: 53558
NWIC
Vehicle:2002 WRX Wagon Silver |
.7-1v is normal.
As long as it's a flatline and not going up and down like the front O2, it's usually fine, even if it's somewhere other than .7-1v. Though, at .3-.4v, I'd suspect a problem, like being lean. What is your front O2 reading? |
#7 | |
Member#: 206931
South East
I took the reading in the process of wiring up my Innovate LC-1 Wideband. I have all the wiring done up for the wideband O2 but in order to calibrate the analog output to OEM (to wire the stock sensor signal into the wideband) I need a USB/serial converter... Macbooks ditched serial ports. |
#8 |
Member#: 16200
id look elsewhere for your issue
your tune may just be way too rich ditch that ecutek garbage and get opensource and be done with it |
#9 | |
Member#: 206931
South East
The tune is probably not to blame as its had the car at 304WHP/289WTQ (and probably more since my last dyno and recent mods) for the past 60,000 miles without a bit of problems. |
#10 |
Member#: 178047
SWIC
Vehicle:02 WRX STI Spec C Black |
The Rear 02 does effect the tune. The readings seem fine to me. Should be .3 to .5 cruise and idle. Under boost it should go higher up to .8 or .9. The trouble is they are not super accurate and the sensor is all the way at the midpipe far from the engine. Any leaks in the exhaust will really this this reading off. I used 1 volt 02s for many years tuning.. Glad we have WB meters now
![]() If the car is not running right, Let me know. I can help. But if its running right and you want to ditch the Ecutek, You will need a New or used ECU. They can be found cheap. If you do decide to go this way, I can port the map over to Cobb AP2 for you. Hope this helps man! Clark |
#11 |
Member#: 70395
Vehicle:02 wrx whitey |
Just totally remove the rear O2..................
#12 |
Member#: 178047
SWIC
No.. Dont do that.
C |
#13 |
Member#: 129231
Vehicle:2005 wrx cgm |
i have no rear o2, its been gone for a long time. 16 bit ecu doesnt need it
#14 |
Member#: 178047
SWIC
You would know better than me.
C |
#15 |
Member#: 16200
#16 | ||
Member#: 206931
South East
![]() I would probably be having to Express Mail two ECUs to your doorstep for that to work out eh? I didnt think Cobb AP2 could handle the amount of tune my car has. Its a pretty done up "Stage 4+" or whatever you want to call it . I do want to go open source.Thanks Clark -Tom |
#17 |
Member#: 70395
Could you explain why you need it? My understanding from the Romraider guys is if you totally ditch it all fueling corrections will default to the front O2 sensor. I have been running for almost 2 years without a rear O2 with no problems with plenty of logs with a wideband.
#18 | |
Member#: 178047
SWIC
![]() The Cobb AP2 is FAR better than open source. Lots of features that Open source does not have. Cya Clark |
#19 |
Member#: 90642
NESIC
Vehicle:2002 WRX Wagon WRB 02C |
If you have some secret as to why the rear 02 is needed on the 16 bits car, it would be nice to share this enlightenment. IME, its not necessary.
Id also like to know abotu all these 'features' that the AP has that opensource does not. OP, you dont need a new ecu to ditch ECUTek, IME Ive been able to simply marry and unmarry an APv2 to get it back to stock and ready to flash with any system you like. M@ |
#20 |
Member#: 178047
SWIC
Cobb wont install over ECUtek flashed 16Bit ECU. Open source wont flash over it either.
In the past you could be not with the ECutek version thats been out for a year or so. There is no comparison to features of AP2 vs open source. The differences are way past the scope of this thread. I tune both and have for years now. I prefer AP2. C |
#21 |
Member#: 129231
you tuned it like that about a year and a half ago
but its prob been tuned a dozen or so times since. it was my understanding that in a 2.0L wrx, the secondary o2 sensor functions as a catalyst efficiency monitor. so when you go catless, it becomes useless. as long as the code is deleted in romraider, you can delete the sensor. i also thought that you need it on 32 bit ecu's because it serves two functions, it is a catalyst efficiency monitor, and it double checks the front o2 values. but if i'm wrong, then i am wrong. i never said i was better, or that i knew more than you, i only stated what i thought was true. Last edited by MrSlowbaru; 12-01-2009 at 09:34 PM. |
#22 |
Member#: 90642
NESIC
Hmm, interesting about the cobb reflash deal not woring on 16bit. Ill have ot think about that for a bit. I know it works with at least some ecutek'd cars that are 32 bit because I have personally seen it done.
Everytime I ask about how an apv2 is a better system I get the same vague answers. It would be great if someone that tunes on both could do a comparison one day. I parallel it to Crome vs Neptune in honda world. On the face of it they seem the same, except Crome is free (not OS). But I can easily explain the ways Neptune is superior to tune with, and on the end user side. Ive never seen that done for AP vs anything. On the rear o2 deal, my understanding is the same as the above poster. |
#23 |
Member#: 178047
SWIC
32 bit with ecutek : Cobb and open source can go over the top.
16 bit with ecutek: Cobb and open source CANNOT. The only way to get rid of it on the 16 bit is to: 1. Throw it out in the street and let cars run it over. 2. Use the ecu has a door stop for that peskey door that wont stay open. 3. Use it as a book end to hold up books? 4. Ecu Frizbee anyone? 5. Sell it on ebay or Nasioc classifides and dont tell anyone about the ecutek (common) 6. Hardware flash the actual Microproc directly. Clark |
#24 |
Member#: 54592
SCIC
I think with opensource you have to reflash the ecu each time you want to make a change. I'm not a tuner but I imagine this would be tedious. With the AP2 you can make changes in real time. Unless they have a new opensource update that I'm not aware of. I think I read that they were trying to implement real time changes but I don't know if/when it will happen.
#25 |
Member#: 90642
NESIC
its actually not that bad to reflash the car each time, especially on the canbus cars it only takes a few moments and there are no test connectors, but thats a valid point
