#1 |
Member#: 228210
Vehicle:09 Wrx premium Lightning red |
anyone else get a throw out bearing noise (chirping) when the car is cold? it goes away when the car is warmed up. is this normal for a subaru? i have 1500 miles on the car
#2 |
i haven't heard any chirping with my car...
#3 |
Member#: 216135
South East
Vehicle:2009 WRX SSM |
Mine does. There is a thread about this in this forum. I'd say a half dozen people in that thread said the same thing.
#4 |
Member#: 223960
Vehicle:2009 WRX Sedan Dark Gray |
I am not sure but you should look for the thread as stated above. When the car is first turned on for 30 seconds it is supposed to make a strange noise. The thread details it and all, but it is to be expected for 30 seconds to hear something you wouldn't normally expect with a car warming up.
#5 | |
Member#: 216135
South East
The OP is referring to TOB/clutch noise while you are engaging the clutch in gear when cold. Mine usually goes away after 3-4 shifts. Most dealerships either say it's nothing wrong and to put up with it, or cannot reproduce. |
#6 |
Member#: 212399
Vehicle:2009 wrx gh swp i can haz sc00by snax? |
yeah, there are a few of them. here is the one i started: http://forums.nasioc.com/forums/show....php?t=1775341
still does it depending on humidity. haven't had any problems from it and it's not obnoxiously loud from the inside so i'm not bothered. |
#7 | |
Member#: 216135
South East
#8 |
Member#: 223960
Glad i dont have this issue =) But now thanks to that one post if i ever do i know exacty what it sounds like.
#9 | |
Member#: 212399
#10 | |
Member#: 216135
South East
#11 | |
Member#: 82767
NWIC
the noise is the bearing moving back/forth slightly. it keeps doing this, and it will wear down the snout of your transmisson assy. and that.... will make it impossible to correct without a spendy tranny snout repair kit and this tranny snout repair kit means you will no longer be able to use OEM throw out bearings. take the car in. get it replaced and sorted out under warranty again, my advice? do not ignore this..... |
#12 |
I have a click every time I push the clutch in.
#13 |
Member#: 216135
South East
Is it just shortly after pushing it in, or at the bottom of the pedal stroke?
If shortly after pushing it in, you need a new cruise control switch. I had mine replaced a few weeks ago. If at the bottom you need the engine start clutch switch. also, try putting a bit of grease on the white rubber pad on the clutch pedal where it pushes the cruise switch in. |
#14 | |
Member#: 212399
and... will it really mess things up given it only does it about 2min a day a most? it's most predominant between shifts. if you're off the clutch, it's fine. |
#15 | |
Member#: 216135
South East
#16 | |
GC84Ever
Super Moderator |
then it started again. I ignored it. Now my car has a nifty tranny snout repair kit..... and an aftermarket TOB ![]() wish I had more information for you but your best bet? especially on a new new car? see your dealership. |
#17 | |
#18 |
Member#: 223960
The bottom line is, not just anybody responded to you guys. But someone from genuineparts.... I would take his advice very seriously. They say not to ignore it so get your ass to a dealership and make them go at it till they fix it =) the only one who suffers in the end is you.
#19 |
^^ agreeed
#20 |
i didnt hear a chirping noise but i felt a vibration in the clutch pedal... and its horrible because my whole car was vibrating...my brother felt it too and he was in the passenger seat?!?
#21 |
Member#: 190978
My car does that too when its cold, but now there is something else that i cant figure out. the chirpin noise is there at traffic lights at idle always but when i press the clutch pedal down it stops. Anybody knows what it is?
Some input will be appreciated Thanks |
#22 |
Member#: 191290
Vehicle:2009 WRX OPB Sedan 1970 Triumph GT6+ |
ditto, I get it on occasion. A kind of chirp/whirr sound when the car is cold. Doesn't always happen when its cold, just some of the time.
Unfortunately, the dealer wouldn't be able to replicate it, since it won't do it when warm... |
